1988 xj900f blinker problem
Discussion in 'XJ Technical Chat' started by Arnaud, Sep 12, 2024.
  1. Arnaud
    Arnaud Member
    Netherlands
    Dear folks, since 2 days i have a strange problem with the blinkers.
    When switsched on, they blink a few times, and then seize to blink, or blink at all, and the needle of the RPM-meter sways rithmically up and down, or simply drops.
    I cleaned the 2 connectors where te black wires go from 2 to 1 wire.
    Maybe it is a ground problem.
    Where can i find the 'further'connectors and/or the place where it is connected to the frame?
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Main ground is on the rear of the engine.
    The frame is connected by this as ground(negative).
    The indicators are generally 2 wire so not a grounding issue.
    I would be suspicious of the globes or indicator relay.
  3. Arnaud
    Arnaud Member
    Netherlands
    I have found it in the meanwhile, thanks!
  4. cds1984
    Excellent!
    What was the issue?
  5. Arnaud
    Arnaud Member
    Netherlands
    I think bad grounding..
  6. cds1984
    Glad you fixed it.
    It's funky really.
    The spark plugs don't fire if the engine doesn't have a negative attached to it.
    Actually the starter motor won't actuate either.
    Paint and other issues must come in to play for the frame to not have a negative also since it is bolted directly to the engine.
