carb problem
Discussion in 'XJ Technical Chat' started by Steve Noltensmeyer, Jun 30, 2025.
  1. Steve Noltensmeyer
    Steve Noltensmeyer New Member
    Freeport FL
    I need suggestions where to go from here
    81 Yamaha XJ650 Maxim
    I just completed rebuilding my carbs.
    I tore them down completely
    broke the carbs apart into individual carbs
    removed everything jets etc...
    used carb cleaner, wire tool, and air to clean all passages
    ultra sound cleaned carbs
    soda blasted carbs
    cleaned all with carb cleaner
    reassembled
    The bike started up within a second or two on prime / switched to on
    i set the idle / idles at 700 well
    revs and snaps back
    I start on a test ride and it bogs when accelerating hard
    I got brand new gas
    I changed the oil
    I changed the spark plugs
    I put seafoam in gas
    I tried turning fuel mixture screw in 1/2 turn all 4 carbs
    I tried turning fuel mixture screw out 1/2 turn all 4 carbs
    I tried running in prime petcock
    I tried running in reserve petcock
    It seems better after spark plugs were changed / but still not strong acceleration / some popping not much
    It sounds good revving in neutral
    the bike was running good before I started / but leaking gas
    I replaced the needle and seat
    I replaced the O-rings in the gas pipes between the carbs / this was the problem I think / no gas leaking now
    Thank you in advance for any advice you have for me.
    I have rebuilt / clean carbs on this bike several times and on my 81 Honda CB750K many more times than I like to admit.
    Stevenolts
  2. Rooster53
    North, FL
    Did you bench sync the carbs on assembly and then do a running sync with gauges?
  3. hogfiddles
    I don’t see anything about syncing, or float height, or colortuning…….
    Rooster53 likes this.
  4. Steve Noltensmeyer
    Freeport FL
    what is color tuning?
    I will sync the carbs / that was next on my list / I have sync tool /
    If I need to take the carbs back off I will check the float height
    Thank you!!!
    This carb ran great on the bike when I took it off
    it was cleaned about a year ago
    it was leaking so I figured if I was taking it off to replace the O rings in the carb connection pipes I would clean extra good this time
  5. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
  6. Rooster53
    North, FL
    hogfiddles likes this.
  7. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    If you log on and click the xjforever icon top right, you can access a mine of information, including carb setting and cleaning. As well as searchings on carbs issues. You will quickly gather that 90% of issues with these old bikes is carb related, sometimes because they are old, dirty, or issues caused by owners. They are all vacuum operated devices, and little understood. Even when you do understand them, they can take a while to sort.
  8. Steve Noltensmeyer
    Freeport FL
    Thank you for your advice
    I am off tomorrow
    I will take another look
    Thank you,
    Stevenolts
  9. Timbox
    Did you do an air pressure check to make sure the diaphragms were seated? That too would cause bog issue.
  10. Steve Noltensmeyer
    Freeport FL
    That is where I landed today
    I need to spray carb cleaner around the air box boots to see if they are leaking.
    If not I need to remove the carbs and check the diaphrams.
    If I need new diaphrams where can I get them?
    I have it idling great
    revs snaps back
    I just synced the carbs as best as I could
    (I have the motion pro round gauges / the bounce but when I rev a little they all seem the same after adjusting)
    I started with air fuel screws 2.5 out
    I went 1 out through 4 out testing each adjustment (no change still bogs)
    I now think it must be an air leak
    diaphram slides or airbox boots
    Thank you, Stevenolts
  11. Steve Noltensmeyer
    Freeport FL
    What is the correct way to do the pressure check
    blow air in the vent to raise the slide?
  12. Steve Noltensmeyer
    Freeport FL
    It runs and starts so good just to bog at 3/4 throttle
    if I shift quick it goes until I hit 3/4 throttle
    What is the best way to adjust the air fuel mix after I get rid of the bog?
    Stevenolts
  13. cds1984
    Once you get out of the idle circuit. The fuel mix screw is not a big factor.
    Then it is the main jet and slide needle.
    Hitachi needle are a set height so you are looking at your jet size, compression, air filter and exhaust flow.
    If the slide opens the main jet and it is too big then you flood... And the opposite if too small of course.
    Are your main jets standard?
  14. Steve Noltensmeyer
    Freeport FL
    They are stock with the stock air box
    Stevenolts
  15. cds1984
    A couple of tricks.
    Pull the slides and hold the diaphragms up to a light and look for holes.
    If the air filter is new, stick a piece of cardboard over the air inlet with a smaller hole in it to restrict air flow to test.
    If it's not new blow it out with a compressor or leave it out for a short test.
    Do you have the standard 4into2 exhaust system and standard mufflers?
    What compression numbers do you have?
  16. Minimutly
    West Wales, uk
    Bogging rich or bogging weak? I suspect weak, otherwise you would know...
    Did you forget to fit the springs above the slides?
    Did you fit the air jets in the wrong place - the Haynes manual has them the wrong way around, or so I have read on here....
  17. Steve Noltensmeyer
    Freeport FL
    I sprayed carb cleaner on airbox boots and intake boots no change in idle
    I took the carbs off
    I sprayed air in intake slot and only 1 of 4 slides moved up
    I took the caps off and reseated the diaphragms and now all 4 slides go up with air sprayed in
    As good as this bike ran with 1 of the 4 slides just bog
    I think once I put the carbs back on tonight and test it should run very well.
    Thank you for you help
    Stevenolts
    Timbox likes this.
