1981 XV750 Cam Chain Replacement
Discussion in 'Other Motorcycles' started by Lonewulv13, Apr 8, 2025.
  1. Lonewulv13
    Lonewulv13 New Member
    Canada
    The cam chains are apparently stretched. Anyone have any experience replacing these?
  2. Robert Strumbell
    Robert Strumbell Member
    United States duluth mn
    Why do you think it is stretched? How many miles?
  3. Robert Strumbell
    Did U mean XJ 750?
  4. Robert Strumbell
    I have successfully replaced other cam chains, not the XV750. I definitely needed the riveting tool. Removed tensioner, partially removed old chain, cut chain, connected new chain roll engine over feeding new chain, installed master link.
    Lonewulv13 likes this.
  5. Lonewulv13
    Canada
    Did it require a full engine removal? Also how did you install the new chain if you had to cut the old one to remove it?
  6. Lonewulv13
    Canada
    Response is above. This forum's system is terrible...
  7. Lonewulv13
    Canada
    No- XV750 is the Virago 750
  8. Lonewulv13
    Canada
    That's what the mechanic told me. It's hard to tell how many miles are on it cause it was an engine rebuild.
  9. Robert Strumbell
    What makes you think the chain is stretched? Doesnt run good, noisey?
  10. Franz
    Franz Well-Known Member
    Scotland UK.
    Were the cam chain tensioner plungers fully extended so they cannot keep the chains tensioned any more?
  11. Lonewulv13
    Canada
    That is what my mechanic told me. It's a 1981 Virago so the chains are just worn. The pins bend slightly, causing the chains to have more give so they slip. It has a hard time starting- makes this loud clacking sound almost like something is whacking against the bottom of the tank. It cut out on me while riding. Couldn't get it started again.
  12. Lonewulv13
    Canada
    I'm sure if they were my mechanic would have told me. He was certain that the chains are old and stretched.
    What would the symptoms be if the tensioners were extended?
  13. Franz
    Scotland UK.
    Symptom can be a rattling noise from the engine if the tensioners are fully extended. Chain age doesn't matter chain wear matters. I always check the tensioner plungers to see if they are fully extended before l change a cam chain.
  14. Robert Strumbell
    Hmmm Clacking not good. If tensioners are fully extended and working properly it means chain is worn out. Sounds like it jumped time. First you will have to make sure Valves arent bent with leak down test. I think manual chain adjusters are available, you might be able to get more tension out of them.
