Starting problems
Discussion in 'XJ Technical Chat' started by Jackson metcalf, Sep 27, 2021.
  1. Jackson metcalf
    Jackson metcalf New Member
    Utah
    Hey guys. Hopefully someone has an answer to my question. I have a 1983 Yamaha xj550. The bike doesn’t want to start after sitting for a few hours. If I spray a tiny bit of carb cleaner into the carbs it starts fine. If it let the bike run for 30 seconds and then turn it off it starts right back up no problem. So after the bike has ran it will start no problem for the next hour or so but if it sits for a couple hours it doesn’t want to start. The bike runs great. Maybe someone has had the same problem as me. Thanks In advance!
  2. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Are your valves in adjustment? I believe hard starts can be a symptom of out of spec valves.
    Jetfixer and Franz like this.
  3. DarinAdkins
    DarinAdkins Member
    Dallas,TX
    Not a good rider by mechanically but you should check the plug first. Clean it and start with a smooth push again if that's didn't work! find a good garage or maybe somebody else will help you out
  4. Jackson metcalf
    Utah
    I’ll definatly do some checking there. That’s kinda what my dad was thinking. Thank you!
