Fuel sending unit
Discussion in 'For Sale, Trade/Swap, Wanted' started by John Stomski, Dec 1, 2025.
  1. John Stomski
    John Stomski My new(Old) xj900
    Queensbury, NY 12804
    Hey, I’m in need of a fuel sending unit. If anyone has one laying around please reach out. Thank you! Happy Holidays
  2. Timbox
    Have you tried taking it out and cleaning it? They are built well and if not eaten away from rust or other, they will come back to life with a good cleaning. Taking the cover off the resister area is needed to clean it right. If you have yours out, send some pics and let us see what it looks like.
  3. John Stomski
    Timbox, I haven’t taken it out yet but the wires are dry rotted. Both plugs broke off. I’m going to try and get into the wiring harness and splice a couple new wire in. Then I’ll pull the sending unit out and try to clean it. Thanks, John
  4. Timbox
    Using a multi meter you should be able to see if the sending unit still work. As for those wires, happens a lot with our older bikes. Still looking for some pics of your troubleshooting and your progress.
  5. John Stomski
    Im on the road a lot so I will post when I get home.
    Timbox likes this.
  6. John Stomski
    Here are some pics. The unit is covered in a tank sealing material. This is not good I really don’t want to spend 400$ on a new one.
  7. Franz
    Franz Well-Known Member
    Scotland UK.
  8. Franz
    Scotland UK.
    Did you test it with a multimeter? You should be able to get that stuff off the float. I don't think it is tank sealer looks more like adhesive, and there is none on the metal parts unless you have cleaned it off.
  9. chacal
    Here's one on eBay: https://www.ebay.com/itm/205797080959
    It's in Belgium, which means you'll have to pay import fees, but that won't be that much, considering the price (probably around $ 30- 40).
    But one thing you should be careful off when buying used sending units, is you should contact the seller and ask them to verify that it is working properly (using an ohmeter). The specs for the 900 sending unit are:
    Full = 2 - 12 ohms
    Half full = 40 ohms
    Empty = 87-102 ohms
    They would just need to move the arm from fully from one "stop" to the other end, and verify the low/high ohms. The "half-full" reading is kind of meaningless and not that important. There should not be any "dead spots" on the readings anywhere along the path.
    Even if the empty and fill readings are off by a little bit (maybe 10% or so?) that wouldn't be a big issue (to me), as the senders and gauges aren't all that accurate to begin with, they're more of a "better-than-nothing" type indicator of fuel levels.
    Timbox and Franz like this.
  10. John Stomski
    Thank you for all your help! I actually found a brand new one in the box for 220$ us. Such a relief because I don’t like have gauges that don’t work. The only issue I have now is the 2 wires coming out of the harness are dry rotted. Time to slice into the harness and add some wire.
    Timbox likes this.
  11. Timbox
    I think it could be saved, looks clean compared to some I have seen. Not too sure what is on the float, could be gas varnish but looks clear like glue or epoxy. Glad that you found a replacement, the wire splicing should be an easy job for you.
    Now is a good time to start to get some tools on hand for other things that might happen to your bike. Always nice to start a tool hord as you will be needing a multi meter and other hand tools down the road.
  12. hogfiddles
    Or a bike horde……:D:D
    Timbox and Fuller56 like this.
  13. John Stomski
    im leaving for florida right after xmas for 4 months. while im gone my friend is painting and restripeing my 900. ill post some pics in the spring when its done. thank you for all your help!
    Timbox, co.dirtbiker and hogfiddles like this.
