Xj 700 gear problems
Discussion in 'Hangout Lounge' started by Townzi, Mar 14, 2021.
Tags:
Xj 700 1985 first Road bike finally got her running but in first gear clicks like it's not engaging
  1. Xj700
    0 vote(s)
    0.0%
  2. Xj700
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Townzi
    Townzi New Member
    Westmidlands
    Slipping in first gear
  2. Franz
    Franz Well-Known Member
    Scotland UK.
    Is your clutch cable properly adjusted?
  3. Townzi
    Townzi New Member
    Westmidlands
    Its clicking in first as if its not engaging fully all other gears fine
  4. Franz
    Scotland UK.
  5. Max 700-X
    Max 700-X Member
    AL
    Question: Do the XJ700 & XJ700X use the same transmission?
  6. k-moe
    Yes. With the exception of some potential gear ratio changes (I can’t think of any offhand) all of the shaft driven XJs use the same transmission.
  7. Max 700-X
    Max 700-X Member
    AL
    Good info, thanks. K, do you have a recommendation where to find a new performance clutch set for these transmissions?
  8. k-moe
    @chacal
    info@xj4ever.com
