Ignition switch issues
Discussion in 'XJ Technical Chat' started by jag3, Oct 4, 2023.
  1. jag3
    jag3 Member
    Daytona Beach, FL
    I hope this is the right forum for this. My 83 Xj750K ignition switch started having problems the other day. I added a fairing and everything seems to have gone well but I can't lock the steering when I turn the bars all the way left or right. The switch seems to not want to push down very far at times and when it does the key doesn't turn to lock it and now on rare occasions the key has a hard time turning to on. Do I need a new ignition switch assembly? I would hate to be stuck someplace and not be able to get back. On another note, for years I have been able to remove the key while it is still running. I'm the original owner so I know there hasn't been any tampering with it.
    Thank you.
    Joe
  2. jag3
    jag3 Member
    Daytona Beach, FL
    Is the steering lock and ignition switch one unit and if I replace the ignition switch will that take care of the steering lock? My steering won't lock anymore.
  3. Dan Gardner
    Minneapolis, MN
    Yes, the ignition switch unit has a little piece that sticks out to lock the steering.
  4. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    You should remove the assembly and regrease the locking bar.
    It is at the base and can get gunged up and tight.
    Jetfixer and Roast644 like this.
  5. Rooster53
    North, FL
    cds1984 and Jetfixer like this.
  6. jag3
    jag3 Member
    Daytona Beach, FL
    Thank you all for your responses. My next project.
    Joe
  7. Dan Gardner
    Minneapolis, MN
    Like most of these projects, the first time you do it might you might feel like a complete noob, but if you are patient and follow the directions you will be fine.
    I've done a few ignition switch assemblies now - at first taking out those little springs and wafers out freaked me out. Now it's just mild anxiety.
  8. jag3
    jag3 Member
    Daytona Beach, FL
    Does anyone know an easy way to put the bolts back in that attach the ignition switch to the frame? My fingers are too big. Do I need to remove the headlight bucket?
  9. Timbox
    I would try to tape the screws on what ever you took them off with. Once they are started into the threads you would be able to pull the screwdriver or what ever you are using off and remove the tape. Otherwise, yes you will have to gain better access to the bolts that hold the swx.
    Good luck.
  10. Lars
    Lars New Member
    Europe
    On my 750 seca; I removed the ”atari” a bit by loosening the bolts but not the connections (kind of bent it away) and loosened the headlight so I could bend it down a bit.
    Then a 10 mm socket; fair light and a shaft to the socket made the job (add a reasonable amount of patience too)
