New to me bike - List of what to replace / check - What am I missing?
Discussion in 'XJ Technical Chat' started by noah scott, Apr 21, 2022.
  1. noah scott
    noah scott Member
    McMinnville, Oregon
    So I bought a project bike... started making a spreadsheet of what I need to purchase / check and feel like i'm potentially missing things.
    This is strictly a list to make it safe / reliable to ride - not worried about cosmetic at this point (rusted bolts/tank paint, etc)
    Need to check / do
    • Valve clearances
    • Rear brakes (PO who had this bike as a project just did them, everything looks clean but i'm going to take it apart and check)
    • Front Brakes
    • Compression test
    • clean and lube switches
    Already Bought
    • Complete gasket set (tend to do this with my projects, so i have gaskets at the ready)
    • Valve cover donuts
    • Positive battery cable (terrible looking)
    • oil / oil filter change
    • speedometer cable (missing)
    • Petcock
    • Clutch lever (the one on the bike was from a dirt bike)
    • misc items like silicone lube, gasket tack, etc
    • Cable Lube and tool
    Already checked/done
    • Throttle cable (within spec/need lube)
    • Clutch cable (within spec/need lube)
    • Choke cable (within spec/need lube)
    • Plug wires within OHM
    • Fuel tank (no rust)
    • Lights functional (sans one light that is broken)
    • Clutch adjusted
    • Exhaust dent repaired (Cyl 1 was crushed from what looks to be a highside, sliced and banged it back to a circle and welded back up)
    To Buy List
    - FORKS
    • Fork rebuild kit 129.95 HCP20617
    • Aftermarket DAMPER ROD RETAINING TOOL. 29.95 HCP4402
    - Front Brakes
    • Brake line - MC to Dist > brake line 54.95 HCP2877RU
    • Brake line - Dis to Left Caliper 59.95 HCP2879RU
    • Brake line - Dis to Right Caliper 59.95 HCP2878RU
    • Basic master cylinder rebuild kit 49.95 HCP1696
    • Brake Caliper Seals Kit 59.95 HCP21233SET2
    - Fueling
    • Rebuild Kit 264.95 HCP18721
    • Colortune Plug 119.95 HCP95C
    • YICS tool 59.95 HCP5460
    • Carb dip (1gal) 20
    • Carbtune 4 pro 139.95
    • JIS screwdriver set 14.9
    • Ultrasonic Cleaner 63.99
      • OR murrayscarbs.com (i have one of his carbs on my other bike and love it) - a little worried about future obtainability of parts like diaphragms on the old carbs. I know about this - http://jbmindustries.com/HITACHI.html, but still worrysome.
    • Spark plugs
    • Fuel line
    - Misc
    • Front driver turn signal
    • Clean EVERYTHING
    • change oil in the rear drive
    - Final
    • Tires 150ish (no reason to get tires until it's time to ride, current ones are dry rotted and thrashed and about 6 years old)
    • Battery 60ish - have a battery for it now, but it's probably 3 years old at this point from my old bike.
    • Registration 100ish
    i'd also at some point would like a less HUGE seat...
  2. noah scott
    noah scott Member
    McMinnville, Oregon
    well hot damn - Thanks fitz!
    https://www.xjbikes.com/forums/thre...r-as-much-info-as-possible.36362/#post-317101
  3. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    One other comment. Make sure you completely tear down the carbs, meaning break the rack, for total meticulous cleaning. That also means you might need to replace the throttle shaft(s) seals.
  4. noah scott
    noah scott Member
    McMinnville, Oregon
    Yup! totally doing that - full rebuild kit is up there :)
  5. XJ550H
    dont waste your money on the yics block off tool you wont notice the difference in the tuning.
    when you change the gear lube in the rear acorn remove the fill plug first very important.
    if you drain it first and then cant get the fill plug off you will not be able to refill it
  6. noah scott
    noah scott Member
    McMinnville, Oregon
    Well I would be that guy... truth be told could still fill it up... if you turn the bike upside down! badumpshhhhhhhhhhhhh...........
    i've heard it both ways with the YICS block off, but thr majority leaning toward not, think i will leave it out
  7. XJ550H
    the tool is just for tuning and not ment to be left in. there are little holes in the passage that need to be cleaned .
  8. noah scott
    noah scott Member
    McMinnville, Oregon
    Oh sorry, i meant leave it out of my "to buy" list - should have been more specific
