EXC525
Discussion in 'Other Motorcycles' started by Simmy, Apr 22, 2024.
  1. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    I dedicated Saturday to my long neglected dirt bike.
    Really haven't ridden it much in the last 2 years but hope to change that.
    I couldn't figure out why the electric starter struggled to turn the motor, relying on the old-fashioned kick lever.
    At 63 I need the push button, kicking a 500 is a beastly task even for the young.
    I had already changed batteries and tried boosting it so that was not it. A mechanic suggested the auto-decompressor malfunctioning so I looked there.
    After pulling the entire valve cover off I had a good look at this.
    Many bikes & ATVs have similar arrangement, the cam shaft has an eccentric tab which protrudes and keeps the exhaust valve slightly open at zero to very low RPMs. As RPMs increase centrifugal force tucks the tab in place and compression is restored.
    Very simple stuff so I put the cover back in place and went to rechecking the valve clearances, this is done by small removable covers over the inlet and outlet valves.
    I found all the valve clearances were too large. After putting the clearances in spec (threaded adjusters) I tried the starter and it spun like new, awesome.
    What I conclude from this is that the clearance was large enough to negate the auto-decompressor.
    I'm waiting for a water pump gasket so I haven't had chance to test it yet.
    Spent another 2 hours converting it into super-motard, haven't ridden it in that config for a few years.
    Fuller56 and chris123 like this.
  2. Simmy
    Thinking about this some more, that was my stupidity adjusting the valves last time.
    You can’t just position the cam past the lobe like an XJ. A motor with an auto compression release must be positioned exactly TDC on the compression stroke so you’re not sitting on the auto-decompressor. That’s obviously what I did last time.
    The auto-decompressor opens the exhaust valves on the way to full compression, but once at full compression the valves are closed again.
    Franz and Timbox like this.
  3. Timbox
    I agree with you on the bikes that are kick start. I refreshed a XR650 a few yrs back, 1989 model that had the two carbs. One being the chock ckt and the primary jet and the other carb just for the main jet after half throttle. If that bike had an electric start it would still be in my stable.
    Went back with a 1st Gen KLR650 and put a 685 kit it it. That bike was sweet. I think my days of riding any of those dirt or on off bikes is behind me. I sold the KLR this spring.
  4. Simmy
    I just rode my KLR to work this morning. My brother turns 70 this year and he still rides a KLR, KDX and YZ250.
    As long as he rides off-road I need to keep up.
    I have a cousin 64 still running competition enduros, he is crazy.
  5. Simmy
    I forgot what 50 hp and <300 lbs feels like on the street, can’t be legal
    this is my school from grade 1-4
    Not even sure it’s public anymore
    Timbox, Rooster53 and Roast644 like this.
  6. Simmy
    We’ll here’s a first, last night my bike was eaten by a squirrel, said no one ever LOL
    I bought this tank 20 years ago
    Just found out Clarke is still in business and replacement caps are $18
  7. Dave in Ireland
    Ireland
    Mmm... yummy plastic.
    Weird how some rodents love some plastics.
    Some of them cause house fires because of that, too.
  8. Simmy
    I rode the bike all day Friday, then went out dirt riding with my son today so I left it outside in my backyard Friday and Saturday night.
    The city squirrel wanted gasoline.
    Glad he chewed the cap instead of a corner of the tank
    chris123 and Timbox like this.
  9. Timbox
    I have a mechanic friend of mine that says same happens to the cars. Mice like to chew on some cars wires and others they leave alone. I remember reading that some of the coatings and or plastics have some chemical or compound in them our chewing pests like. Nature is weird, all them pets have to chew or their teeth will grow to the point they can't eat anymore.
    Sorry for the cap but yes good thing it was not the tank.
    chris123 likes this.
  10. Simmy
    I'm going to be attending the Grand Bend Festival of Speed Oct.3rd to 5th.
    I registered to do the track lapping, 4 sessions of 1/2 hr each, all for $80.
    Bikes must be 2005 or older. My KTM happens to be an 05 so planning to take it road racing in supermoto trim.
    Fingers crossed for the weather to hold.
    If the forecast is nice I might take an XJ for show.
  11. Simmy
    I spent long overdue time rebuilding my trailer, installed new plywood decking including adding another rib where the front tires sit.
    I have mounts to move Pingel wheel chocks for 1 bike or 2.
    Where the bolts penetrated the plywood they were wasted to the diameter of a wire.
    Disaster avoided!
  12. Timbox
    Not too sure that Canada uses salt like they do in Wisconsin in the winter? I know the salt really takes a toll on bolts and trailers in general.
  13. Simmy
    In Ontario I think the formula is equal parts salt to snow.
    Our Western provinces have days too cold for salt to have much effect so they use sand then.
    This trailer has had very little winter use. 20 years sitting in the weather soaked the boards and kept the bolts wet.
    I stained then sealed the wood this time.
    20 more years will get me to 84, that's probably a good time to give up trailering dirt bikes.
  14. Timbox
    Nice, that seems to work out well. Always good to have a good handy trailer around.
  15. Simmy
    So I made it to the Grand Bend Festival of Speed.
    This is a great event.
    The dragstrip had a huge turnout of pro-stock and dragsters going all day, there was a sports car club racing the road course as well as the bikes.
    My 525 Supermoto was working real nice on this track, one rider on a full on 750 Norton Atlas race bike was the only guy giving me trouble, he slowed me down in the curves but on the back straight he had just a little more top end so we diced back and forth.
    I knew the other guys in his pit and they were razzing him for getting beat by "the Supermoto guy"
    We had a big laugh when I said I was the supermoto guy.
    There was even a guy on a 550 Maxim on track, good on ya if you're here on this forum. You're puffing some smoke BTW.
    The sidecar racers were giving rides to anyone interested in being the monkey but they were taking it pretty easy.
    The bike show on Saturday was good. I got talking with one guy who had a bunch of bikes in it.
    He had Kawasaki 500 and 750 triples, an RG500 Suzuki Gamma and a CX500 Turbo, all bikes he bought new.
    I had a good long talk with the guy building these 550 Secas for Period 3 racing.
    We has a plan to use XJ650 pistons and sleeves in the smaller block, I think he said it would be a 707 but not sure, he was talking too fast.
    They actually had 3 550 Secas, there's 2 in the pics plus the street hot rod.
    He said no one would ever guess the frame it started with - YB100
    Yamaha YB100 with 550 Seca motor swap
    Dave in Ireland, Timbox and Fuller56 like this.
  16. Fuller56
    Fuller56 Well-Known Member
    The YB100/550 certainly is the definition of "hot rod"! It looks like a 550 that has spent too much time in the gym and chugging steroids, but then again, that is exactly what it is.
