The search continues... XJ550 Maxim seat
Discussion in 'For Sale, Trade/Swap, Wanted' started by Jason Piccolo, Apr 8, 2022.
  1. Jason Piccolo
    Jason Piccolo Member
    Savannah, GA
    Greetings fellow part-seeker/sellers!
    I'm inching closer and closer to getting this 1981 XJ550 Maxim on the ROAD...Most likely jinxing it by typing that.
    In need of a good SEAT option for the old girl; my wrinkle is this
    some dumb dumb 'modified' the bar that the seat assembly uses to attach.
    Pictured here is NOT my frame, but I'm using it to explain the part that's gone. They've cut it right off. So, i'm pretty sure ANY seat that can be afixed to the frame would work, just don't know what or how to do so? Current 'seat' that came with the bike is a padded wad on a shit wooden plank
    Any tips?
  2. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    I have a seat from a 82 XJ650. Would that work? I have some photos you can look at.
  3. Jason Piccolo
    Savannah, GA
    Looks good. can you shoot a profile of the seat?
    and what would you want for it? where in the world are you?
  4. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    I also have the rear part of the frame.
    Hi, Jason,
    I can send a profile shot this Saturday. I live in Manassas, Virginia, USA. Make me an offer and if it's reasonable, you can have it.
    Gary
  5. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    Hey, Jason,
    Just to be clear, the pictures I already uploaded don't give you the needed perspective, correct?
    Gary
  6. Jason Piccolo
    Savannah, GA
    that is correct. i'd love to see the seat from the side, laid flat.
  7. Jason Piccolo
    Savannah, GA
    so this frame is off of what year/model bike? it's looks super close to my XJ550 Maxim frame, but the previous owners butchered it a bit so i don't know what it's supposed to look like. just have evidence from online pictures.
  8. XJ550H
    have you considered mounting a bar to replacate the missing part? ti is used to mount the rubber straps inside the chain box that hold the stock seat.
    front of the seat has a tang that slips under the gas tank mount.
    if you want a flat seat the seca 550 seat will work and you could add the hindge and lock to the frame.
    I have used broom clips to hold a seca seat to a maxim frame. the clips you put on a wall to hold broom.
    I will look at how a 650 seat fits on mt maxim 550 over the week end and get you a photo the 650 seat has a latching mechinisim at the rear .
    you would have to do some welding to atach brackets for that as well.
    do you have a 550 maxim seat?
  9. XJ550H
    that is a 650 frame he posted a photo the frame is same for all 4 years you would need to add the pracket and pins for a 650 latch setup
  10. Jason Piccolo
    Savannah, GA
    I do NOT have a seat…i have a makeshift bs board with a pad on it that the previous Dr. Frankenstein used… they chopped the bar (i assume) to accommodate this ‘luxury item’
  11. XJ550H
    wow thats quite a seat.
    you will need to add that bracket or a cross support back to the frame as it is more that a seat mount it keeps the frame from moving.
    there are enough people bobing the 550 maxim you should be able to get someone to give you the part of the frame they cut off with the bracket then weld the bracket back on.
    Simmy likes this.
  12. XJ550H
    just tried a 650 seat on the 550. the front of the tank interfears with the front hook due to seat hitting tank. seat could be modified to slide in
    the seat fits with the grab bar in place but the bracket that was removed would hold rear of seat a little high due to its shape.
    photo to follow
  13. XJ550H
    oem bracket bracket.jpg 650 seat interfeared with by wing on bracket and chain box on.jpg 650 seat seat.jpg 650 seat on.jpg 550 seat oem seat.jpg
  14. Jason Piccolo
    Savannah, GA
    nice. that bracket looks DRASTICALLY different than the ones i've gotten images of (mine was chopped obvi)
    my preference is to get a more cafe racer style seat, and i've seen stock seats (like the one Gary Potter posted above)
    this bracket looks super tall.
