  1. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    Wow! What a stunning machine!
    Simmy likes this.
  2. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    Thanks @Brhatweed I’ve had 36 years to modify things. Thinking it might be time for a new paint job though. When I look at the sidecars at Advrider I am completely humbled, especially the suspension systems built.
  3. Jacobxj
    Jacobxj New Member
    Minnesota
    Took my carbs out for the 5th time cleaned them cleaned fuel lines. Just trying to get her to run nice again… I’m thinking it could be a carb sync that’s needed but I’m unsure. Thousands of dollars put into my xj700 and I’d love to just appreciate it fully
  4. Oblivion
    Oblivion Active Member
    Northeast Illinois
    Carb sync can make a HUGE difference. If you were closer, I'd lend you my Carbtune Pro. AND ColorTune. I know they're expensive upfront, but I'm so glad I made the purchases years ago. Good luck.
    I keep forgetting to post - rode to a nice coffee meetup on Saturday and the co-owner of the coffee LOVES the '80s I-4s and talked to me for a good half hour about my bike.
    Then Wednesday, my kid and I rode to the local car meet and there happened to be quite a few bikes there this time. A guy I remember from last year was at least a couple beers in and told me about his '81 Seca. He even still had pics on his phone even though he sold it in '91. Funny thing is he got it at the same dealership mine's from.
    Continue to have a crunchy starter when the engine's hot and also a hanging oil light. I did do an oil change last week and didn't see anything concerning in the oil. Right now, I'm just riding it to meetups and doing the daily on my WR250R until I can dig into it this winter (hopefully out-of-sight-out-of-mind doesn't get me again).
  5. Maxim40
    Maxim40 New Member
    Quebec
    So, the last week I replaced the throttle shaft seals and other rubber bits, also a thorough cleaning . Then color tune and YICS balance a couple of times. Running great now. very smooth throttle response and plenty of power when getting on the highway. Passing is smooth and fast, very quick from 100 to 140Km/h with room for more, but then I realized how fast i was going in a 100 zone. Also, today new Dunlop D404 tires. Last week I noticed that my tires were 13 years old so took care of that before getting back on it today. These new ones really grip on the curves.
    Amazing how quick these bikes are for a machine that's over 40 yrs old.
    Fuller56, Brhatweed and Oblivion like this.
  6. Oblivion
    Northeast Illinois
    Rolled past 42,000 miles on the way home from work (and looking at another motorcycle - shhh, don't tell her).
    Brhatweed likes this.
  7. Brhatweed
    Mora MN
    Added some cheap replacement signals to my SECA. Not the most elegant but they work and they're not busted and taped on.
    Timbox, ksigurdsen and Oblivion like this.
  8. Donglord
    Donglord Member
    Arkansas
    After 5 months of nothing but problems and headaches, I finally got my 86 maxim x700xs running like a top. Valve adjustments, carburetor cleaning, complete rewire, any many more things have been done to this bike and I have this forum to thank for that. My grandpa built choppers for fun before he passed away, so I feel I need to keep the family tradtion alive. I was a total mechanic noob before, and this bike has taught me so much. Thanks to all who have helped me get this thing going. I'll see you on the road
  9. Maxim40
    Maxim40 New Member
    Quebec
    Finally got around to the steering head bearings. It was a big job for me because arthritis forced me to do it in stages over a couple of days. But it's done, thanks to the abundance of info from this group. Brand new roller race bearings- what an amazing difference. There were a lot of divots in the old races and it was grabbing in a few spots. Very smooth now and better control in the tight curves.
    That was the last thing left to do on this bike because it runs great, it's reliable and a blast to ride. The way it sits now, it should last another 40 years! I suppose I'll have to leave it to someone in my will, like owning a parrot or turtle.
  10. Secacsm89
    Secacsm89 Member
    Still trying to get my 750 RH running with rebuilt carbs. Later plan on going to get a vacuum pump at the local auto parts store (loaner tool) to finish (hopefully) bleeding the front brakes after the rebuild.
