Fj600 85 carb choke won't stay open
Discussion in 'XJ Technical Chat' started by mark1911, Apr 2, 2021.
  1. mark1911
    mark1911 Member
    liverpool uk
    Having trouble getting her started and wondered if this could be part of the problem. The choke doesn't stay open and you have to keep yours fingers on it keeping it pulled all the way out. Remember cleaning the carbs a while back and it was working then, have i missed something putting it back together. Can't remember if there is a small ball bearing that goes on the choke pin or not? so when you pull it out it stays out.
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Hi,
    Looked at a few FJ600 pictures on the googlenet and it kinda looks like mikuni cv carbs.
    Odds are the fuel enrichment circuit cable (choke) is lacking some sort of friction at the actual lever.
    On the XJ it is held in place at that level from the lever and nothing to do with the carbs.
    Hope this helps.
    mark1911 likes this.
  3. k-moe
    There should be a wave washer in the choke lever assembly. If that is missing then it won't hold the enrichment plungers open. It's also possible that the screw that holds the assembly together is just loose (use a JIS screwdriver).
  4. mark1911
    mark1911 Member
    liverpool uk
    Thanks for the replies my mistake I have the 85 engine in the frame with the later mikuni carbs fitted with the choke lever on the left side of the carbs. Not the earlier type with the cable running from the carb to the left hand switch gear. I think your right kmoe it could be missing the wave washer we're is it mounted on the carb and we're can you get one? Included some photos of my carb.
  5. k-moe
    You can get a wave washer at any good hardware store. They are nothing special.
    I don't think that choke assembly uses one though.
  6. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    thats right , no wave washer that i know of -----bbuutt-----
    look at carbs 2 and 3 , just at the back of the pilot screw , where the choke rod goes through the carb casing, there are is a hole on the 2 and 3 carb, there underneath the rod ,is a spring and ball bearing, that locates in a dimple in the rod, its likely you lost them if you took the rod out, or at least lost the ball bearing , they are tiny, and you wont find them on any part fiche , you may still have the springs in place , maybe you can match up the balls .
    i'll see if i can find the picture of them in my cafe racer build ,some years ago.
    mark1911 and k-moe like this.
  7. bensalf
    yorkshire ,england
    and this may help others working on carbs
  8. bensalf
    yorkshire ,england
    what I found ,was that where the enrichment shaft slides through each carb, on #2 and#3 carbs, there is a tiny spring and ball ,that locates in a notch on the enrichment shaft ,to keep it in position, very lucky I found these
  9. bensalf
    yorkshire ,england
    looks like the balls are about 3mm diameter
    by the way, the 2 chromed carb hats go on the outer carbs, 1 and 4 ;)
  10. mark1911
    mark1911 Member
    liverpool uk
    Hi stu OK I'll swap em around, yeah just checked the carb now and there both missing springs and ball bearings.
  11. bensalf
    yorkshire ,england
    did you remove the rod to check, the springs and balls should be underneath the rod, thats tough if they're missing ,:mad:o_O
  12. mark1911
    mark1911 Member
    liverpool uk
    Yeah the rods out no bearings or springs. I remember cleaning the carbs 5 or 6 years ago and removed the rod and remembered a tiny bearing falling out now but never thought nothing of it, I've probably misplaced it somewhere never find it now. Only when I came to putting the bike back together last year I noticed it. Like you said there's nothing on the microfiche parts or diagrams in the Haynes that states its there or can be bought as a part number.
  13. mark1911
    mark1911 Member
    liverpool uk
    Stu further to the thread would something like this maybe work saw them on ebay. Shot in the dark I know. Screenshot_20210404_205407_com.ebay.mobile.jpg Screenshot_20210404_205137_com.ebay.mobile.jpg
  14. bensalf
    yorkshire ,england
    cant see why they would'nt work, balls seem to be about 3mm dia, and springs the same od, about 9mm long, but you can always cut them to length
    Share on Facebook - opens in a new window or tabShare on Twitter - opens in a new window or tabShare on Pinterest - opens in a new window or tab
    Click to view larger image and other views
    Move over photo to zoom
    Have one to sell?
    Sell it yourself
    Shop with confidence
    eBay Money Back Guarantee
    Get the item you ordered or your money back. Learn more- eBay Money Back Guarantee - opens in new window or tab
    Seller information
    hkdz-2017 (11806 )
    99.7% Positive Feedback
    Save this seller
    Contact seller
    Visit Shop
    See other items
    Registered as a business seller
    Small Springs Compression 304 Stainless Steel Wire Dia. 0.2mm OD 2/ 2.5/3mm
    Condition:
    New
    Wire Dia.*OD*Length:
    Pack Size:(pcs)):
    Quantity:
    More than 10 available / 206 sold
    Price:
    £2.66
    Buy it now
    Add to basket
    Watch this item
    206 sold
    sorry picture did'nt apear but something on those lines, havent got any in pieces to check sizes, but let us know how you go
