Battery Replacement?
Discussion in 'XJ Technical Chat' started by Dullahan93, Apr 3, 2021.
Tags:
  1. Dullahan93
    Dullahan93 New Member
    Suffolk, Va
    I'm new here, recently bought a 80 XJ650 Maxim project bike and I've been searching for a new battery. The manual says to use a 12NI2A-4A, but I was wondering if there are any others I could possibly use in place of that one, being as none of my local shops have them. Thank you for any help.
    thats the battery size.
    ebay sells them most with free delivery
    wal mart sells them
    tractor supply
    auto parts stores sell them
  3. XJ550H
  4. XJ550H
  5. Dullahan93
    Suffolk, Va
    So do I have to use that specific battery or are there substitutes I can use?
  6. k-moe
    You can use any battery that meets the physical size, post placement, voltage, and cranking amps requirements.
    Most sellers will have a cross-refrence by application.
    If you can afford the extra initial cost of an AGM battery, get one. There is an overall cost savings because an AGM battery will provide longer service, and won't spill acid if the bike should tip over.
  7. XJ550H
    see my edited post for one in advanced auto parts
    12NI2A-4A is incorrect 12N12A-4A this is correct number
  8. Dullahan93
    Suffolk, Va
  9. Dullahan93
    Suffolk, Va
    O'Reilly's says that a B14L-A2 will work so I'm assuming that one would be ok also?
    And I found an AGM but wasn't sure if the CCA being 220 would be too much? I'm not too familiar with batteries
  10. XJ550H
    The higher the CCA the better it is the ability to start the bike in cold weather
    Nj
    Jetfixer and k-moe like this.
  11. dkavanagh
    Rochester, NY
    AGM all the way! Less mess (no vent) and better performance. I have the MotoBatt in 2 of my bikes.
    Jetfixer likes this.
  12. Dullahan93
    Suffolk, Va
    Do you mind linking me a AGM I could use?
  13. Dullahan93
    Suffolk, Va
    And thank you to everyone who has given insight and help. It's much appreciated
  14. dkavanagh
    Rochester, NY
  15. Erick Quezada
    Erick Quezada New Member
    Kitchener
    Hello all.
    Is this a good battery to put on my xj650
  16. chris123
    chris123 Active Member
    Benicia, ca
    I have a MotoBatt MB12U in my other bike and it’s been great - but unfortunately it’s creeped up in price so I’m looking for other AGM options.
    How’s the “mighty max” battery working out?
    Does anyone else have an AGM recommendation?
  17. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
    I had a 18 month old mighty max go bad.
    I have a pirate battery that hasn't given any trouble in 14 mo. so far.
    now that I typed that out loud, I'll expect trouble shortly .
    chris123 and dkavanagh like this.
  18. jayrodoh
    jayrodoh YimYam
    Cleveland
    Another vote for the MotoBatt MB12U here. I'm still running the one I bought in 2016. It's been through some winters without a maintainer, a major collision, major temp swings, and the bike still starts up like a champ. I know its a little (a lot now) pricier than a regular lead acid battery but I've never gotten 8+ years out of one.
    Jetfixer and chris123 like this.
  19. chris123
    Benicia, ca
    Thanks for the replies.
    I was really considering that Mighty Max, but now I think I may be better off spending a bit more (double ) for the Motobatt.
    Both the mighty max and the pirate battery that fit my bike are 12aH.
    The Motobatt is 14aH.
  20. Fuller56
    Fuller56 Well-Known Member
    I have had very good luck with AGM batteries from NAPA, not so much with MotoBatt. It was some (15?) years ago that I got a MotoBatt for my Kawasaki Concours. It lasted about a week and died with a big "SNAP" at an attempted start up. The warranty replacement was little better and died a slow, lingering death within 6 months.
    chris123 likes this.
  21. chris123
    Benicia, ca
    Interesting. Thank you.
    If you have a chance - could you post the part number f the Napa battery you bought?
    Im not sure if it’ll fit my yx600 (xj550), but it’ll be easy to check if I know which one you bought.
    My motorcycle batteries have a pretty easy life as I always usually leave them on a trickle charger. My current ctek 7002 has a specific “AGM” mode to provide the higher voltage they need to stay healthy.
  22. Fuller56
    @chris123, I don't have a clue about that part number as that XJ was sold a couple of months ago. Sorry.
    Most generally the counter guys in NAPA stores are pretty good at getting the right parts. Way better than the children who work at AA or AZ parts stores.
  23. chris123
    Benicia, ca
    Just realized that the Motobatt MB12U is 15aH.
    It’s +3aH more than any other batteries that fit my bike. I don’t know if that justifies the price but my bike turns over like a champ with this battery in it - especially after it’s been topped off with my trickle charger.
    Guess I’ll be going with another of these :)
  24. Jetfixer
    I bought my AGM battery from Batteries Plus and have another Mighty Max AGM this one is my spare , but have many spare parts never have enough.