  11. k-moe
    Don't be discouraged if it takes a long time to bleed them. A vacuum bleeder helps, but isn't the only tool needed.
    https://www.xjbikes.com/forums/threads/bleeding-the-xj750-seca-front-brakes.124736/
    If you need help with carb setup, we have that too.
  12. Secacsm89
    Secacsm89 Member
    The portable power vacuum pump still isn't allowing me as get any pressure. Got the brake handle pressing on the handle while bleeding them. Trying all the bleeder screws including ,the anti dive . Haven't rebuilt the anti dive system as of yet.
  13. Brhatweed
    Mora MN
    Relax the handle completely while using the vacuum bleeder, piston in the bore of the master that's beyond the return port won't allow fluid to pass from the tank down assuming the little hole is clear.
    On my end I passed the 49,000 mile point on my SECA 750
    Oblivion likes this.
  14. Oblivion
    Northeast Illinois
    Today, I added to my Yamaha collection. Up to 5 two-wheeled contraptions now.
    1981 XJ750 Seca
    1997 YZ80
    2007 Vino 125
    2008 WR250R
    And now *drumroll* . . .
    2015 FJR1300ES
    I LOVE it. The silly thing only has a little more than 2k miles on it. I've already changed the oil and final drive. Will get to brake and clutch fluid this weekend.
    Some pics: https://www.instagram.com/p/DOKYZEIgDcb/
  15. Fuller56
    Fuller56 Well-Known Member
    Congrats on your new rocket ship. I bet your license is cringing in your wallet realizing how often it is going to be coming out to talk to the officer....
    Timbox likes this.
  16. Simmy
    nice!
  17. Oblivion
    Northeast Illinois
    I've yet to have one of those talks on a bike *knocks wood* Guess I'm overdue. On the commute in to work, I was using the cruise control primarily to keep from creeping up faster and faster. o_O It's like butter at 80 (allegedly), and pretty darn quiet, so I'm going to have to re-calibrate after being on the screaming/naked Seca. I did one takeoff from a light in Sport mode (been keeping it on Touring) and might have peed a little.
    A few pics attached:
  18. Oblivion
    Northeast Illinois
    For one weekend, I didn't need to do anything to the Seca, but the WR205R got fresh oil, and the FJR got fresh brake and clutch fluid. The brakes were flushed a few years ago, but the clutch fluid was neglected/original 2015 and looked like Hershey's syrup. Luckily the reservoir cleaned up well (didn't get an 'after' pic, though). Might be in my head, but the clutch response feels more precise off the line.
    I also organized my garage a bit to get the bikes together. The YZ80 is still on the other side of the garage, though.
  19. Fuller56
    I learned that our XJ's have 2 different oil level sensors. While researching the sensors here I ran across a thread where 1 of our learned members had posted that the Atari wearing XJ's use 1 a sensor that is read by the computer all the time, the non-Atari wearing XJ's use 1 that is simply a switch. I discovered I needed to know this because my 750J is wearing the wrong one. Examining the 5 sensors I have revealed the Atari sensors have a red wire the non-Atari sensors have a white wire. I am hoping @chacal will chime in shortly and confirm this, or tell us I am not as smart as I think I am. So, I am in the process of changing out the sensors.
  20. Brhatweed
    Mora MN
    Ones is normally open and the other normally closed. The atari requires the OIL line to go LOW as it's biased with a 5V reference which in turn triggers the logic to flash the OIL message and blink the WARNING light when it goes HIGH or open while the others need to close the switch in order to complete the circuit for the OIL light.
    The way you can tell is by flipping the sender upside down to simulate a full oil pan and check its state with an ohmmeter, closed will be the atari sender provided the magnet is still good. They use a reed switch with a magnet on a float that over time gets weak and doesn't always pull the contacts together.
    Fuller56 likes this.
  21. Oblivion
    Northeast Illinois
    Today I rode my Seca for the first time in a week after riding the FJR every day since getting it. For the first minute, the ergos, especially the handlebars, felt weird. It was loud, smelly, slow, clunky, and archaic compared to the FJR. And it felt like home and I still love it.
