KLR650
Discussion in 'Other Motorcycles' started by Simmy, Dec 23, 2020.
  1. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    it was beyond time for the initial valve check on my 2015 KLR daily rider - 25,000 kms.
    I found both exhaust valves tight.
    Unfortunately camshaft removal is part of the process to change shims.
    Fortunately the shims are the same as our XJ's.
    Unfortunately my salvaged XJ shim collection starts at 265.
    I need 2 x 255's.
  2. tj.
    tj. Active Member
    Canada
    I'll have a look.
  3. tj.
    tj. Active Member
    Canada
    1x250, 1x255, 1x260
  4. Simmy
    Thanks TJ, I just ordered a couple from the K dealer.
    Looks like you've done a few KLR adjustments.
  5. tj.
    tj. Active Member
    Canada
    I've had a couple of them...great bikes! Some guys say they can remove the shims without having to loosen the cam caps (using a pair of hemostats and a magnet)...haven't tried, but I'm doubtful. I'm assuming you remembered to remove the cam tensioner bolt...I've played that "where'd the damn spring go" game before.
  6. Simmy
    This is my 4th KLR, had an 89, 97, 2000 and now 2015.
    I checked valves before but never had to adjust them.
  7. tj.
    tj. Active Member
    Canada
  8. Timbox
    They are great bikes. Going a little off topic, I wish they would put the Versys engine in that frame. I owned a 09 until three yrs ago, just wanted a little more engine. That or fine the military version with the diesel engine....now that could be fun.
  9. Simmy
    Fuller56 and Timbox like this.
  10. Simmy
    KLR is almost packed. I'm heading out July 1st for 6 days with 6 buddies, we're all on KLR's.
    We'll be right out of cell range, vagrant camping and pooping with the bears.
  11. Timbox
    Have a great safe ride. Taking fishing gear or just find food along the way? Interesting camping rules you have in Canada, cool for the people traveling. KLR's are rock solid bikes, enjoy the trip and see you back on here when you return.
  12. Simmy
    We'll be about 80 kms from the Trans-Canada Hwy so will be going there to fill up and buy food and beer each day, only the essentials.
    There are no rules, there's no one there and all crown land.
    I'm taking a large mosquito net which will cover 2 lawn chairs, I'll be the most popular guy there, ha!
  13. Timbox
    Yes you will, those little black flies are nasty at times. Hope you stay dry.
  14. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    So jealous. Take lots of pictures and post them here.
  15. Simmy
    Here's a couple pics of my touring bike.
    campsite on 1st night
    you can blow your horn out here, no one to hear it anyway
    campsite days 2 & 3
    Corn on the cob, potatoes and hot dogs, standard bush cuisine.
    All told I did nearly 2,000 kms of riding from Thursday morning to Monday evening.
    We had planned on persevering until Tuesday but Monday we got drenched to the bone so we all headed home.
    We've been doing vagrant style trips for about 5 years now, seems to be harder with age.
    The mosquitoes black flys and no-see-ems were particularly viscous this year.
    I had 2 problems with my bike, 1st was a loose battery connection which made my single fire like half a cylinder.
    Also lost one of the 4 bolts holding the subframe. Luckily someone had an extra bolt which fit.
    No flat tires, a few spills, good time had.
    Timbox, Rooster53 and lostboy like this.
  16. Timbox
    Looks like you had a good load on her as well. Glad it was a save and successful trip. I new those bugs would be nasty.
  17. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    You had the red chair didn't you ?
  18. Simmy
    Yep, and the large bug net
  19. Simmy
    I’ve whittled my list for adventure touring smaller every trip I take. At one time I tried taking cooking gear but no more. I took just a 21” tube as it will work in a 17” rear if needed. Good to split the tools and any emergency supplies amongst the other riders.
  20. Simmy
    Just brought my new touring and daily rider home.
    The 3rd gender KLR is actually a good looking bike, well done Kawasaki.
    I thought about a 790 KTM but they're assembled in China and I'm weary of problems being such a sophisticated bike.
    The KLR's have been made in Thailand for many years now without issue.
    I've become so accustomed to touring with a single cylinder, really don't want it any other way.
    It helps that all my friends ride KLR's too.
    IMG_4001[1].jpg Getting crowded here until I sell my Gen 2
    Timbox, Fuller56, Franz and 1 other person like this.
  21. Timbox
    Great bikes....now comes all the fun with the mods. Then later on down the road, the 685 kit goes in....
    Have a great time with your thumpper.
  22. Simmy
    There is an Adventure model from Kawasaki which comes with auxiliary lights and too tiny hard bags.
    I got the standard model with ABS and added heated grips from Kawasaki.
    The wiring harness now comes with plugs for the grips, USB socket, cigarette socket and the auxiliary lights.
    Once you add the relay all these plugs are activated with the key.
    I have side pannier racks ordered for soft bags and need to install a top box and the power outlets.
    I look at the crash bars guys like to install and shake my head.
    $500 in additional weight to save plastic side panels new for $200, or just live with the scratches.
    I ride these things for what they are.
    The 685 kits really don't add any perceptible power.
    They were a thing to cure the 2008 models (1st of the Gen 2's) which had poor ring sealing and heavy oil consumption.
  23. Kickaha
    New Zealand
    I'm heading to Australia next month from NZ for a week riding and camping in the Victoria high country and riding a Gen 2 KLr650, same bike which last year took me 7500km Melbourne to Cairns return over 12 days, It doesn't do anything spectacularly well but it does do everything, I like them, a few suspension improvements wouldn't go amiss and would transform them
    Simmy likes this.
  24. Timbox
    Simmy, you are all over making that bike yours already. Yes you are probably right on the 685 mod, I had a second gen and then went back to a first gen and did the mod. Big différance on the fist gen bikes.
    I, too, would stay away from the crash bars, adventure bikes wear some scratches like a badge of honor, imho.
    I have read the Kaw listened to their customers and finally did a bunch of mods to the engine at factory. Or should I say change the motors at factory so all the mods didn't have to be done. That will be nice for a change.
    Enjoy the hell out of the new bike. Might have a month of riding on select days in my area, hope you have longer.
    Simmy likes this.
  25. Dave in Ireland
    Ireland
    I'd still fit crash bars to protect engine casings. The bodywork, not so much.
    You can always get home with a tie-wrap or two holding things in place, but not with a hole in the end case.
  26. Simmy
    The motor is already tucked in pretty tight on these things.
    Back in my younger days we used to get deep into the bush with our Gen 1 KLR's, just never seen this happen.
  27. Kickaha
    New Zealand
    Australia, Victoria high country, Randalls track, near Dargo, the crash bars are definitely needed, I'd just picked it up KLR.jpg
    Rooster53 likes this.
  28. Simmy
    Great scenery, not what I pictured Australia to be.
  29. Timbox
    I can't see a bike in the picture, must be all the digital camo ;) Nice looking bike and great pic. I am sure there is nothing in that pic on the ground the might want to kill you? lol
  30. Kickaha
    New Zealand
    Not that I saw and out of sight out of mind
    Depends on what state and area you are in, they have everything from desert to rain forest and all points in between
    Timbox likes this.
