Stuck and rounded oil filter bolt
Discussion in 'XJ Technical Chat' started by CrazyBrit, Oct 2, 2025.
  1. CrazyBrit
    CrazyBrit New Member
    Tri-cities
    Got a rounded oil filter bolt. Impact wrench just spins. Ordered a new bolt to replace it, but I still need to replace the filter. What's the best method to get it off?
  2. Timbox
    Welcome to the forum.
    I don't know what your wrenching skill set is, or what type of tools you have. There are many different ways to make the bolt have a shape that can take a wrench or socket again. Order a new plug, as the one you have will not be going back on the bike.
    You can file or grind down the round of the bolt to give an area to put a wrench on again. Once you are able to get a "grip" you can use a little heat on the bolt before you try to remove it. Hard area to work in, just make sure to keep the case of the bike in good shape. I am sure some more folks will chime in with some other ideas as well. Good luck.
  3. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    As Timbox suggested you need to grind some flats on the head so an adjustable wrench fits.
    Failing that I've had to completely grind the head off on one occasion.
    If you damage the filter housing don't worry too much about it, cheap used replacements are easy to find.
    Heat will not be a realistic option as the threads are 4" in, heat will only get the head hot.
    Timbox likes this.
  4. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Stilson ftw. Unless it makes it worse of course.
  5. Franz
    Franz Well-Known Member
    Scotland UK.
    Or one of these.
  6. cds1984
    You'd think those rotten buggers could have put 15 or 17mm head on that thing Sheesh.
  7. Dan Gardner
    Minneapolis, MN
    Others may correct me, but I believe early models had the 12mm head, but at some point they realized that was a bad idea and increased the size to 17mm or something.
  8. Franz
    Scotland UK.
    I have used this before for rounded bolts because you can get it very secure with the fitted bolt. Might work its worth a try.
  9. CrazyBrit
    Tri-cities
    Thanks for the tips y'all, imma see if my Dremel will make a some contact point to monkey wrench that sucker off. That pesky lil 12mil is stubborn
  10. hogfiddles
    You can always grind the head off, and then carefully grind through the shoulder til the housing pops off. The spring inside will make it do that. If you end up screwing up the filter cover, there are plenty available. The 650, 700,750,and 900 all used the same cover. If you can’t find one, I have several right here in NY.
    dfox
    ksigurdsen likes this.
  11. Simmy
    just think how tight the DPO could crank it in with a 17mm.
  12. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Or stick a 1/2" nut over the bolt head and plug weld in place.
  13. cds1984
    Well there is that. Haha good point.
  14. cds1984
    You know imperial is exact and I wish I could think it properly but I was born in a metric age, unfortunately, I use metric.
    The simplest example of imperial being superior is when you talk in 3rds. I'll stop now as our world with computers has become all about rounding.
  15. Roast644
    WASHINGTON
    I use them both, and they both make sense. I do like the unit size of imperial measurements as they seem more practical. But my first rig was a VW bug and I had metric tools before I had standard. And feet and inches are commonly divided into tenths, especially in surveying just to make it interesting! Using a 250' tape with fractions on one side and tenths on the other has bit me more than once.
  16. Rooster53
    North, FL
    I used these allen hex sizes at work for years and got used to them, but having started out on UJM I thought it was a crazy way to mark tool size 050, 1/16, 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16.
    I like metric for tools as it seems much easier, although I also like the tenths in the SAE when measuring tight tolerances.