    Some kids in a brand new Tesla wanted me to race them. I knew better. They asked if I could wheelie. I demurred.
    SecaMaverick, Brhatweed and chacal like this.
  22. SecaMaverick
    SecaMaverick Active Member
    Northeast Ohio
    Most nice days during the spring, summer, and fall in Ohio, I alternate riding my FJR and my Seca to work. You're right about the obvious differences between the two.
    I still really like my FJR after owning it for nine years, but the Seca -- which I've had for 24 years -- is easier to flick around. I find myself smiling more on the Seca, and concentrating more and working harder riding the FJR. (I'm sure it's related to my skill level.)
    When I park the FJR, I'll get off, pat the seat and say, "good work."
    When I park the Seca, I'll get off, pat the seat with a smile and say, "good girl."
    Timbox, Fuller56, Minimutly and 2 others like this.
  23. Cheri Lynn
    Cheri Lynn New Member
    Vancouver Washington
    Today I replaced the mc on my 82 xj650 and will bleed in morning. I have a new clutch perch and gas cap arriving tomorrow as well. Excited to get this installed, I do not want to burn out my clutch more than I have.
    I all of a sudden have a bad wobble after dropping the bike and hitting a bump that same day. Someone told me to loosen the lower pinch bolts on forks and really bounce it up and down and then retighten to torque. Has anyone of this before? I can do all the engine maintenance, but I don't do forks and such.
    I am in Sw Washington state if anyone is close by.
  24. Simmy
    That was sound advice on the pinch bolts.
    Something anyone who’s riding a bike should do unless you know for certain you tightened them or Yamaha did.
    Hitting a bump while slightly out of position can wobble any bike. Was it just an occurrence or is it repeatable?
  25. chacal
    Well, the answer from Brhatweed is correct....but yes, the sending unit for the computer-monitoring dashes has a red lead wire, and all of the others have a white wire.....kinda clever that Yamaha thought to make that distinction for ID purposes (because otherwise they look the same).
  26. Fuller56
    I guess most folks are out riding their XJ's, not working on or messing with them. Sunday saw the '80 650 Maxim get out for the ride to White Birch Airport for their last breakfast of the season and get introduced to Chuck. Chuck is a riding buddy for about 40 years or so. He currently rides a Honda CTX700. He said Jersey Maxim is "like a puppy, just wants to go play". Then home to work on brakes. Assembling the front brakes for the 650RJ, calipers previously cleaned and reassembled with new seals got installed with new, steel lines and bled out fairly easily. Then on too cleaning a 750J caliper for another project. A delightful XJ day. Some riding, some XJ puttering.
  27. Brhatweed
    Mora MN
    I've put more miles on my XJ this year than the car. Total reliability and far more fun than my ex...
  28. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Took a look at Google Maps and see my red XJ700 parked in my parents driveway, in street view mode XJ700 in Google Streetview.png .
  29. Oblivion
    Northeast Illinois
    Commuted on the Seca for the first time in over a month (got my FJR month ago today, coincidence or ???). I've been leaning towards the FJR not only for newness, but because it's been DAMN HOT, and it's just slightly more comfy than the Seca. But today should stay in the 70s, so she got to stretch her legs.
    Anyone in the WI area doing the Slimy Crud Run this weekend? I'm not sure I can do the whole thing, but I may at least make the run up to Pine Bluff and back (from Crystal Lake, IL, we should have a small group). Need to pick a bike.
  30. Brhatweed
    Mora MN
    Added another set of those cheap lights to the back of my 750.
  31. Brhatweed
    Mora MN
    ...and it's parked & pickled for the winter. Got too much going on at the moment and the weather isn't being cooperative so I drained the tank and carb bowls and shot some oil in the jugs before pulling the battery and parking it in the garage on the center stand. Not a bad year really considering the bike is at 49,709 miles, I'm satisfied with the season. Next year is going to be just as good. Got newer rubber all around and a fresh oil & filter, battery is on the shelf with a small 100 ma charger that's on a timer set to come on for two hours each week. Once I can see over the snowbanks and the temps are in the upper 40's I'm on the wheels again.
