Stuck in gear
Discussion in 'XJ Technical Chat' started by Yammaat, Mar 31, 2021.
  1. Yammaat
    Yammaat Active Member
    Netherlands
    Aaaarrgghhh.. my seca is stuck in first gear and won't shift anymore.
    I made a nice ride.. parked it, left after an hour, rode it 2 km's, stopped at a trafficlight and no upshifting possible any more.
    Any hints of what might have happened? Spring inside the engine?
    Probably the engine has to come out I assume.
    Damn.. was just preparing for a nice trip etc... but rather at 20 km from home then somewhere in Europe.
    Is this a familiar flaw? Haven't searched the database/posts yet coz now I'm typing on a computer that's not mine.
  2. Franz
    Franz Well-Known Member
    Scotland UK.
    Check under the gear selector cover for any broken components. If they are fine it might be your alternator/starter chain guide failure. Check for plastic bits in the engine oil and the sump.
    If it is the guide the cases have to be split. You can see through a opening in the crankcase when the shifter cover is removed for plastic bits too. An oil spray nozzle behind the alternator rotor lubricates the chain. That will get ruined if the guide has failed as the chain will hit it.
    Jetfixer likes this.
  3. Yammaat
    Netherlands
    I could still ride the bike in first gear without any extra noise whatsoever.
  4. Franz
    Scotland UK.
    If is your guide you are better not using the bike until you repair it.
  5. Franz
    Scotland UK.
  6. Franz
    Scotland UK.
    Check it first. Hope it's not the guide. I would remove the selector claws, etc under the shift cover and try and rotate the selector drum by hand. If it won't turn you might have plastic stuck in the drum tracks the selector fork pins fit into.
    Check this.
    https://www.xjcd.org/emergency_guidectomy
    Yammaat likes this.
  7. Yammaat
    Netherlands
    Aha.. ok but first I have to get the bike home and the engine out. The gear spring seems ok but blocks when trying to get the shiftlever up to neutral or second gear.
    Got another engine complete and one in parts.
    Big bummer nevertheless.
  8. Franz
    Scotland UK.
    Can you do an engine exchange to keep you on the road while you repair it? If you have to split cases check the starter clutch rollers and springs, renew the guide and bolts and check both chains. Heat up the bolts holding the old guide before slackening them to soften factory thread lock. The bolts can snap if they are not heated first. I think you can leave the top end of the motor assembled if you are not changing the starter/alternator chain.
    Yes it's unfortunate. I changed mine last year. The guides fail with age.
  9. Yammaat
    Netherlands
    I just saw the links to get the engine out and how to check/clear the shiftmechanism .
    Thanks.. could be helpfull.
    I haven't looked into it sofar because I just got home and had to eat first..lol
  10. Franz
    Scotland UK.
    I like to use the frame to anchor the engine for slackening tight components. But it is fine to remove it with the engine closed. Mezzmo engine rebuild here, more videos on YouTube. Same as the 750.
  11. Yammaat
    Netherlands
    I will first check the space behind the shiftcover to find out what is going on.
    The other engine will have the same agingproblem I presume so swapping is even more timeconsuming.
    To be continued..
  12. XJ550H
    when you have the cover off do this. read the link on guidectomy it is ment to be done on side of rode to get you home
    Yammaat likes this.
  13. Yammaat
    Netherlands
    Thanks.. I will give it a try and otherwise it could be the end of the SecaRat because hauling 75 kg engines and working in a small space without proper utilities is not what I'm gonna do I'm afraid. Buying another seca, with a high probabillity that it will happen again due to age, and rebuilt it all. Or am I too pessimistic?
    Pity though because the bike was finally the way I liked it.
    But we'll see what happens if I open up the left side.
  14. k-moe
    You are being pessimistic.
    I've changed truck transmissions out in a gravel driveway (in the rain mind you) without a proper transmission jack.
    My first workshop was a metal 8x10 shed. Power came courtesy of a 50' extension cord.
    You can keep her working.
    Jetfixer and chacal like this.
  15. Franz
    Scotland UK.
