driveshaft noise/vibration
Discussion in 'XJ Technical Chat' started by Victor Hugo, Jan 7, 2021.
  1. Victor Hugo
    Victor Hugo New Member
    Mexico
    Hello everyone, I have a problem. I have a 1985 xj700x. I have been working on carbs, last week I finally put them back on, I was going for a ride but I start to hear an annoying sound from the driveshaft, it sounds like metal hitting metal and the bike started to vibrate. When I got home, I put the bike on the center stand, I started it in neutral but it works without problems, when I put her in gear starts to vibrate and makes the sound again.
    The noise is only evident when the bike is in gear.
    I inspected the bike and found this:
    I think it is called U-joint, it is damaged, I am going to replace it, but my question is: is it normal for the U-joint to be damaged? Is there anything that could damage the U-Joit? Should I check something else? And could this be the source of the noise?
    I would be grateful for any solutions / advice etc, thanks
  2. mlew
    Not normal, that one is damaged beyond repair it will need to be replaced
    Jetfixer likes this.
  3. k-moe
    The bearings in the yoke failed. Then it ground itself to death, seized, and finally snapped.
    An uncommon problem, but one to look out for on any old machine.
  4. JCH
    JCH Active Member
    seattle wash
    How many miles on your Bike Victor ?
  5. Victor Hugo
    Mexico
    I don't know, the tach says 25000 +/- but it has no speedometer cable since I bought it so I don't know
  6. Victor Hugo
    Mexico
    It was worse than I thought, the U-joint was completely broken
    upload_2021-1-28_13-19-15.png upload_2021-1-28_13-20-24.png upload_2021-1-28_13-20-51.png upload_2021-1-28_13-21-9.png upload_2021-1-28_13-21-26.png
    I replaced it with this one that I found on Ebay
    I took the bike out for a ride and it runs smoothly.
    Thanks for the help
  7. chacal
    Yikes, that was ugly! Good thing you took it down for a look-see.....
    hogfiddles, Jetfixer and k-moe like this.
  8. jayrodoh
    jayrodoh YimYam
    Cleveland
    Holy crap, obviously someone rode it for along time after it failed to get like that!
  9. JCH
    JCH Active Member
    seattle wash
    Doesn't look like it is easily servable, did you try to inject some grease into the new one or anything like that.
    Was it easy to swap out, did you just remove the rear tire and swing arm.
  10. Victor Hugo
    Mexico
    Its easier than it looks like.
    I didn't remove the swingarm, I did as k-moe explains in this post:
  11. Franz
    Franz Well-Known Member
    Scotland UK.
    Easily serviceable surely means replacing complete CV joint in comparison with replacement of bearings in worn but repairable joints.
  12. k-moe
    The XJ u-joint has no provision for regreasing, or rebuilding...well, not without some major surgery (the bearings are staked into place).
    Replacement is the best option.
  13. a100man
    a100man Well-Known Member
    Bedford, UK
    What's a drive shaft?
  14. k-moe
    Propshaft to you.
  15. XJ550H
    there is a post from a member from Argintina his avatar is red, thats all i can remember.
    he sourced a cross joint from a catalog that was for a renault and repaired his yoke.
    there are lots of u joints on ebay so no need to get in deep unless you cant get one
    Franz likes this.
  16. k-moe
    I remember that thread well. He actually had the Renault u-joint modified to fit and used it instead of the OEM u-joint.
    XJ550H and Franz like this.
  17. a100man
    Bedford, UK
    ..it was a joke (of sorts) - the 550/600s run chains.;)
  18. hogfiddles
    What’s a chain?
  19. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Chain (unit) The chain is a unit of length equal to 66 feet (22 yards). It is subdivided into 100 links or 4 rods. There are 10 chains in a furlong, and 80 chains in one statute mile. In metric terms, it is 20.1168 m long.
    k-moe, Franz and hogfiddles like this.
  20. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Great and accurate answer.
    hogfiddles likes this.
  21. hogfiddles
  22. XJ550H
    whats a cubit?
  23. hogfiddles
    1. A variable length, from the elbow to the middle finger tip. On a building site, ONE person (typically the ‘foreman”, was the only person to do the measuring.... otherwise measurements would vary unless everyone else had the same length arm/hand/finger.
    2. a game
  24. a100man
    Bedford, UK
    Which is also the length of a cricket pitch (well, the wicket part that is).
  25. Huntchuks
    East Rochester, NY
    Wasn't that Q*bert?