    So when I drained the tank I used a 60ml syringe with a length of hose to suck out the little puddle in the lower pockets and came up with a bunch of crud, surprising really in that I did the same last year and thought it was clean, not happy with the quality of the gasoline considering it's "supposedly" filtered before reaching the nozzle, guess some of the stations don't do this.
  32. co.dirtbiker
    co.dirtbiker Active Member
    Colorado, USA
    Took the 900 out for a little spin last night for the first time in about a month. We're still getting nice riding weather here, but it won't be long before the snow starts flying. She started right up as usual and was a pleasure to ride...except...I'm still having an issue with random stalling while riding due to fuel starvation.
    I initially thought it was a fuel line routing issue essentially causing a "vapor lock" because it went a little uphill after exiting the tank, but I had cut the line shorter so that it has more of a downhill slope and that didn't seem to help. I don't think it's a venting issue either since opening the cap doesn't help. It happens at odd times, like after I have been riding for several miles, and usually on a mild incline. Switching to PRI and cranking for a little while gets me going again, so now I am wondering if maybe there is an intermittent vacuum leak that is causing the petcock to close sometimes. If it was just air in the line, you wouldn't think switching to PRI would matter.
    Maybe I'll fiddle with it more this weekend.
  33. Franz
    Franz Well-Known Member
    Scotland UK.
    Is the vacuum hose in good condition and the caps all secure for the carb synch hoses?
  34. Rooster53
    North, FL
    I seem to remember someone reporting non vacuum line would sometimes collapse after heating up?
    Minimutly likes this.
  35. Franz
    Scotland UK.
    Mabe deterioration due to age.
  36. Fuller56
    Nothing done yesterday as far as working ON an XJ, but another 650RJ climbed into the back of my truck and followed me home. A bit rough and neglected and the last inspection sticker is from 2002 but with a bit over 13k miles showing and the aluminum bits not being corroded or dirty it has lots of potential. Lots of proper original parts in reasonable condition it seems to have slept indoors and protected most of its life. The pretty original headlight is gone though. Drat!
    Brhatweed, Dan Gardner and Huntchuks like this.
  37. Brhatweed
    Mora MN
    Guess I need to get a pickup truck huh?
  38. Fuller56
    @Brhatweed, if so, for catching roaming, feral XJ's it is easier to have a smaller, lower pick up. Mine is a GMC Canyon 2 wheel drive and is nice and low so it is easier to them to climb into. It has nice sturdy tie down points in the corners of the bed from the factory so they can't easily escape once snared.
    This is a bad news, good news deal. The bad is no title and likely will be an organ donor. The good news is that the organs appear to have been well stored. As the seller advertised the engine turns over, too easily though. And the good starter is not connected to the internal engine parts. I might be able to fix that but for no title...... probably not worth it. I can use lots off it so that others may live and be loved.
    Dan Gardner likes this.
  39. ScottFree
    ScottFree Active Member
    Northern Ill-Annoy
    What I did to my Yamaha today... took it for a nice ride to see get ice cream and see fall colors:
    The other purpose for the ride was to put stabilizer in the gas and warm up the oil enough to change it. Winter is coming--it was 80º on the 17th, 53º on the 24th. I have to remind myself that 53º is actually pretty close to average for late October; the long, long end to summer has spoiled me.
    I only put about 800 miles on the Yamaha this year because I've been playing a lot with my new toy, a Royal Enfield Himalayan 450 I bought just about a year ago. That bike now has 9400 miles. On top of that, the Slimey Cruds fall weekend, when I would normally take off for a multi-day ride around the Driftless (and the weather this year was perfect for such a ride), was pre-empted by my 50th college reunion.
    I also came close to doing something kinda clever:
    Missed 12345.6 and 789.0 by a tenth. Seems the trip meter reset is a bit sloppy, and the first tenth after a reset is more like 0.15 miles before the trip meter moves. Oh well. Close... I kinda doubt I will have a chance to get it to 98765.4 and 321.0--not because I doubt the bike will run that long, but because I'm already 71 years old and would need to put 15K a year on the bike to have much chance of reaching that.
