Pick up coils Question
Discussion in 'XJ Technical Chat' started by Bandit, Mar 23, 2025.
  1. Bandit
    Bandit New Member
    Stevenage, England
    Can I use XJ750 pickup coils on a 1980 XJ650 or will there be issues?
  2. bensalf
    bensalf Well-Known Member
    yorkshire ,england
  3. Bandit
    Bandit New Member
    Stevenage, England
    They will have different part numbers as they are off different models, i.e 5g8 / 4h7 , that is the reason I'm asking. I know the Ohms readings are different on both but by hardly anything, what I wanted to know is will the 750 pickups work and be as efficient as a 650 pickup coil or would it screw around with the igniter box?
  4. Bandit
    Bandit New Member
    Stevenage, England
    Well I swapped out the pickup coils and nothing but a barely visible spark, It eventually started but run really rough. I put the original one back in and it fired up first time.
  5. chacal
    Dirty connections......
