30% of the way there...
Discussion in 'Hangout Lounge' started by Zoot_Suit, Jan 5, 2024.
  1. Zoot_Suit
    Zoot_Suit Active Member
    Detroit, Mi
    I start making her pretty this weekend.
    :D
    Dan Gardner and chris123 like this.
  2. Dan Gardner
    Minneapolis, MN
    That's a pretty snazzy booth setup you've got there.
  3. Zoot_Suit
    Detroit, Mi
    Built it from an old pallet and cheap plastic drop cloth. :D
    But hey, it works.
  4. Zoot_Suit
    Detroit, Mi
    Lower is primed. :D
  5. Zoot_Suit
    Detroit, Mi
    Now onto the upper half.
  6. Zoot_Suit
    Detroit, Mi
    Now we wait...
  7. Zoot_Suit
    Detroit, Mi
    Franz and Dan Gardner like this.
  8. hogfiddles
    Engine side covers-
    peel the YICS stickers out and when you’re done painting, put NEW replacement stickers in. Len Chacal carries them.
    Zoot_Suit likes this.
  9. LAB3
    LAB3 Member
    Traveling the U.S. with no fixed address
    About 20 years ago I took that idea one step further and used two pallets as a floor. Sealed off the areas on the sides of the pallets with cardboard and made a plenum for a fan off the back also out of cardboard. Cheap and easy down draft paint booth!
  10. Zoot_Suit
    Detroit, Mi
    Oh yeah? I'll look for them. Thanks for the tip!
  11. hogfiddles
    Yep:)
    The only difference is that the original red letters have flat endings, and Len’s have rounded endings. Other than that, they’re the same. Only a keen eye or knowledge of that detail would even know theres a difference.
  12. Zoot_Suit
    Detroit, Mi
    Header prep is done.
    Timbox and Roast644 like this.
  13. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Looking good! I can't tell in the photo, did you remove the header chrome? Or just buff it up to accept the primer? What is the ceramic coating and baking process you've got?
  14. Zoot_Suit
    Detroit, Mi
    Unfortunately the chrome was too far gone, so I had to strip it. I'm using VHT Flame Proof on it.
    Roast644 likes this.
  15. Zoot_Suit
    Detroit, Mi
    More progress. :D
    Franz, Dave in Ireland and Roast644 like this.
  16. Kickaha
    New Zealand
    Isn't the idea of a ceramic coating to retain the heat ? which would be the opposite of what you'd want on an air cooled engine
    Dave in Ireland likes this.
  17. Dan Gardner
    Minneapolis, MN
    chris123 likes this.
  18. LAB3
    LAB3 Member
    If the ceramic needs to be cured then what disease does it have?
  19. Fuller56
    Fuller56 Well-Known Member
    Oxidation Ugliness.
    Zoot_Suit and LAB3 like this.
  20. Zoot_Suit
    Detroit, Mi
    Yes. If you can keep the heat inside of the pipes, it's cooler on the outside. And if you keep the heat inside of the pipes, you get better exhaust flow, and more power.
  21. Zoot_Suit
    Detroit, Mi
    I have de-badged the fuel tank. :D
  22. Zoot_Suit
    Detroit, Mi
    Now I have to find the paint I want.
  23. Timbox
    Nice work, that and a great make shift paint booth. I guess one of these days I will have to make one. I too have some painting to do, once it gets warmer.
    Looking forward to seeing the project finished.
  24. Kickaha
    New Zealand
    I can understand doing a ceramic coating on a pipe for that reason but not to an aircooled engine where you want to shed heat and not retain it
  25. LAB3
    LAB3 Member
    Sometimes it's best to leave the "Bill Nye the Science Guy" mentality out of the picture and just accept the fact that there's more than likely ZERO reason to be concerned. You could probably say the same thing about chrome, the epoxy finish they come out of the factory with or you could possibly even make that point with just plain old paint but in the end the truth still remains: It ain't YOUR bike so keep your nose out of it!
