xj750j dies
Discussion in 'Test Zone' started by maxim xjj, Jun 8, 2022.
  1. maxim xjj
    maxim xjj New Member
    Billings, Montana
    Hello to every one & I know you can tell me what is wrong with my 1982 Yamaha XJ750J bike. When I am going slow & I hit a bump a the engine dies but will restart in a minor flooded condition then start to run full throttle & one more is when I let off the throttle to come to a stop it dies. I have to rev the engine to keep it from dying & will idle normal waiting for the light to change
  2. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
    sounds like.. I could be wrong.. the bump jolts one of the plastic floats up.. sticks to carb body, and doesn't close. flooding. remedy is to straighten float assembly.
  3. k-moe
    Maybe.
    Keep in mind that setting up floats takes a bit more than bending things...you got to bend them exactly.
    @maxim xjj
    How long have you had the machine, and what do you know about its history (prior owners, maintainance, etc.)?
  4. McTavish
    Daytona Beach, Fla.
    yes.. I blame the P.O. in two of my carbs, the assemblies were twisted, causing floats to stick.
    as in priming the empty bowls, then overflow. tapping the bowl stops flow.--that kind of sticking.
    it did take alot of trial and error to eyeball it.
  5. k-moe
    When you get time this winter, go back in and make sure it's all set correctly. The fuel levels have to be pretty-much spot-on to ensure proper running at all engine speeds.
    Setting the fuel levels
  6. maxim xjj
    Billings, Montana
    I have only owned the bike for about 2 weeks I found boots without clamps, some with cracks, and vacuum lines off I am not sure where all go I've changed the oil, final drive oil & have put clamps on & bike runs better but still dies starts back up anyway to unstick the floats without tear down p.s. put vacuum line on the petcock idles better
  7. maxim xjj
    Billings, Montana
  8. maxim xjj
    Billings, Montana
    Thank you I am so-so with 2-stroke carbs on small engines & my dirt bike but this bike with 4 carbs gives me the is a different adventure so I came to the best for help
  9. Franz
    Franz Well-Known Member
    Scotland UK.
    With a cold engine start the bike and spray engine start or carburettor cleaner around the intake boots. If the cracks are right through the engine will rev without you touching the throttle. If the boots are cracked you can repair some damage with RVT l believe but if you need to replace them be careful as the intake stub bolts can shear off. You will need to remove the carbs to set float heights. Get a Haynes manual, check valve clearances before carburettor work. If the carburettors need synchronised valve clearances must be in spec to get this right.
  10. Franz
    Scotland UK.
  11. McTavish
    Daytona Beach, Fla.
    what is winter ?
    Timbox likes this.
  12. k-moe
    When it freezes. I know that it's not something you have often, but it does happen there.
    But you bring up a good point. In your case it'd be better to work on her during monsoon season.
  13. k-moe
    OK.
    Start here and do a lot of reading.
    The Information Overload Hour
    It sounds like the PO didn't keep up on maintaince, which is common.
    Unfortunately you will need to remove the carbs to check the condition of the float levels, and to make sure that the carbs are clean, but hold off on that until we do some more diagnosis.
    I'd reccomend checking the valve clearance. It's really common that people don't ever bother to check clearances, let alone change shims when needed.
    Bigfitz's AIRHEAD VALVE ADJUSTMENT with Pics - parts I & II
    If the valve clearances aren't in spec then she'll never run right, no matter how much work you do to the carbs.
  14. McTavish
    Daytona Beach, Fla.
    oh ... 3pm you mean .
    k-moe and Timbox like this.
  15. Timbox
    McTavish, I remember living in area that I could ride all yr round. It is great but then when the bike has to go down for service, it sucks. Or does it? That just means you need another backup bike when one is down being serviced.
  16. maxim xjj
    Billings, Montana
    hey guys thank you for the advice I order new boots and let you know how that works out but now another problem on the left grip is a what I say is the choked cable that was stuck, I think, I went down to carb & push the plunger into the carbs & now it wont idle, run right & those plungers dont move with the cable at all
  17. maxim xjj
    Billings, Montana
    Thank you I will do that next question How do you adjust choke cables properly
