Xj750 Seca help
Discussion in 'XJ Technical Chat' started by Russtic, Feb 20, 2025.
  1. Russtic
    Russtic Member
    Uk
    Trying to get the engine out of my 750. The front bottom bolts are seized. I sheared the bolts and have cut off the nuts. But they still wont come out :-(
    ideas????
  2. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    I think you might have to drill them out now
    I encountered the same parting out a turbo
  3. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Yes, not uncommon. A recip saw, or sawsall to cut them flush would be my preferred option, then drill carefully in steps once the engine is out.
  4. Russtic
    Russtic Member
    Uk
    Yep. That worked.
  5. Russtic
    Russtic Member
    Uk
    Cannot get crankcase split. Stuck at front I have given it lots of heat, pb blaster, more heat and more heat. All I have succeeded in is breaking a couple of fins.
    it appears to be stuck at the centre bit at the front of the engine see photo.
    Am I missing something? Or do you have any ideas. Getting a bit frustrated now!!
  6. Franz
    Franz Well-Known Member
    Scotland UK.
    MAP gas l used on those three.
  7. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    "Crankcase" ??
    i take it you mean "cylinder head"
    yep go easy on those fins, you dont want to be levering on those, are you sure you have all the cylinder head nuts off ?
  8. Russtic
    Russtic Member
    Uk
    Yes that is what I mean and yes all bolts are removed. It has moved a little and then nothing.
