rpm's at 55 mph speedo wrong 1982 XJ750
Discussion in 'XJ Technical Chat' started by Andy_1602, Feb 22, 2008.
  1. Andy_1602
    Andy_1602 New Member
    Shelbyville, KY
    Can any body tell me about what should be RPM's at 55 or 60. Mine at 5000 rpm is reading 45 mph and I know that is wrong in 5th gear feels more like 65 or 70. I need to check cables and speedo gear to make sure it is good. Thanks
    Andy
  2. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    Andy,
    What bike? The gear ration in 4th gear for the 750 seca is like 9.9xx to 1
    *EDIT* I "think" at 5k rpms in 5th should be ~70mph (flat surface). Dont quote me on that though.
    "Yes officer, Ass.Fault told me that I would only be going THIS fast at this Rpm. Dont write me a ticket!!!" :lol:
  3. Pacocase
    Pacocase Member
    MD
    According to my GPS, my speedo is always about 5-7 mph slow. At 70, which is really 75, I'm doing around 5.5k
  4. TIMEtoRIDE
    another thread said that spiders crawl around inside the gauges, leaving web as they go, interferes sometimes. Just a thought.
  5. 07spacker
    07spacker Member
    Utah
    dang nasty bugs
  6. bap3826
    bap3826 Member
    Nanaimo, BC, Canada
    I had a spider build a nest in my neutral light lens. I was much brighter after she was evicted.
    GPS is a great way to confirm speedo readings. I have tried this on a few vehicles. Sometimes the mechanical speedo is quite poorly calibrated.
  7. Andy_1602
    Shelbyville, KY
    Sorry It is a 1982 XJ750 Maxim. With one piece guage set. I just bought it for wife and at 45 mph tach is at 5k rpms. It feels like 65 or 70 mph. Are these guages hard to take apart. Needle does not jump around like cable is bad. Thanks
  8. Gamuru
    Gamuru Guest
    Granite Falls, WA
    On my '81 XJ650, the tach reads 4250 at 55 Mph. Same on wife's '82 XJ650.
  9. Ass.Fault
    Andy,
    I think the gear ration is .812:1 for 5th gear. That 45 mph does not sound right unless you ar on a steep incline.
    I would verify to make sure an accurate reading(Like riding next to someone else and see if there are any diffrences)
    If your truely off then you have a couple of options.
    Attempt to repair, search the forums for simmilar topics and you should be able to accoplish the task.
    Or just but a known-to-be-well cluster and just change them out.
    Ebay is a treasure chest sometimes.
