Can anyone identify this XJ 653cc cylinder?
Discussion in 'XJ Technical Chat' started by lastexx, Sep 10, 2024.
  1. lastexx
    lastexx New Member
    GR
    Hello I cannot find from which model was. There is a 11T00 number marked. Which model had this?
    Thanks.
  2. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    Since the knock sensor boss is threaded, pretty certain it’s a Turbo
    Franz likes this.
  3. lastexx
    lastexx New Member
    GR
    What was the difference between the LK and LJ ?
    Many thanks for your reply.
  4. Dan Gardner
    Minneapolis, MN
    J = 1982
    K = 1983
  5. chacal
    11T is the model ID code for the Euroland XJ650 Turbo model.
    I bet not many ever made it to Ἑλλάδα.......
  6. lastexx
    lastexx New Member
    GR
    Many thanks for your kind info.
  7. lastexx
    lastexx New Member
    GR
    I know about the knock sensor but I have not seen Turbo cylinder with the upper hole-puddle (red circle in photo). Have you seen again like this ? Thanks.
  8. chacal
    Well, I've never seen an 11T set of jugs, and it's hard to tell what the "puddle" is that you are referring to, although I'd be surprised if there is any difference between the 11T jugs and any other Turbo jugs......
