Power Lock Key
Discussion in 'XJ Technical Chat' started by xJoJo, Jul 7, 2006.
  1. xJoJo
    xJoJo New Member
    Halifax
    Hi All,
    I just got myself an 81 XJ650, and it's got a power lock on it that hasn't been used for ages. I'd like to make some use of it, but I can't get it disengaged from the bike. My main problem is that I don't know if it's siezed or if I'm missing the key. Does anyone know whether or not the power locks were keyed the same as the ignition?
    Thanks,
    Casey
  2. richard03
    richard03 Member
    Texas
    What is a power lock?
  3. woot
    woot Active Member
    below the left hand side cover on the maxim is a chain... IRC it has powerlock written on it. It's locked to the frame at the moment...
    looking for a picture.
  4. woot
    woot Active Member
    I found a side view picture of a seca that appears to have the same lock mechanism.
    From what I can tell it is a length of chain in a little cubby... the end of the chain is locked to the frame. You can't get it out without unlocking it. I don't think I ever did unlock it...
  5. jdrich48
    jdrich48 Member
    Smithfield, North Carolina
    Mine is keyed the same as my seat lock, fuel cap, and ignition.
    I would shoot it full of your favorite bolt loosener ie. PB Blaster, WD40 or something similar. Let it soak some and just keep working the key in and out and try turning it gently.
    Good luck
  6. xJoJo
    xJoJo New Member
    Halifax
    Thanks, I'll give that a try! I was mostly concerned about mucking up the key, if it wasn't the right one :)
    Casey
  7. woot
    woot Active Member
    I've got some nice high quality penatrating oil at home... we'll put some shop rags around it and give it a blast.
    The other thing I need to find is my tub of short bolts... licence plates need mounting properly on both bikes. The cbr's is zip tied!?!
  8. jdrich48
    jdrich48 Member
    Here are a couple pics of the power lock.
  9. Robert
    Xjojo, I would suggest highly that you consider having a couple of spare keys made up before you try to use your only original on the lock just in case you end up buggering up the key.
  10. xJoJo
    xJoJo New Member
    Halifax
    Yeah, I've got a spare in line already, I've just got to get it from Woot first :)
  11. woot
    woot Active Member
    A thought on this.
    When I brought the bike, the gas tank cap had been drilled. When trying to get the key to work in the power lock recently it wouldn't slide in all the way - even after freeing it up so it slid in that far easily.
    I'm wondering if the PPO (previous previous owner) broke the key off in the lock - needed gas so drilled the lock.
    This would also explain perhaps why I had one yamaha key and one cut key.
    Any ideas on how to verify this theory? Any way to remove a broken bit of key?
  12. Robert
    A small hook and a lot of patience. I've seen this nifty barbed hook the locksmith uses. Another option is to thin down the profile of a hacksaw blade (side opposite of the teeth) and viola, you have a thin, hooked tool. Expensive way is to pay that nice man at the locksmiths shop to "tuneup" the lock.
  13. Nick
    Nick Member
    Vernon, BC Canada
    Locksmiths also use an extraction tool - basically a small diameter wire with spiral groves - it's threaded in along side the broken key and then pulled out hopefully taking the broken key with it!
    The lock has to be in the normal position for key insertion/removal, the tumblers inside have to be free ( not gummed up or rusted up ), and usually given a shot of lube prior to using the extraction tool.
  14. RickCoMatic
    Fabricate a tool from the heavy gauge copper wire in a short length of Romex cable. Do some "Black-smithing" and make 2 "probes" with sharp points slightly angled to move the key fragment.
    You have to slide your picks under each side before moving the fragment.
    The idea is to eventually get your picks close to the tip of the key and drag it out.
    When you feel like you have it ready to move ... have somebody shoot a shot of WD-40 in there and "massage" it out.
    If you get it out and it does work with your key ... you can take your key and the gas cap to a locksmith for fixing the gas cap to work with your key; again.
  15. woot
    woot Active Member
    Thanks... I'll have to see what xj jojo wants to do of course.. it is just a mystery that'd I'd like to solve.
