sudden electrical short please help
Discussion in 'XJ Technical Chat' started by joejr2, Aug 10, 2022.
  1. joejr2
    Santa Fe,NM
    I have an 82 xj650 maxim. It has been sitting for a while. everything was fine when parked. I tried to start it
    a couple of days ago. Turned the key, neutral light went on, horn was faint. Pressed starter button and the starter sputtered with not enough juice to spin the motor. So I put my battery charger on it set to 10 amp
    quick charge and left it for a couple of hours. When I tried to start it I got nothing, no horn, no neutral light
    and whenever the key was turned the signal fuse would blow. I figure the battery was toast so I replaced it.
    turned the key and signal fuse blew again. Not being able to find short glass fuses in my area, I replaced the
    fuse block with a small after market fuse block taking auto fuses. Got everything together and the same thing,
    the signal fuse blew. Can anyone suggest circuits or relays to start testing ? Could the 10 amp charger have melted or shoted something ?
  2. k-moe
    I would open up the headlight bucket and look for evidence of critters chewing on wires.
  3. joejr2
    Santa Fe,NM
    no critters in my garage
  4. Franz
    Franz Well-Known Member
    Scotland UK.
    Check if you have any damaged wiring touching the frame, and corrosion on harness wiring in electrical plug connectors.
  5. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    many years ago I had a girlfriend riding an FJ600.
    The bike kept blowing fuses, always good in the garage but always reoccurring when out riding.
    The wiring harness was worn where it rubs on the steering neck.
  6. Franz
    Scotland UK.
    Same thing happened with my Suzuki GT 250.
  7. joejr2
    Santa Fe,NM
    Great suggestions, I couldn't figure why I don't get horn and neutral light when the key is turned on and why the signal fuse also blows
    when the key is turned. Could that be happening because a wire in the signal lighting system is grounded ? I was thinking of just stripping the harness, fastening it
    to a sheet of cardboard, first look for damage then check each circuit for continuity and resistance. also check all the relays. Funny though because neutral light
    and horn worked at first but the battery was too weak for the starter to turn the engine over, so I hooked the charger to it at 10 amps for a couple of hours. thats when
    something fused or melted.
  8. Franz
    Scotland UK.
    Check the wires from the components that are not working. I always start at the components that are not getting power and check the wiring connections for corrosion causing high resistance all the way back. Follow the wiring diagram and check each connection with a multimeter. You can also pinpoint physical damage that way where a wires insulation may be damaged and the wire is shorting onto the frame etc.
    Check the wires at the signal mounts where the units bolt to the frame. You don't need to strip the harness chances are the problem is not in the main harness which is taped up from the factory because those wires are better protected. Check also the indicator bulb holders for any signs of corrosion.
  9. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    You didn't charge the battery the wrong way did you? It is possible, and would fit in with your symptoms. Get a dvm across it.
  10. joejr2
    Santa Fe,NM
    I may have hooked it up to the charger at 10 amps with the key on. I think I may have fried something. any Idea what devices may have been damaged ? I have lots of extra parts.
  11. Rooster53
    North, FL
  12. Minimutly
    West Wales, uk
    Do you have a wiring diagram for it? If not get one. Then start by disconnecting various items, as many as you can and then switch on. One by one start connecting stuff back in.
    Franz likes this.
  13. joejr2
    Santa Fe,NM
    Yes I do,I'm working on two bikes now. An 82 maxim (blowing the signal fuse) and an 82 seca which has horn,neutral light and signals when the key is turned but no starter button. thats why I was
    testing the relays. I bypassed the cutoff relay by jumping the two red/white wires at the relay terminal. the button now spun the starter, I checked for spark, had spark, so I fed fuel to the carbs via
    aux. bottle, applied the enrichment,. pushed the start button and it ran for ten seconds and then died. No start button again even with the red/whit wires jumped .
