This bike won't stop giving me issues.
Discussion in 'XJ Technical Chat' started by Donglord, Aug 29, 2025.
  1. Donglord
    Donglord Member
    Arkansas
    Finally got my valves adjusted, carbs rebuilt, new coils, wires ,and plugs. But now i discovered my cylinder #3 isn't firing. I have good spark and fuel should be getting to it. (Haven't checked compression yet). Although I suspect its the compression. Another thing, I finally got around to replacing my battery, and the recitifire gets burnt up when I got the new battery on there. What could have caused this? All my grounds seem to be good. No corrosion or anything like that and they're all tight. Someone help me through this nightmare.
  2. Rooster53
    North, FL
    I thought you had a runner?
    "After 5 months of nothing but problems and headaches, I finally got my 86 maxim x700xs running like a top. Valve adjustments, carburetor cleaning, complete rewire, any many more things have been done to this bike and I have this forum to thank for that. My grandpa built choppers for fun before he passed away, so I feel I need to keep the family tradtion alive. I was a total mechanic noob before, and this bike has taught me so much. Thanks to all who have helped me get this thing going. I'll see you on the road"
    So get that done - it's a good idea to know the condition of the engine as a baseline, and would have been nice to know before and after valve adjustment.
    Are the plus and minus the same on the new battery? Hopefully, you are not connecting a battery with reverse polarity
    cds1984 and Huntchuks like this.
  3. Donglord
    Donglord Member
    Arkansas
    The battery is connected properly. I can assure that
  4. Donglord
    Donglord Member
    Arkansas
  5. Donglord
    Donglord Member
    Arkansas
    It was running great for a couple of days. Now these new problem have surfaced. I don't have a compression gauge at the moment so i can't check it quite yet. The battery is connected properly. I can assure that. I just don't know why my rectifier would crap out on me like that
  6. Donglord
    Donglord Member
    Arkansas
    Is there an updated rectifier people are using on these bikes? Cause I'm sure the one on it was the one it came with
  7. Rooster53
    North, FL
    Autozone and likely others will loan a compression gauge.
    "Crap out" doesn't help much when describing a problem and hoping to get help over the internet
  8. Donglord
    Donglord Member
    Arkansas
    It actually burnt up. Wires melted and smoke came from it. Would a rectifier from an 82-83 work. The colored wires match up
  9. k-moe
    That will work, but you need to figure out why the R/R failed so that the replacement doesn't fail. Start by checking the wiring harness for worn-through insulation or melted connectors.
    Based on your description you'll need to relace the harness connector that the R/R plugs in to, but that does not ensure that there isn't a problem elsewhere.
    Have you checked the output voltage at the Alternator?
    I prefer buying a new R/R over buying a used one. They are fairly simple devices, and only differ in connector/wiring pinouts and the physical size/ mounting hole spacing.
  10. Donglord
    Donglord Member
    Arkansas
    Honestly I'm really wanting to just chop all the electronics I don't need. All I really need is headlight, tail/brake lights and an electric start. I'd be interested in a simple bare bones wiring diagram if anyone has anything like that. Preferably one where I can just use all the components I already have.
  11. Rooster53
    North, FL
    Was it multiple wires and what color were they? Check the diodes in the Rect / Reg to see if they shorted
    Didn't you replace the wiring harness earlier?
  12. Donglord
    Donglord Member
    Arkansas
    Yeah but it was already burnt up so that's why I did it. I'm just going bare bones with it. Keeping it nice and simple
  13. Rooster53
    North, FL
  14. k-moe
    Having seen several parking-lot accidents caused by modern riders on vintage bikes, you'll want a sidestand safety switch as well.
    You will also need turn signals. They are required in Arkansas if the motorcycle was originally furnished with them by the manufacturer.
    Rooster53 likes this.
  15. Donglord
    Donglord Member
    Arkansas
    Got my compression check and its showing around 140 psi for cylinder 3. And its getting spark, so that leads me to a fuel issue. Only, as I said, I've just rebuilt all the carbs. Could it just be in need of an adjustment?
  16. Timbox
    Those carbs can be a bugger sometimes. I agree, it is a fuel issue. Might have been something in the fuel line the slipped by? Something in the tank that got past the screen? Not too sure how many sets of these carbs you have cleaned. There is a learning curve to get the set-up right. Wet set, choke ckt jet in the bottom of the float bowl and bench synch. Go through the carbs again just to make sure and take some of the guess work out of it.
  17. Donglord
    Donglord Member
    Arkansas
    Its my first set of carbs like this, but I went through and cleaned it very thoroughly, and made sure to the best of my abilities that all the passages were clear. What are some things to look out for when cleaning. And how can I properly sync at home
  18. Timbox
