1988 xj900f blinker problem
Discussion in 'XJ Technical Chat' started by Arnaud, Sep 12, 2024.
  1. Arnaud
    Arnaud New Member
    Netherlands
    Dear folks, since 2 days i have a strange problem with the blinkers.
    When switsched on, they blink a few times, and then seize to blink, or blink at all, and the needle of the RPM-meter sways rithmically up and down, or simply drops.
    I cleaned the 2 connectors where te black wires go from 2 to 1 wire.
    Maybe it is a ground problem.
    Where can i find the 'further'connectors and/or the place where it is connected to the frame?
  2. cds1984
    cds1984 Active Member
    Perth, Western Australia
    Main ground is on the rear of the engine.
    The frame is connected by this as ground(negative).
    The indicators are generally 2 wire so not a grounding issue.
    I would be suspicious of the globes or indicator relay.
  3. Arnaud
    Arnaud New Member
    Netherlands
    I have found it in the meanwhile, thanks!
  4. cds1984
    Excellent!
    What was the issue?
  5. Arnaud
    Arnaud New Member
    Netherlands
    I think bad grounding..
  6. cds1984
    Glad you fixed it.
    It's funky really.
    The spark plugs don't fire if the engine doesn't have a negative attached to it.
    Actually the starter motor won't actuate either.
    Paint and other issues must come in to play for the frame to not have a negative also since it is bolted directly to the engine.
