Hitachi carb id
Discussion in 'XJ Technical Chat' started by Roast644, Feb 18, 2024.
  1. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    I grabbed a set of carbs out of the pile to rebuild for the '82 750J. I noticed the bowl drains had the dual sided castings which I haven't seen on the Maxim carbs before. Looking at carb pictures online, I see 750 Seca carbs with this feature. Inside they have these jets:
    #128 main
    #40 pilot
    #80 pilot air
    #225 main air
    So they match in stock 750J jets except for the main fuel (#120 stock).
    Are these the same HSC32 carbs as the Maxim with the main swapped out? Or are they for a Seca or something else? And does it matter?
    I read on Len's carb description that the model number for the body is different for the Maxim and Seca. What, if any, differences are there?
  2. kosel
    MInneapolis, MN
    You should be just fine. I have a spare set with the same bowls. So long as the jets and needles are right for your model.
    Roast644 likes this.
  3. Melnic
    Melnic Active Member
    Don't forget to look at the needle
  4. Roast644
    WASHINGTON
    Needles are the stock Y-13, but they have a shim washer installed. I believe there should be no shims to return to stock jetting.
  5. chacal
    Correct.....between that and the rather huge main fuel jets, someone sure had a desire to richen that mixture way up......
