Fork bolt
Discussion in 'XJ Technical Chat' started by Ltp, May 2, 2021.
  1. Ltp
    Ltp New Member
    Houston
    So I am rebuilding the forks on my 82 XJ650 seca and I lost the hex bolt that connects the fork tube and the fork shaft. Anybody know what size bolt that is?
  2. k-moe
    Timbox likes this.
  3. Brent NZ
    Brent NZ Active Member
    Tauranga, New Zealand
    It's probably an M12 hex socket cap with 1.25 thread - around 30mm long. Len from XJ4ever will almost certainly have a replacement, you will need to replace the copper washer while you're at it.
  4. Ltp
    Ltp New Member
    Houston
    Thanks for the help, looks like it's an M10-1.0x30
    Gonna swing by a Fastenal and check to see if they've got them.
