XJ550 (re)build
Discussion in 'XJ Modifications' started by Lodewijk, Apr 20, 2019.
  1. a100man
    a100man Well-Known Member
    Bedford, UK
    Oh well, not to worry - from what I can tell the bores survived 'the intruder.'
  2. Lodewijk
    Lodewijk Member
    Oudenburg, Belgium
    Yesterday, I took the afternoon off to work on my bike. Weather was good, and that reminded me I have an unfinished bike in my shed. I've been slacking a bit lately with the family and vacation and stuff ... Got a few things done, so feeling a bit better about myself again.
    A mechanic friend supplied me with some noxious stuff to soak my cylinder head in. Hopefully now I'll get all the goo and grime off. At first glance it's also stripping the black paint off the PO put on the engine block, so it's doing something at least (lol). I also managed to get the engine block out of the frame. PO welded some kind of panel in there, and that's going to be in the way for the airbox. Now I can decently get at it with grinder.
    I also got the cylinder block of the crankcase/engine.
    Is this discoloration of the cylinder heads normal?
    The Clymer manual said to check for variance and play in the piston rods (other than the normal, rotating motion). I'm able to rock all piston rods left to right about a milimeter; is this normal wear?
    The oil pan has some sludge in it, but less than I was expecting. Also, no metal or other particles so that's good. Not planning to split or open the crankcase if I can help it.
  3. Franz
    Franz Well-Known Member
    Scotland UK.
    As you have the bike dismantled to this extent it would be a good idea to replace any potential problem parts in the crankcase. It may save you a lot of work later.
    Lodewijk likes this.
  4. Lodewijk
    Lodewijk Member
    Oudenburg, Belgium
    That's sound reasoning. I hate to sound like the noob that I am, but any pointers to what to check?
  5. Franz
    Scotland UK.
  6. a100man
    Bedford, UK
    Pfff. Really? A 'may save' isn't enough for me. Top end rebuild is usually enough on these motors isn't it? The shaft version have there own set issues though I understand. Like most of us the guy is struggling to find time to do the basics and then there the carbs to set-up, brakes to reburb etc..yet...
  7. Lodewijk
    Lodewijk Member
    Oudenburg, Belgium
    Continued the good work today, by starting to clean the engine block. Had to stop because it started to rain (doing it outdoors so I don't trip on the fumes).
    Are these supposed to come out? Because they're stuck in there good, and if I have to use pliers, I'll score them.
  8. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    Don't bother with those, they look fine, just replace the O-rings and the head gasket as well as the big cylinder o-rings.
    Lodewijk and Franz like this.
  9. Polock
    go ahead and open up the bottom, there's all sorts of fun stuff in there
  10. PavelK313
    PavelK313 Active Member
    Fairfield CA
    Wiha and Knipex tools... I like your style! ;)
  11. Lodewijk
    Lodewijk Member
    Oudenburg, Belgium
    Like the dark side, eh? ;-)
    Someone noticed! :D I'm lucky that my job sells all kind of tools and equipment, so not only do I get everything on the cheap (or as cheap a good tools cost), I also get a bunch of really handy co-workers. And they don't mind explaining stuff to their resident IT-jockey ...
    PavelK313 likes this.
  12. PavelK313
    Fairfield CA
    I couldn’t possibly miss that. I am a tool snob, my tool box at home with hand tools contains mainly Hazet, Knipex, Wera, NWS, Snap-On, Witte, Wiha.
    Franz and Lodewijk like this.
  13. a100man
    Bedford, UK
    Personally I'm a big fan of UK brand 'King Dick' - although principally for the amusing connotation.
  14. Lodewijk
    Lodewijk Member
    Oudenburg, Belgium
    Tbh, I'd buy those for the brand name alone ... "Son, please hand me my King Dick 10mm wrench." The Dad Joke potential is almost endless!
  15. spacetiger110
    spacetiger110 Member
    Pennsylvania
    Are you planning on replacing the rear fender as well?
