Secondary and Tertiary Fuel Filters
Discussion in 'XJ Technical Chat' started by Antothoro, Aug 25, 2021.
Extra Fuel Filter?
  1. No additional filter
    12.5%
  2. A secondary (Petcock + 1 Inline filter)
    75.0%
  3. A tertiary (Petcock + 2 Inline filter)
    12.5%
  4. A quaternary (Petcock + 3 Inline filter)
    0 vote(s)
    0.0%
  1. Antothoro
    Antothoro Member
    So I know that my fuel tank has junk it in. I tried to de-rust it years go. It sat open for a long time. So I figured that I would put two fuel filters in line.
    Do any of ya'll run with a secondary fuel filter?
    Do any of ya'll run with a tertiary fuel filter?
    Which filters do you use? What arrangement?
  2. Antothoro
    Antothoro Member
    months and months ago, when I was thinking about this I had this setup:
    Petcock - stock
    Secondary - paper with magnet - link
    Tertiary - right angle - link
    Now that I'm actually using the bike and have fuel going through it I'm seeing that I don't have sufficient space between the carbs and the tank for the size of the secondary one because I don't see the tertiary one filling up like I should.
  3. Timbox
    Interesting share....I have never seen or heard of a magnet filter before, interesting.
    I would go after the tank again. Will it ever stop rusting if you just let it keep going the way it is? Will you have to keep running filter and changing them out every so often? I guess it all depends on what you want to do. Just know that even those filters are letting some bits go by. If you were to open the carb bowls I would guess you would have some junk in there. I would also guess you are having the occasional sputter or pop when you are riding?
  4. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I would clean the tank and if needed line it.
    StarGeneral likes this.
  5. hogfiddles
    I use one inline filter and the four beanie-cap filters..... so— two filters
  6. XJ550H
    Clean out the tank info overload has several ways of doing it. Eliminate the source .
    As far as magnets you could mount several of those super magnets on the tank underneath and turn the whole tank into a magnet
    hogfiddles likes this.
  7. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    If they made a 90° filter with a magnet I would be all over that.
  8. XJ550H
    Add a magnet rare earth magnets to outsIde of filter.
  9. Antothoro
    Antothoro Member
    Thanks for all the input guys!
