Engine wont turn over
Discussion in 'XJ Technical Chat' started by Philr, Jan 4, 2025.
  1. Philr
    Philr New Member
    England
    Hi could someone advise me as I'm getting stick of this problem.
    So I have checked everything out and I'm sure I'm getting right but apparently I'm not. My engine was seized and I've managed to free it up and it now turns over by hand freely. I put the head back on and I've done the timing and suddenly I can't turn the engine at all.
    It's like it just binds up and the only way to free it is to loosen the cams. I'm stuck in a frustrating loop and I can't see what's going wrong. Could someone please advise me. It will end up in a scrap heap at this rate.
    Thanks in advance.
  2. Franz
    Franz Well-Known Member
    Scotland UK.
    What machine do you have?
  3. Philr
    Philr New Member
    England
    Xj550
  4. Franz
    Scotland UK.
  5. Franz
    Scotland UK.
  6. minimuttly
    minimuttly Active Member
    UK
    You need to isolate the issue. Remove plugs, disconnect the cam sprockets by removing the bolts. Then try carefully turning the cams - don't be surprised if you find a valve comes against a piston. If either cam does not move or is really tight you likely have the caps wrong. They are numbered...
    In an ideal world the pistons should be half way up/down the bores to do this but if you cannot move the engine it makes this difficult. Tread carefully, don't force anything.
  7. minimuttly
    UK
    When you say the engine was seized, what's the history? Seized how? Engines don't seize without scoring something - pistons, crank bearings, - cam bearings?
    More info needed, it's a 2 way thing..
    Timbox likes this.
