Stripped the paint
Discussion in 'XJ Technical Chat' started by Zoot_Suit, Dec 17, 2023.
  1. Zoot_Suit
    Zoot_Suit Active Member
    Detroit, Mi
    If anyone is curious, I used Klean Strip Premium Stripper. (I used about 500ml, or a little over half a quart)
    Rough the surface by hand with 80-100 grit, stipple the stripper on so thick that it starts running. And let it sit for 1-2 hours.
    Then scrap with a putty knife, and scrub with a steel brush, then wash in soapy water, and rinse with hot water.
    Any trouble spots may need a second pass.
  2. LAB3
    LAB3 Member
    Traveling the U.S. with no fixed address
    Nice job! Is this a personal project or an ad?
  3. hogfiddles
    Yep, looks the same as how mine came out.
    Franz, Zoot_Suit and chris123 like this.
  4. Zoot_Suit
    Detroit, Mi
    Personal project.
    I find others experience invaluable, so I figure if I share mine, it may help someone else. I try to include as much relevant information as I can to reduce questions and just make it easier for others. I even share my failures too. lol
  5. Zoot_Suit
    Detroit, Mi
    I just finished blasting a bunch of parts with baking soda, and Holy smokes, I swear it is smoother than silk. I'm wondering if I'm going to have to sand with 600 to put a little tooth back for primer.
  6. Melnic
    Melnic Active Member
    That looks really good.
    Is the glass beading going to put a texture onto it or just strip more remnants off?
    I have a tank I'm about to do (not an XJ) that was custom painted and I believe they used Bondo to cover up the mounting bar for the "Yamaha" emblem.
    Curious if pain strippers like this attack the bondo or not.
  7. hogfiddles
    I used a Citrus stripper on my tank and fender..... it didn’t touch the fender bondo—-
  8. Zoot_Suit
    Detroit, Mi
    It left what felt like about a 320.
    Then once I blasted with baking soda, it made it too smooth. I'll have to sand with 600 to give it some tooth for the primer.
    hogfiddles likes this.