  15. XJ550H
    I put the 650 seat on another 550 frame I had it fit well without the chain box and grab bar.
    the wing on the bracket interfears with the seat sitting flush.
    the front tang on 650 seat does not slide under fuel tank due to shape of front of seat but could be made to fit.
    if you were to get the 650 bracket and weld that on the frame and mod the front of seat a little the 650 seat would work well
  16. XJ550H
    for a CAFE STYLE SEAT USE A SECA 550 SEAT
    I will do a photo of the seca seat on a 550 for you as well.
    I have posted that setup here before with a seca tank and seca seat on a maxim
  17. XJ550H
    I think the frame photos you posted are seca frame setup
  18. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    It's off an 82 xj650 Maxim.
  19. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    I will try and get that to you today.
  20. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    Here is the profile of the seat. I have included the part of the frame that it sits on. There is also a "grab bar" that goes together with it.
    Gary
  21. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    The frame is off of an 82 XJ650 Maxim. See my other post below.
  22. Noahsxj
    Noahsxj Active Member
    SW Missouri
    I have a full nicely upholstered xj550 maxim seat I would sell you cheap
    650 seat is much different and sits awkward on a 550 frame
    Jason Piccolo likes this.
  23. Jason Piccolo
    Savannah, GA
    You guys are killing me with the generosity of knowledge. Thanks all around. This stuff is super educational and helpful.
  24. Jason Piccolo
    Savannah, GA
    Love to see it.
  25. XJ550H
    if you go with the 650 set up you only need the bracket section of the 650 frame. that would save you some shipping
  26. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    The frame section is off of an 82 XJ650 Maxim
  27. Noahsxj
    SW Missouri
  28. Jason Piccolo
    Savannah, GA
    What’re you askin for it?
  29. Jason Piccolo
    Savannah, GA
    so i don't know if it's because i don't have a 'pro account' but no one is replying to my messages about their available seats AND i can't make NEW posts...
    i'm sure I don't have the proper pay grade privileges.
  30. XJ550H
    premium Membership is as high as you get for accounts.
    to start your own post pick a room such as
    then click
    give it a title such as xj550 maxim looking for seat
    you can go to
    Test Zone
    in test zone you will see
    what's this forum for?
    if you want to contact a member with a privet conversation click on their avatar then click
    start a conversation
    then make a title and your question or comment
    to practice and ask how to about posting
  31. XJ550H
    so if you click on Noahsxj avatar
    then start a conversation about his seat and price
  32. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    I have the xj650 seat you can have. Let me know.
    Gary
  33. Jason Piccolo
    Savannah, GA
    I really appreciate that. Just don’t know that it’ll work with my canibalized frame. How much do you want for it friend?
  34. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    Make me an offer. If it's reasonable, you can have it. I also have the frame section it connects to. You could weld it onto your existing frame. I had sent you some pictures not too long ago. Look and see if that would work. Let me know. Gary
  35. Jason Piccolo
    Savannah, GA
    I don’t even have an idea for what’s fair for that seat and the frame…
  36. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    How does $50 plus shipping sound? Send me your address and I will find out how much it will cost to ship.
  37. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    By the way, what happened to that seat for the 550?
  38. Jason Piccolo
    Savannah, GA
    Bought it without knowledge of anything. Seat was never on it. Eventually realized they hacked the frame apart.
    5406 Waters Drive
    Savannah GA 31406
  39. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    I meant the seat for a 550 someone offered you on this thread earlier on. Did that fall through?
  40. Jason Piccolo
    Savannah, GA
    They didn’t reply
  41. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    Would you like to try using my seat and frame?
  42. Jason Piccolo
    Savannah, GA
    Noahsxj; drop me a line clermonthound@gmail.com
  43. Ryder Magnuson
    Ryder Magnuson New Member
    United States
    I have a decent 81 XJ550 Maxim seat if you want something that for sure will fit, at least on the front. I'll do $40 plus shipping for it. Let me know.
  44. Jason Piccolo
    Savannah, GA
    awesome! have any pics of it? you can drop me a line at: jason.piccolo@gmail.com
  45. Ryder Magnuson
    United States
    I am away from my shop at the moment but later today I will have some photos for you!
  46. Jason Piccolo
    Savannah, GA
    Many thanks!
  47. Ryder Magnuson
    United States
    Hey I just sent you an email with photos of the seat.
