What is CORRECT float height
Discussion in 'XJ Technical Chat' started by MrSeca, Dec 4, 2020.
  1. Polock
    you should also check the tide charts for your area and never set during low tide
    jayrodoh, MrSeca and Dave in Ireland like this.
  2. MrSeca
    MrSeca Active Member
    Oakland, CA
    LOL
  3. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    This is a really useful, informative thread, well done contributors all.
    MrSeca and k-moe like this.
  4. k-moe
    Teacher hat on:
    Most people learn and communicate in a similar way, but not everyone does. Asking for clarity is not wrong, but it can indeed be frustrating when we assume that we have already communicated clearly to begin with. Put aside the assumptions and clarify (as several here have) even when it's frustrating to do so. I'm not innocent of assuming that the learner communicates and thinks in the same way that I do. This thread is an example of humility and perseverance as applied to problem-solving. Well done.
    kosel, jayrodoh and MrSeca like this.
  5. MrSeca
    Oakland, CA
    As a teacher in the profession myself I have to more often then not create ways to get my student to understand something. I often take for granted the knowledge I have learned and cultivated over the years and expect a student to understand it instantly forgetting the journey I once took to figure something out. In this case I am still the humble student and I am the type of guy to ask the same question probably 3 different times in 4 different ways. But I don't give up and I am always grateful to the people who don't give up on me as well. Thank you everyone. Now time to rebuild some carbs.
  6. hogfiddles
    That’s what we’ve been saying all along:D:D:D;););)
    jayrodoh, MrSeca and k-moe like this.
  7. RoadsScholar
    RoadsScholar New Member
    USA
    What is correct BS30 float bowl volume when drained?
  8. hogfiddles
    What bike?
  9. RoadsScholar
    USA
    Any bike that takes a BS30. Mine is a Yamaha Turbo.
  10. jayrodoh
    jayrodoh YimYam Premium Member
    Cleveland
    The fuel level can vary based on the application. I don't think I've ever seen the volume measured anywhere. From the archive:
    Mikuni BS30 (all XJ650 Turbo): -Fuel level measured via the clear-tube gauge: 2mm +/- 1mm (.08 +/- .04 inches) -Float height: 17.5 +/- 0.5mm
  11. hogfiddles
    But, the cheat sheet says—
  12. jayrodoh
    Cleveland
    Rub roh raggy, I got that from the PDF linked in the thread you got that from.
    Stick with the fuel level method and you’ll be okay, I think it’s a better way to set it anyway.
  13. hogfiddles
    That’s right off the cheat sheet.
  14. jayrodoh
    Cleveland
    Yah I see that, the PDF and the fuel system thread have different specs:
    4538F788-C557-480B-A2F7-2419B367EA9D.jpeg FB5FBE27-5A0F-4C45-94E9-A004A04456FC.jpeg
  15. hogfiddles
    Hmmmmm
  16. Fuller56
    Fuller56 Well-Known Member
    Dave, Remember when you and Len were discussing my Turbo carbs and discovered the error in one of the references you were using? I don't know which one was correct though. I eventually wet set mine and did not measure the float height after.
    John
  17. hogfiddles
    I remember, and figured you’d pipe up here
  18. jayrodoh
    Cleveland
    @Simmy
    or just wet set and be done
    hogfiddles likes this.
  19. Neil Doughty
    Neil Doughty New Member
    kansas
    just rebuilt 4 HSC 32's. the new float needles and seats are much shorter than the ones i replaced. the 17.5 mm dry float levels DO NOT WORK, however, it appears that if your fuel levels were properly set before you replace these, they will still be in the ball park. the parts i was able to get are K&L 10L-14390-02 (18-8937). i don't know what these were set when i dismantled them, they do appear to have been near the 17.5mm (11/16") dry levels.
    i guarantee you that if you try to achieve the 'dry' level of 17.5mm, you WILL have problems.
  20. hogfiddles
    If the fuel valves are that different, then I’d question if you have the right fuel valves
