Oil level concern
Discussion in 'XJ Technical Chat' started by Mxtlplck, Sep 26, 2022.
  1. Mxtlplck
    Mxtlplck New Member
    Kansas
    Hello again. She runs!! Cleaned the carbs good, checked seals, cleaned air filter, changed petcock, fired up immediately. Idles no problem, sounds good.
    I changed the oil, 10w-40, filled to the top of the sight glass. Filled the filter before installing. No leaks after 2 weeks. Before starting for the first time, I noticed the oil dropped to about the middle of the glass. I topped it off, and it went back up. Fired up, ran about 8 minutes, rejoiced because my clumsy ass actually made something work, and then I noticed the oil was back to the middle of the glass. I’m really hoping this is normal. Not leaking anywhere I can see, I looked hard. Carbs didn’t have oil residue and exhaust smoke isn’t white/blue/black etc. Am I going crazy, or is this abnormal? TIA
  2. Franz
    Franz Well-Known Member
    Scotland UK.
    Oil heads for the bottom of the oil pan and is pumped around the engine when running. So when engine is off the level goes up a little.
  3. Jetfixer
    Take a deep breath your oil level should have a slight bubble at top of sight gauge , you don't want to over fill oil .
    k-moe, Franz and Mxtlplck like this.
