Bearing play?
Discussion in 'XJ Technical Chat' started by adrian1, Feb 1, 2026.
  1. adrian1
    adrian1 Active Member
    Hello, 1987 XJ900. With the bike on the main stand U can feel a TiNY bit of sideways movement in the back wheel. Is this normal play between the bearing(s) inner race and the axle or should I be concerned about future bearing failure? Mileage of rear wheel bearings unknown because second hand wheel fitted some time ago… Thanks
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Is the movement in the wheel or in the swingarm?
  3. adrian1
    In the wheel
  4. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    I'd replace them anyway, better than having one grenade on the road. Cheap insurance and Chacal has good quality replacements. As I recall my seca 750 rear wheel had no wobble play when everything was torqued & tightened to spec.
    adrian1 likes this.
  5. Dave in Ireland
    Ireland
    Good quality (Koyo) wheel bearings are cheap, don't fit really cheap ones.
    adrian1, Roast644 and Brhatweed like this.
  6. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Not sure what's in the tail of your 900, but 6203, 6303 pretty universal in millions of bikes. Find the numbers and look for cheap handfuls of old stock, quality bearings on ebay. Koyo, Timken, NTN, SKF. Wheel bearings are typically always standard clearance. C3 indicates extra clearance for hot running bearings (motors, trannys, etc). 2RS (2 seals) are most common and you can always pop out one or both seals depending on the configuration. Handy to have a pile of them in the parts bin.
    cds1984 likes this.
  7. adrian1
    Thanks Roast. Mainly true but there is an extra wide bearing in there ONLY available from Chacal now :)
  8. adrian1
    Any advice from other 900 owners re any sideways movement in their wheels appreciated!