  16. jdornski
    jdornski New Member
    BC,Canada
    I had a similar problem with the power lock, and thought I had mis-matched lock and ignition key, but I discovered that the key has to turn only about 1/8th of rotation to unlock. Is the power lock standard issue with an XJ650J? It looks like the plastic cubby holder for the lock chain would hold the tool kit. Does the tool kit live under the seat normally?
  17. cgutz
    cgutz Well-Known Member
    SE South Dakota
    The chain/lock that came with my XJ550 is still where it was when I bought the bike brand new from the dealer. Hasn't been used but once or twice the first year I owned the bike. It did use the ignition key.
    Not sure how secure/strong these chains are? Looks like it might only be a speed bump to a thief.
    kerriskandiesinc likes this.
  18. XJ550H
    yes the chain lock was issued with most xj's tool kits go under seat. 83 seca 900 there seems to be a box listed in fliche with side covers
    550 maxim has a chain box at rear of seat under grab bar.
    lock storage differs on the bikes
    the ignition gas cap, helmet lock , chain and if you have one chain box all have the same key.
    keys are lost over time and things replaced with non matching sets
  19. kerriskandiesinc
    NY
    I believe the Powerlock came with almost every early <85 XJ??, I've certainly seen them on Maxims (American) XJ650 Secas (European) XJ750's and all in between......NEVER on the 900/550..but, I might be wrong...
    PS I'd never think of using it....too feeble, too skinny to be of any real use (maybe a 'helmet lock?)
  20. kerriskandiesinc
    NY
    Never knew it was on the chain XJ's too! (never owned one!)
    What about the 900's.....??
  21. XJ550H
    it just stops someone with out bolt cutters from rolling the bike away and into a van or truck. stearing head lock helps too. nothing is a garentee against theft if someone is determined to steal the bike
  22. kerriskandiesinc
    NY
    I dunno.....it always seemed skinny enough that the weight of the bike probably WOULD have snapped it!
    Still....a very admirable attempt by Yamaha, certainly in the early 80's.......
    I can't think of ONE other manufacturer, who ever gave us a lock/powerlock/disc lock, with our bikes (NOT scooters...).......anyone like to prove me wrong ( again!!)
  23. cgutz
    SE South Dakota
    I lived in Chicago area my first year, used it then. Still have the bike, so it must have been some deterrent.
    While at work I use the steering lock, but live in small, Midwestern town, so theft isn't too big a problem.
  24. XJ550H
    90% H-D owners around me short of leaving the key in it and running I think I am a low value target
  25. kerriskandiesinc
    NY
    You lot are lucky!!
    UK...any major European city....or not so major, I've had bikes with ABUS Granite, German high security chain, and disc lock stolen!!
    here in the US...even NY....seems a lot less likely to go missing!!
    My last UK bike had immobiliser, disc lock and security chain......kept that.....but then again it WAS a Suzuki ! ;)
  26. cgutz
    SE South Dakota
    Harley worth thousands or 35 year old XJ worth a few hundred to a thousand...XJ not exactly the prime target.
    A chain and/or steering lock would stop joy rider.
    That said, a couple years ago, a yellow XJ was stolen from a forum member from his driveway...
  27. XJ550H
    yes I remember that got it back trashed and fixed it
  28. kerriskandiesinc
    NY
    I'd rather have an XJ than a Harley....but, I get your point !!
    Stumplifter likes this.
  29. kerriskandiesinc
    NY
    One of my XJ's got stolen, Salford UK......lads had 'ragged' it around the fields for days, funny thing was, after I fixed her back up, she never ran better !!
  30. k-moe
    The chains also came on first generation Viragos.
  31. hogfiddles
    A good key smith could pick it then cut a new key for you
  32. kerriskandiesinc
    NY
    I would think so....I'm about to take the Seca Tourer to a locksmith, the original Yamaha lockable 'pods' in the fairing, are locked, no key, and no they aren't keyed alike with the ignition... :(
  33. RideAlong420
    RideAlong420 Member
    USA
    My bike still has this! I was wondering what this was!
    Now I need to figure out how to make copies of my 1 and only key for the bike...Lowes/Home Depot's machines can't copy this key
  34. chacal
    You need a real locksmith with a (older) copying (tracing) machine........
  35. RideAlong420
    RideAlong420 Member
    USA
    I'll have to see what options there are in the area, my area mostly only seems to have roaming locksmiths
