Dielectric or not?
Discussion in 'XJ Technical Chat' started by Carl LaFong, Nov 22, 2021.
  1. Carl LaFong
    Carl LaFong Member
    ontario
    Doing end of season jobs. Considering pulling apart all electrical connections I can find and greasing them. Bike runs fine with no electrical issues. But it's 40 years old. Grease or not?
    Or leave well enough alone, if it ain't broke don't fix it?
    Anyone go down this road, how did it go?
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    As I always say 'if an't broke didn't fix it '. If you take a connection apart for repair then I would apply some dielectric grease then. The grease dose not improve electrical contact but stops moisture getting into the connection. Dielectric grease is not conductive.
  3. Carl LaFong
    Carl LaFong Member
    ontario
    So after 40 years corrosion would not be occurring in All connections? Just don't want to be stuck on side of the road if a little preventative would help.
    Sounds like a bit of a gamble but so is riding.
  4. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Depends on how the bike has been used/stored over the years.
    My bike is one owner, and has never been stored outside, driven every season. So far, no issues with electrical connections (except for the self-destructing fuse box, which has been replaced).
  5. XJ550H
    grease connectors when you have to disconnect them. some you want to clean when you get the bike
    chacal sells both styles of electrical grease
  6. Carl LaFong
    Carl LaFong Member
    ontario
    Going to swap out the ignition module to test a used one I just bought. Also got complete motor with carbs starter and alt had 9000km on it. Got lucky!
  7. lostboy
    Use the dielectric grease sparingly. This is not when "bigger the glob the better the job" comes in.
    Timbox likes this.
