XJ600 air cleaner joint smaller
Discussion in 'XJ Technical Chat' started by Henry Nguyen, Jan 1, 2025.
  1. Henry Nguyen
    Henry Nguyen New Member
    Oakland, CA
    I notice that one of my air cleaner joint(airbox boot) is smaller than the other three by 4mm.
    There was an air cleaner case on ebay, so I bought that. But when it arrived, it was the same size as the small one. The small ones are 44mm in diameter while the bigger ones are 48mm.
    I already tried heating and boiling it, but it's still too tight. I also heard using xylene and wintergreen oil, but at the end of the day, it is still not the right dimension. I don't like forcing parts to fit. How would I find the right part? Chatgpt couldn't help me. Thanks for any help
    I should have measured the carb, I'll edit it in tomorrow...
  2. chacal
    Actually, the #1 and #4 boots are the same size, and the #2 and #3 are a different size. We do have reproductions of the originals available for both positions.
    Timbox likes this.
  3. Dave in Ireland
    Ireland
    I wouldn't believe a word that came out of that sucker's mouth.
  4. chacal
    Doesn't having a computer regurgitate mis-information make it more true?
    Only uncivilized, pre-Renaissance Luddites wouldn't believe what a human-created and coded computer program (which has no intelligence, artificial or otherwise) vomits out to the world..... :)
    Or as they like to say in the bit-flogging world:
    GARBAGE IN, GARBAGE OUT.
    Hollybrook and Dave in Ireland like this.
  5. Henry Nguyen
    Oakland, CA
    The carb is also 48mm. Can I get the boot #1 Chacal? Not to doubt you or anything, but can you also get me the dimensions for the inner diameter of the boot? I've been burned once already
  6. chacal
    Hi Henry, tell me what year and model bike you are working on.......
  7. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    that airbox looks like a later model its a diversion model probably post 1991 maybe a 4BR model
  8. Henry Nguyen
    Oakland, CA
    1992 Yamaha Seca II XJ600SD(SDC?) since I'm from California
  9. chacal
    The airbox boot, where it attaches to the carb (where the band clamp is located) is a little over 48mm ID.
  10. Henry Nguyen
    Oakland, CA
    You are a lifesaver, a godsend Chacal. How do I go about buying it?
  11. chacal
    Hi Henry, please send me an e-mail at: info@xj4ever.com and I'll get you all of the pricing, ordering, etc. info!