    I feel I've neglected the Yamaha a little bit this year, and that next year I should make a point of riding it somewhere like down to the Ozarks or to Deals Gap. I think this bike would be a hoot on something like the Pig Trail or Push Mountain Road. It remains a nice bike that brings a smile every time I ride it.
  40. Secacsm89
    Secacsm89 Member
    Wasn't today but yesterday. Tried to install the carb. couplers to the air box (Stock) with not much success. Not a whole alot room to work with. Even heated the rubber.. I will keep trying soon.
  41. SecaMaverick
    Northeast Ohio
    @ScottFree, I don't know if you've gotten past this issue since you posted mid-year, but whenever I see someone mentioning it, I chime in with my experiences.
    I used to have that issue nearly every time I started the bike after it sat long enough for the carb bowls to fully evaporate. After literally YEARS of dealing with it by just shaking the bike a bit until it quit puking gas, I finally decided to look at the float SAG in each bowl.
    Turns out a couple of the floats were hanging too low when empty, which hung up the needle valve so it wouldn't seat when fuel reentered the bowls and the floats tried to lift. I bent the tangs so the floats couldn't drop as far, and I haven't had even occasion of a carb overflowing in the two years since.
    Such an easy fix, I don't know why it took me so long to do it.
    Jerry76, Fuller56 and Rooster53 like this.
  42. Jerry76
    Jerry76 New Member
    Rock springs, Wyoming
    New member here, I took my XJ1100 Maxim for a ride a few weeks ago running great, then started it a few days ago to run stabil through it for winter here in wyoming and it was very rough. Found cyl 1+4 were cold. Thanks to postings here i found my coil reading 31k instead of 20k. I ordered a couple used ones from ebay and been cleaning up things under the tank until the new one arrives.
  43. Fuller56
    On the recently acquired 650RJ I finished repairing the aftermarket fuse panel install and repairing the mouse chewed wires leading to it. Crimp on connectors not crimped, just slid on the wires and taped there. Now crimped, soldered and shrink tubing insulated. Then what I believe to be its first ever valve clearance check. 7 of 8 valves were 1 size shim too tight and several of them were very difficult to remove from their buckets. Just under 11k miles showing on the odometer. All good now.
    SecaMaverick and Franz like this.
  44. Simmy
    pics?
  45. Fuller56
    @Simmy, okay, I can get pics as soon as it gets its clothes back on. Just your basic XJ650RJ though that has not been well loved, yet.
  46. Fuller56
    And another 650RJ no title organ donor sold as "the engine turns over". Yep, it sure does with little to no compression. I found the cam to sprocket bolts removed, gone, not there. So everything turns pretty freely but I am expecting some bent valves..... The things that unknowing folks do to these poor bikes. And at 13k miles!
  47. ScottFree
    Northern Ill-Annoy
    Funny you should post this when you did... 23 hours later, I pulled into the gas station to meet a friend for a lunch ride to the brewery on an absolutely beautiful, sunny, 60º day... and found my #1 carb overflowing again. Well, that explains why the bike had been running badly on the way to the gas station (it had been running just fine when I took it for a 90 mile ride the previous day, of course). No amount of rapping on it stopped the flood, so plans changed: my friend followed me home as I manually controlled the fuel by flipping the valve open when the bike started to stumble, closing it after about ten seconds (before #1 had a chance to fill up and overflow), continue with the valve closed until it started to stumble, repeat, repeat... I knew there was a reason I re-worked the valve for full manual operation instead of vacuum control a couple years ago. Coasted into the driveway as the engine died, picked up one of the other bikes and went for a very pleasant, if slightly delayed, ride.