    I used a sack truck to move the engine and had a small room to work on it. I stripped and rebuilt it on the floor. Making a bench for the next one l work on. And if you rebuild your engine the SecaRat will run for many more years.
  16. Yammaat
    Netherlands
    I will try to pry the stuff out and see how it goes from there but I will not rebuild the engine.
    The job is to big under the circumstances and will take to much time all in all.
    Believe me I really care about this special machine (for me) but I have t0 stay realistic.
    Sorry guys (and girls).
    Will keep you informed about the rubbish removal.
  17. Yammaat
    Netherlands
    There might be an other option;
    how does the 900F relate to the seca regarding fitting other exhaustdampers, frontfork top triangle, to put the secasteer and stuff on there again.
  18. Yammaat
    Netherlands
    Does the top/triplecrown of a 750 seca 11M fit on a xj 900?
  19. Yammaat
    Netherlands
    Nobody knows the anwser to the crown question I guess? Will look into that myself then.:)
    Next plan regarding the seca; I'll probably buy another Yamaha, perhaps a Tracer 700 or TDM, and take my time with the seca.
    I will not rebuilt it myself but bring the engine to a very good mechanic when time is due.
  20. k-moe
    A lot of us were riding on the weekend, or like me preparing for a new week of teaching (yay...It's standardizied testing time /sarcasm).
    The 900 engine should fit into your 750 frame, but it will be a tight fit. You might need to pull the engine for valve checks.
    The Information Overload Hour
    The triple tree should fit, but there might need to be a change of bearings. Check with @chacal or All Balls Racing
    I have no idea about any potential geometry changes since I've never had a 900 to look at.
    I envy you Europeans and the access you have to the TDM range. I passed on a TDM 850 due to the lack of an extra $500 (in the 90's).
  21. Yammaat
    Netherlands
    Well..there seems to be light at the end of the tunnel;
    the plan was to buy a 900 and refurbish that bike into a seca, to me btw only the 11M is a real seca.
    Put the crown of the seca on the forks of a 900 and go.
    To have a 900 engine in is very appealing to me but could experience the same problem then...
    But.. did some snooping around and there are some shops that are willing to do the splittingjob etc. of the old engine.
    Parts are cheap so all in all it would cost me around 5-600 euro when only the engine is delivered. Peanuts in my opinion for such a good engine. I've got a shitload of extra parts so could ride the seca till i'm buried or something..lol
    In the meantime perhaps an Tracer 700 or a TDM so that would mean an extra bike :).
  22. Franz
    Scotland UK.
    SecaRat getting repaired and a spare bike, that's cool.
  23. Yammaat
    Netherlands
    Still got an srx-6 and a fj600 ratbike.
    But more important.. first we'll have to see what happens in the Ukraine because the shit is hitting the fan soon is the prediction.
    Ukraine declared war on Russia last week and bombs are falling.
    It's fairly closeby so..
  24. Yammaat
    Netherlands
    Well.. as it turns out after some TDM-riding last months, the SecaRat won't be rebuild.
    To much trouble and time doing so, I have no garage and all wrenching must be done in a seacontainer 10 mls from home + $1000.
    The difference between the two bikes is very big especially regarding the stability, brakes and suspension (!!).
    Had to make many miles and cornering efforts to get used to this bike but now I am and I like it.
    Still miss the Seca's turbinesound and low-end smoothness but the 'snork' and torque of the TDM, when yanking the gas open, is very addictive.
    So.. 2 xj-bikes in parts now.
    Still got the unused external oilfilter conversion if somebody is interested in this part.
  25. Yammaat
    Netherlands
    But.. perhaps some of you (in Europe?) would like to have some parts so all is either going to be scrapped or I can make somebody happy with some items.
    Still got a lot of stuff left but not for long...
    The TDM runs fine and is a good bike but still kinda miss the turbine-like running Seca. Still the best running bike I've owned.
    Anyway.. let me know if you want something. Parts are nearly free of costs.. shipping isn't ofcourse.
    Take care (of your XJ) and have fun!
