1997 xj 600 seca 2 front fork problems
Discussion in 'XJ Technical Chat' started by MagnaXJ600, Jul 31, 2021.
  1. MagnaXJ600
    MagnaXJ600 Member
    I am having troubles with my 1997 yamaha SECA 2 XJ600 front fork suspension. When im riding it feels like a jackhammer at times. The suspension jumps up and down. I have rebuilt the forks with new fork seals and 20 weight fork oil. I have loosened everything on the triple trees and front axle and jumped up and down on it to see if that will help. The tire looked a little bit crooked. I have changed rims and tires. When I first changed the rim and tire it seemed like it helped and then it started again. I was thinking about removing the top spring spacers.
    Any ideas or suggestions?
    Thx
  2. Mechanic1978
    Mechanic1978 Active Member
    NOYB
    Most forks have bushings that are what keeps the upper tube in alignment with the lower. If these bushings are worn it will allow the upper and lower tubes to have a stutter in thier motion. giving you the so called "jackhammer" sensation.
    While Im not familiar with your peticular forks, most do have these bushings, and most are replaceable....
  3. MagnaXJ600
    MagnaXJ600 Member
    Are these the bushings on the inner tubes? The chrome portion of the shock?
  4. Mechanic1978
    NOYB
  5. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    20w fork oil is too heavy. You should use 10w.
    Simmy likes this.
  6. MagnaXJ600
    MagnaXJ600 Member
    I guess I will have to make some changes. Thx
