Stalls when warm
Discussion in 'XJ Technical Chat' started by josh the man, May 21, 2020.
  1. josh the man
    josh the man New Member
    MN
    Hello all,
    This is my first post on this forum, but have been doing a lot of research and still haven't found the exact issue I'm having.
    I have a 1982 Yamaha XJ550 Maxim. Its my first project bike and picked it up for $250. I drove it home knowing I would have to do work on it. The first thing I had issues with was it not shifting right. After going through the forum I found that my return torsion spring and the Shift Shaft Torsion Spring had failed. I replaced them and put it all together and it seamed to shift fine. Since then I have had the carbs rebuilt by a shop which used a sonic cleaner and oem parts. I then did a valve check and they where all way out of spec and so have just replaced the shims so that they are all now in proper spec. The bike will start up with little effort, however when its running for about 5 min., just long enough for the bike to warm up it begins to struggle at idle then after drooping some cylinders it stalls. I also notice some smoke coming from the clutch cover. Would a clutch cause the engine to stall at idle? I'm wondering if I installed the plates incorrectly. Thanks in advance for the input and sorry if this has been asked already a thousand times.
    Your fuel cap vent may be clogged there is a link on how to fix it at www XJ 4ever.com end of the how to,
    Did you put oil in the bike is it at the proper level? Seeing you had your clutch out in the pot if you're unsure you should definitely look at it again
  3. josh the man
    MN
    Ill take a look at the fuel cap vent issue. as far as I can recal I put in the proper amount of oil, but it wouldnt hurt to drain and refill. During that time ill take a look at the clutch again.
  4. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    The smoke is condensation, assuming you vent is open?
    If it slows as it gets hot the mixtures are likely rich at idle, you need to try screwing each mixture screw in by an equal amount to see it helps.
    hogfiddles likes this.
  5. SQLGuy
    SQLGuy Well-Known Member
    I hadn't heard the oil filler hole called a "vent" before.
    Another possibility is rust/debris in the tank, clogging the fuel tap and, if you have one, the fuel filter.
  6. josh the man
    MN
    So I ran it till it stalled, opened the gas cap and tried to start it. It would start, but die right away. The petcock is new with a filter. Finally as I was about to take a look at where it was smoking I opened up the oil fill cap and it smelled like gas and quite viscous. I think its flooded at this point, which makes me think that the floats are needing adjustment. I did check the spark plugs, cylinder 3 plug was all black.
  7. XJ550H
    stop riding change the oil and fix the floats and needles if your lucky it is the #3 cylinder only
    hogfiddles and josh the man like this.
  8. Minimutly
    West Wales, uk
    I meant the vent pipe - hose being off, not the filler.
  9. josh the man
    MN
    I'll give her a go.
  10. Polock
    how confident are you with the valve shim job? do the valves make more noise now that they're set?
  11. josh the man
    MN
    I'm confident, checked each valve several times before and after each shim was replaced. I also would crank it over by hand a couple times after each install to insure that it was properly seeded. Just to be clear I haven't driven it since the carbs have been rebuilt. So all diagnostics have been done in the garage. I've had plenty of time to work on it as of late so its been wrenched on almost every other day. I'm hoping to pull the carbs out this weekend as loath as I am to do it, to check float height.
  12. SQLGuy
    I kind of thought that, but the breather is on the opposite side from the clutch cover.
  13. josh the man
    MN
    If your referring to the breather from the crank case to the air-box, on my xj550 its on the clutch side. The smoke seems to be just oil burning off the frame as it hasn't been driven in a while, just ran in the garage.
  14. josh the man
    MN
    The hose is connected.
  15. josh the man
    MN
    Update!
    Just to give you all an end cap on this thread this is what I wound up doing. after several tests I found large amounts of fuel dumping in to the engine mixing with the oil. I determined that the bike was not firing on all cylinders so thought it might be a stuck float in the carb. I pulled them off and tested it with no issue. from here I changed the oil and still found that it was filling with fuel. I decided to send the bike to a shop that specializes in classic Japanese bikes. They found that the plugs where bad as well as the wires where in need of replacement. I also never had the carbs synced so I had them do that too. It now runs like a top! I cant believe I didn't check the plugs or wires. such a silly thing to not consider. Thank you all for the help!
  16. Polock
    plugs and wires to fix gas in the crankcase.... that's a new one
  17. josh the man
    MN
    I believe since it never ran on all cylinders fuel was dumping into the head and since it never got warmed enough to burn any of it off it would just fill up the crank case every time I tried to start it. In other words I was flooding the engine.
  18. Franz
    Franz Well-Known Member
    Scotland UK.
    I thought the breather was on the clutch cover side on the 550?
  19. josh the man
    MN
    You are correct
  20. hogfiddles
    You can see it here on a 550 I’m re-assembling. It’s not actually ON the clutch cover— it’s just beyond it.
  21. k-moe
    That can't happen. The majority of the vaporized gas will be pushed out of the engine on the exhaust stroke. A small (very very small) amount will wash oil off of the cylinder walls and end up in the crankcase, but you'd have to run the engine like that for years before it would amount to anything, and even then it would evaporate out through the breather. there would never be enough to see in the sight glass. The only exception I can think of would be if you're missing a piston.
    The most likely cause is that you had a hung-up float or float needle that finally got settled into place. This can happen even with perfectly-rebuilt carbs with all new parts, especially if the correct float needles are not used (there are at least two kits on the market that do not have the correct float needles).
    Check that shop's work. The plug wires are not replaceable as they are moulded into the coils. If they didn't list new coils on the invoice, or if you don't see splices on the plug wires, then don't ever go back to that shop.
  22. Franz
    Scotland UK.
    My CB750 had a set of points stuck open, so no spark on a pair of cylinders. Happened coming off the motorway near my home. My understanding is a flooded engine has an excess of fuel that fouls the plugs, not fuel flooding the crankcase.
  23. hogfiddles
    We don’t have points, and yes- usually a flooded engine has soaked plugs. Flooded crank case is another issue.
  24. Franz
    Scotland UK.
    The TCI is a great improvement. I managed to get two spare ones although one is home made. There is a picture on the forum of it.
