Front Brake Caliper - signs of wear - can it be repaired
Discussion in 'XJ Technical Chat' started by Motown, May 30, 2023.
  1. Motown
    Motown New Member
    Michigan
    Hi All - well with the help of chacal and hogfiddles I have my 82 xj750 seca back on the road, well it's running
    put it that way. After the second test ride I noticed it was sluggish to get going and sounds from the front brakes.
    I found that the front brake pads were not releasing from the disc. So after reading some threads and
    watching some videos I dove in to pull them apart.
    I have them both pulled apart and cleaned. However, I found pitting on one of the pins.
    The big issue is inside the one of the pins bore holes is a cavity. It looks like it rusted to the
    pin and over time created a cavity. See pics.
    Questions:
    Can I reuse the pin that has pitting? Should I sand/grind it smooth?
    Caliper body that has the cavity in the pin bore hole - can the cavity be filled and reused?
    JB Weld? The pin that goes into that hole is not pitted and in good shape.
    I apologize if this isn't the correct place to post this. I did check for other threads and didn't find
    one that had a similar issue.
    Any help/suggestions would be greatly appreciated!
    Thanks - Motown
  2. Motown
    Motown New Member
    Michigan
    Oh and 3rd question:
    I'd like to repaint the calipers black like original. I have high heat VHT caliper paint. I was also going to
    use a high temp clear coat when done. Any other suggestions for paint?