    I had drained the carbs with the intent of putting the bike up for the winter a couple weeks ago, but when we had a week in the high 50s/low 60s, I decided to take it out again. The carb didn't overflow on Thursday, when I went for a long-ish ride, but on Friday. The bike started showing symptoms of a fuel issue right after I put it on reserve about ten miles from home. My working hypothesis is that I got a piece of debris that's jammed the float valve open (back in the '80s, my Harley did this--a piece of rubber came off the inside of the fuel line and got stuck in the float valve), but when I get the rack off and open up the carbs I will look at the sag issue as well. And, I suspect, finally get around to buying some of those disposable inline fuel filters...
    In other "What did you do to your Yamaha today?" news, this week I installed these things:
    National Cycle "Hand Deflectors," clear plastic hand guards to keep the wind off my paws. Combined with the bar-end mirrors, they probably extend my comfort zone by close to ten degrees. They're made for Harleys (these were originally on my Road King, before I replaced the stock windshield with an aftermarket batwing fairing), where they attach to the mirror stalks. I attached them to my Yamaha by replacing the stock clutch and brake lever pivot bolts with longer metric bolts and tubing spacers:
    The bolt threads into the lever mountings and tightens down on the spacer (allowing the lever to move normally):
    and the hand guard then attaches to the underside with a nut:
    Easy-peasy, though I think I will probably put a star washer between the hand guard bracket and the lever mounting, to keep the hand guard from slowly moving under wind pressure (I think I had to do this on the Harley when I ran them there).
    The other thing I did to my Yamaha was spend about a half hour fiddling with the rear brake switch adjustment. I never checked it after I installed my lowered footpegs and new brake shoes, so of course it was on all the time. Got it working right, but it looks like it's showing its age. It also looks like a pretty generic switch, so I ordered a generic replacement for all of twelve bucks. The replacement comes with a new spring, which I think is half the problem I'm having--the hardware-store spring I installed to replace the broken original one isn't the right size or shape and I think it can bind on the frame and hold the switch on.
    Don't know for sure when I'll get into the carbs. I don't want to pull the rack on a cold day because I don't want to risk cracking the rubber ducts between carb and airbox, and if we get a warm day in November I'd rather spend it riding... decisions, decisions...
    Brhatweed and Simmy like this.
  48. Fuller56
    A couple of years ago I traded and got a Turbo that had only about 2500 miles on it because multiple shops and owners had not been able to fix the very same issue. Carburetors had been done several times and had aftermarket float needles. Being a tiny bit different size from the original Mikuni parts they were doing the not sealing due to too much sag thing. I read about someone else having had that problem so I cannot take credit for finding the fix. But fix it, it did. I was thrilled, I had worked for about 2 weeks trying to wet set the float levels and not have the overflow problem.
  49. Blaž Podbevšek
    Blaž Podbevšek New Member
    Slovenia
    Hello, i went thru a nicotine withdraw and with bad concentration made a really stupid mistake. I am very embarrassed about it…(especially because i am an Mechanical engeneer by education…)
    I have recently rebuild the YAMAHA XJ500 1981 (bassically a rare European version of XJ550, seca, etc.), picture bellow:
    The rebuild took time, my battery died (before rebuild and during it motocycle ran like a dream).
    I connected electricity to start it up from a running car and without battery in the motorcycle…it didn’t start, then i connected cables from a car backwards (switched +/-)to the motorcycle (still without the battery on the motorcycle)…
    BEFORE I REALISED WHAT I HAVE DONE, IT WAS TOO LATE..
    I then changed regulator, ignition coils, CDI , FUSES all 5, starter relay solanoid.
    now it cranks up, has spark but will not run or start. If a crank it for a really long time it fires on a cilinder or two, wont rev and then dies. I suspect missfiring?!
    I tried to find solution for 2 months now..but couldn’t
    IF SOMEBODY HAD THE SAME ISSUE PLEASE HELP ME, I AM DESPERATE…(and extremely embarrassed)
  50. Brhatweed
    Mora MN
    Well it cranks and has spark so that's a sign of life, lack of fire is most likely a lack of fuel as you have two out of three of the needed vrroomm vrroomm ingredients. This is however assuming the spark plugs are good and the valves are properly set, are both coils firing?