  16. Enrico
    Enrico New Member
    Gorizia - Italy
    I'm looking for a similar front fender. Anyone can tell me where i can find it?
  17. spacetiger110
    Pennsylvania
    Lol. I'm looking for the rear. And maybe the seat.
  18. Enrico
    Enrico New Member
    Gorizia - Italy
    nobody can help me?
  19. Ryengoth
    Wilmington, NC
    maybe eBay or xj4ever.com
  20. XJ550H
    what bike are you looking for a fender for. you should post this in the wanted section
  21. Enrico
    Enrico New Member
    Gorizia - Italy
    I have an Xj 550 from 1982, i looking the same front fender
  22. a100man
    Bedford, UK
  23. Franz
    Scotland UK.
  24. XJ550H
    XJ550 euro or xj550 seca or xj550 maxim
    XJ650 Seca fender will also fit XJ550 euro or xj550 seca
  25. Lodewijk
    Lodewijk Member
    Oudenburg, Belgium
    3 years since I posted here, and 3 years since I really worked on my XJ. For shame! :(
    Got kind of disheartened when I noticed the PO had butchered the frame as much as he did the rest of the bike. Made it hard to figure out discrepancies when something didn't fit immediatly. Ordered a secondhand frame from ebay but never even took it out of the box. Felt slightly guilty every time I saw it standing in my shed, though. However, I have some time now and started working on it again! Took the second frame out of the box, fixed the rust and give it a once over with black primer so it's protected. Started changing over the front and rear assemblies; found some missing bolts and washers and ordered those. Some bolts are barely finger thight. Also found out that the butchered frame has tapered bearings and the new one has the old ball bearings, so had to stop work to look into that. Figured it out thanks to the forums; ordered the correct bearings. Now I can look forward to getting the old race bearings out, yay me.
  26. Lodewijk
    Lodewijk Member
    Oudenburg, Belgium
    Really late reply, but my go-to sites for my 1981 XJ550 4V8 in Europe are:
    - ebay (for secondhand parts, bought an airbox, saddle, fuel tank and frame off there)
    - cmsnl (for new hardware)
    - wrecker sites that specialize in this kind of stuff like https://www.boonstraparts.com/nl/onderdelen/mke=yamaha/mdl=xj+550+1981+1982+4v8, https://www.motorparts-online.com/nl/yamaha/xj-550/1981-1984?page=1. There are others, too.
    - sites catering to older bikes like https://japparts.nl/index.php?main_page=index&cPath=79_90_106_540&language=nl&sort=20a&page=1 or https://www.sparks-online.eu/onderdelen/yamaha/xj550/1981
  27. Oblivion
    Oblivion Active Member
    Northeast Illinois
    I know the feeling. I got a few more kids, blinked, and ELEVEN years went by. But over the past month, I got back up and running. You’ll get there too. Slow and steady. Just not three-year slow. :)
  28. Lodewijk
    Lodewijk Member
    Oudenburg, Belgium
    High five, fellow XJ-slacker! Slow and steady sounds good to me; up until now I have just the slow part covered. But yes, we'll get there eventually! :D
    Oblivion likes this.
  29. a100man
    Bedford, UK
    Welcome back.. I just read some of my posts and forgotten I'd written them.
  30. Oblivion
    Northeast Illinois
    I love that. I was recently looking through my old maintenance notes and saw that at some point I removed my fairing and had the bracket rewelded. When TF? LOL. I swear, I don't drink that much.
    a100man likes this.
  31. Shaazaam
    Shaazaam New Member
    Pa
    Good thread for me to stumble on, thank you for documenting so much. I have an 82 550 Seca in basically the same condition. PO's completely butchered everything on it. From what I can tell the only stock items left are the engine, fenders, forks, and maybe the frame.
    Got it years ago and ran like crap, finally have the space and tools to fix it all. Nice tips on the mid RPM bog down, thought it could have been misfires, improper jetting, or crude in the fuel system, but guess kind of air filters it has :rolleyes:
    Simmy likes this.
