Replacing Cylinder Barrels/Jugs with existing Pistons and Rings.
Discussion in 'XJ Technical Chat' started by Franz, Jul 14, 2024.
  1. Franz
    Franz Well-Known Member
    Scotland UK.
    My existing cylinder barrels are damaged externally, the two bolts at the front of the cam chain tunnel area. I have a spare set. Can I fit the existing pistons into the spare set without rehoning the spare cylinders? I know about checking end gaps of piston rings in the bores and checking the bores at the top, half way down and near the tapers at the bottom of the liners. Any advice appreciated, cheers.
  2. minimuttly
    minimuttly Active Member
    UK
    Well you can, provided they are in good condition and within spec, and I would recomend a light hone to help everything bed in
  3. Franz
    Scotland UK.
    Cheers minimally what hone should l get thanks?
  4. minimuttly
    UK
    Either the ball on the wire or three stones one would do - you're not wanting to remove any metal, just take the shine off.
  5. Franz
    Scotland UK.
    Great l decided it was better to replace them than weld the original ones. Need tig gear to weld it.
  6. minimuttly
    UK
    If it's accessable I would take it somewhere to weld it - is it doable without stripping the engine? If you do the prep - cleaning etc, a decent welder should be happy to take it on.
  7. Franz
    Scotland UK.
    I will need to take the barrels off to take to an engineer, I heard there is a welder in Shotts who does that type of repair I will contact him.
  8. a100man
    a100man Well-Known Member
    Bedford, UK
    Ive seen Millyard heat up cylinders on his BBQ and drop/knock the liners out. If you'r bravee you could try that i.e. swap them over. BTW to measure bores properly you need
    a specific bore gauge instrumsnt I think.
  9. Franz
    Scotland UK.
    Yes that's a good idea too. I will have to put them in the oven when she is at work :D. Yes l have seen the gauge for the bores.
  10. Franz
    Scotland UK.
    That would be ideal if l can swap them. I have seen people freezing the liners to get them in as well. I will watch the Millyard video again l think.
  11. Franz
    Scotland UK.
    Here is the mess l have to fix. Steel bar holding bolts because the cylinders are damaged at the bolt holes. Some bodge this is.
    I don't want to leave it like this. PO's.
  12. Franz
    Scotland UK.
    Welding required.jpg Yamaha XJ 900 XJ900 F 58L cylinder barrels pre-Diversion eBay.png
    What a mess.
  13. minimuttly
    UK
    Nooo, this is way more complicated than just knocking them out and replacing them - they were installed to a step then the whole lot machined flat - you will end up with liners up down and everywhere in between. I'm not joking, I've actually done this on a Vmax engine, same principle exactly -(with the added hassle of setting up the v engine in the mill).
    You can do it, but you should still deglaze them and have them topped at a machine shop.
  14. minimuttly
    UK
  15. Franz
    Scotland UK.
    The red bar is metal. These are the other barrels. I won't try and change liners. So it's either tig up the damaged ones or fit the spare ones if they are in spec and hone. I didn't realise the liners would be up and down cheers minimuttly.
  16. Franz
    Scotland UK.
    Is the machining involved once it is TIG welded like skimming a cylinder head? Local engineers skimmed the head on a Mondeo I had before I replaced the head gasket. It was not expensive for that.
  17. minimuttly
    UK
    No, if you tig weld up the rotten lugs it will need machining to drill and face off the newmetal, and maybe reface the jugs due to distortion. I would guess £200 all in, but it depends where you take it.
  18. Franz
    Scotland UK.
    That's not expensive if it's around that cost cheers.
  19. a100man
    Bedford, UK
    welding probably safer but not as much fun. I agree that seating the liner again so they are all within a couple of thou' would be tricky fo the layman and a lick over by a mill probably wise.
  20. minimuttly
    UK
    Tricky for the layman? They will only go down as far as the lip lets them, and they won't match the reliefs in the "block".
  21. Franz
    Scotland UK.
    Replacement cylinders arriving today. Local engineers will check the bore dimensions and if within tolerance as I have been assured they are they will be honed and fitted. Should I put the rings in the bores to make sure they end clearance is within specifications? If this works it is the easiest solution at the moment. And what grit of hone is necessary to remove the glaze?
  22. Franz
    Scotland UK.
    Cylinders look to be in excellent condition but of course need them measured to be sure. No damage whatsoever and no lip at the top of the bore where the rings stop.
  23. minimuttly
    UK
    Yes to checking ring gaps. Be careful!
  24. Franz
    Scotland UK.
    I will motor is not stripped yet.
  25. Franz
    Scotland UK.
    Replacement cylinders look good.
    20240717_232512.jpg 20240717_232503.jpg 20240717_232454.jpg 20240717_232447.jpg
    Dave in Ireland likes this.
