Foot peg rubbers
Discussion in 'XJ Technical Chat' started by Oatmeal, May 8, 2022.
  1. Oatmeal
    Oatmeal New Member
    Cedar City, Utah
    Okay, not really a "technical" question more of a "how to", but I have new aftermarket replacement rubbers for my 650 Seca.
    Haven't taken a really good look at them yet as I bought them a couple years ago along with a whole slew of parts to bring my bike back to life, it's been mothballed for about 23 yrs.
    How are the rubbers secured to the metal part of the pegs?
    I remember (don't have them in front of me to look at) there being a couple of holes on the bottom of the metal insert molded into the rubber.
    Drill those out and slide them off then, plug weld the new ones in place?
    Searched all over the internet no luck.
    Hans
  2. Brent NZ
    Brent NZ Active Member
    Tauranga, New Zealand
    Remove the split pin & then withdraw the large retaining pin, this will separate the foot peg from the holder. Then pull the rubber off the internal steel shaft.
  3. Oatmeal
    Oatmeal New Member
    Cedar City, Utah
    Just looked at those pics, those are the passenger pegs, I was asking about the rider's
    (operator's) pegs, but thank you.
    Hans
  4. Brent NZ
    They should have the same split-pin connection
  5. Oatmeal
    Oatmeal New Member
    Cedar City, Utah
    Quite a bit different
  6. chacal
    To get the old ones off: slit the rubber along the somewhere along the long axis with a razor knife, etc.
    To put the new ones old: use some silicone lube or dish soap, etc. on the shaft or on the inside of the rubber pads, and pound them on. They are retained by friction.
  7. Oatmeal
    Oatmeal New Member
    Cedar City, Utah
    Wow,
    That's it?
    You'd think a guy could find some info on YouTube or something, I mean they sell them all over the internet..., but not one write up!
    Thank you!
    Hans
    PS
    How does one go about ordering parts from you guys?
    Your catalog is very thorough, but hard to navigate.
  8. chacal
    Just send us an e-mail at: info@xj4ever.com or use the "Start a Conversations" feature on this website (click on my user name in my post, IOW the word "chacal").
  9. Oatmeal
    Oatmeal New Member
    Cedar City, Utah
    Thank you,
    Sent an email
    Hans
  10. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    I've drawn red arrows to the folded lip which holds the rubbers on.
  11. XJ550H
    handle bar grips are the same way for instalation friction holds them in place and soap gets them on.
  12. Oatmeal
    Oatmeal New Member
    Cedar City, Utah
    Ah,
    Makes sense now.
    Should I use any kind of adhesive, like hair spray or something?
    Hans
  13. Simmy
    I've just pushed them on until that angled lip on the retaining plate is seated into it's groove.
    You can push them on but you can't pull them off, as you've found out.
  14. Oatmeal
    Oatmeal New Member
    Cedar City, Utah
    Excellent, thanks!
    Hans