  26. Kickaha
    New Zealand
    Are you his Mum ? does he need you to hold his hand ?
    If he or any other member didn't want comments and questions then they don't have to post or they can ignore any question
    I am simply curious as to the reasoning being doing it when ceramic is primarily used (from what I have seen) for heat retention,
  27. LAB3
    LAB3 Member
    Why eas it his place to make man question his decision after the fact? Seems to me it does nothing other than to "prove" he thinks he knows something.
    Again, it's not his project and it ain't his business.
  28. Zoot_Suit
    Detroit, Mi
  29. Timbox
    The bowl on the left looks to have a blocked enrichment jet, need to make sure they are all cleaned out and flow liquid before putting them back together. Looks great other than that.
  30. Zoot_Suit
    Detroit, Mi
    Yeah, I rinsed the baking soda away.
  31. Zoot_Suit
    Detroit, Mi
    Fleabay offered me a $15 refund after I spent over $40. o_O
  32. Zoot_Suit
    Detroit, Mi
    Painting continues.
    I swear, the painting portion seems to be 90% of the work.
  33. Zoot_Suit
    Detroit, Mi
    The clear coat turned white in a few spots. Weird.
  34. Zoot_Suit
    Detroit, Mi
    Beginning work on the side covers.
  35. LAB3
    LAB3 Member
    Wouldn't it be best to remove the badges until you're done painting?
  36. Zoot_Suit
    Detroit, Mi
    I started to, but they're so old and brittle they started to crack when trying to remove them. So I figured it'd be best to leave them be.
    LAB3 likes this.
  37. Zoot_Suit
    Detroit, Mi
  38. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    looking good, silver tinted green, no argument from me!
  39. Zoot_Suit
    Detroit, Mi
    It started off as a 1969 Pontiac Limelight Green Metallic. But it was a touch too dark. So I had him add a few drops of white, and an additional ounce of silver to lighten it up. It came out exactly as I wanted. :D
  40. Zoot_Suit
    Detroit, Mi
    I was able to get the badges off without them breaking (used a heatgun).
    Dave in Ireland, Fuller56 and LAB3 like this.
  41. LAB3
    LAB3 Member
    Those look sharp! It's one of those little things that all add up to create a nice looking restoration.
  42. Zoot_Suit
    Detroit, Mi
    Starting the artwork.
  43. Zoot_Suit
    Detroit, Mi
    Finally finished the tank.
    Just have to wait for it to cure, then I can buff and polish it.
    chris123, Roast644 and Timbox like this.
  44. Zoot_Suit
    Detroit, Mi
    Hot, sweaty work.
  45. Zoot_Suit
    Detroit, Mi
    Rims are done! They just need new rubber now.
    Dan Gardner and Roast644 like this.
  46. chris123
    chris123 Active Member
    Benicia, ca
    Awesome work on the bike so far!
    Looking at all the carb parts pictured above, $40 makes me worry about the quality. I’ve found that today’s gas destroys the cheap aftermarket brass and O-rings.
    I only use OEM or high quality aftermarket parts in my carbs and OEM only for brass. I’ve found Keyster and K&L to be okay for O-rings/gaskets but others on this site have had various results.
    Of course it’s your bike, just trying to be helpful :).
    Thank you for sharing your build!
  47. Zoot_Suit
    Detroit, Mi
    One small step for man... during the workweek. :D
  48. Zoot_Suit
    Detroit, Mi
    Heat curing the ceramic coating on the Screenshot_20240413_122149_Gallery.jpg Snapchat-1833751188.jpg Snapchat-164160618.jpg engine. :D
    chris123, Franz and Roast644 like this.
  49. Zoot_Suit
    Detroit, Mi
  50. chris123
    Benicia, ca
    Very nice!
    What paint did you use? Did you do anything to the bare aluminum areas besides clean (polish etc)?
