86' XJ750 Maxim engine (cam chain tensioner?) noise
Discussion in 'XJ Technical Chat' started by borche007, Feb 25, 2026.
  1. borche007
    borche007 New Member
    Macedonia
    Hi Guys,
    My Maxim is producing some slapping noise which I believe is the cam chain tensioner.
    I concluded that after reading a lot of threads on the forum, I could be wrong of course.
    The slapping is more noticeable on hot engine and only on idle.
    When I rev the engine the noise disappears.
    When I engage the clutch, the noise stays the same.
    Question is, can I remove and check if it is stuck cam chain tensioner without removing the carbs?
    What kind of tensioner do I have automatic or manual?
    If someone can send me useful manual pictures about this I will be very grateful.
    Thank you in advance.
  2. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    Well you could check the tech section which is located on the top right of the webpage where it says XJ4Ever, this is considered the bible of the XJ bike world and has basically rendered every aftermarket service manual obsolete. Now do keep in mind the starter clutch is also a known source of idle noise and can easily be mistaken for a loose timing chain being so close in the engine. I believe a Maxim is a manual tensioner however you're working with a 1986 750, the USA had a displacement tariff in those days and our largest I believe was 700cc before this kicked in, maybe someone here can further clarify this from across the pond? The SECA 750 had an automatic tensioner and below is a picture of it on my 1981 XJ750R SECA, its the black object with the large bolt on the end.
    borche007 likes this.
  3. biggs500
    biggs500 Active Member
    Sherwood WI
    The 750 should have an automatic tensioner on it. Yes, you can remove it without pulling the carbs but it will be tighter. Remove the nut at the end of the tensioner first (the spring will pop out) as you need to do this to reinstall the tensioner anyway then the two Allen bolts and it should come right off.
    But seeing as the tensioner is the automatic type this probably isn't the issue. Without actually being able to hear the noise it's hard to say what it might be.
    Brhatweed likes this.
  4. chacal
    Automatic chain tensioners should --- in theory --- never need attention (unless an oil leak develops on it). A naked auto-tensioner looks like this:
    https://xjbikes.com/forums/threads/need-manual-and-auto-cam-chain-adjuster-pics.24597
    However, like any other mechanical device, an auto-tensioner can fail to perform properly, typically due to one of 2 reasons:
    a) the ratchet mechanism has stopped ratcheting, usually due to the internal "works" getting gummed up from congealed oil residue, etc. Solution is to remove the tensioner unit, take it apart (note: the case end bolt....the spring and shaft live behind it....is torqued on there really tight, and you may need to secure the tensioner body in a vice (or similar) while banging away on the wrench / socket you're using. Also note if the bolt is removed, we suggest you replace the crush washer under the bolt head, and of course a new tensioner-case-to engine gasket should be fitted).
    Sometimes you can free-up the ratchet mechanism in an automatic tensioner (without removing the tensioner from the engine) by rotating the engine backwards a turn or two and then rapidly changing the direction of engine rotation. Rotating the engine backwards introduces a fair amount of slack in the cam chain at the rear guide, and tapping on the tensioner case gently during this procedure can motivate a reluctant ratchet mechanism to free itself up enough to ratchet the tensioner shaft forward and resume its proper tensioning.
    b) the round rubber "head" or "cap" at the end of the shaft....which pushes on the rear face of the rear chain guide, can get fractured, cracked, or even end up missing in extreme cases. A tensioner in this condition needs that cap replaced (and it is not a part that is available) or the entire tensioner needs replacing.
    Note you should follow the procedure in the service manual for ensuring proper positioning of the cam chain when removing or re-installing a chain tensioner.
    Pro-tip: if you have a manual tensioner (on all XJ550 engines, 1984-85 FJ600, 1986-88 FZ600, 1986-90 YX600 Radian, 1984-91 XJ600 Euro, 1986-88 FZ600, 1980-81 XJ650 Maxim and Midnight Maxim models, and the 1982 XJ650RJ engines), you can replace it with an automatic tensioner (from a 1982-later XJ650 YICS-engined model, XJ700 air-cooled, all XJ750 air-cooled, or an XJ900RK, RL, N/FN, and F engines) as they will interchange. Note that the XJ700-X water-cooled engines use a different style tensioner which will not interchange, as well as the XJ1100/XS1100 tensioners, which are unique animals all to themselves.
  5. Brhatweed
    Mora MN
    He's like the encyclopedia of the XJ
  6. borche007
    Macedonia
    Thank you guys for the responses.
    The rotating backwards trick sounds good to me. I will try it before taking out the tensioner.
    Btw here is a picture of my tensioner, notice how it looks longer and slimer than the other (automatic) ones that are posted here and in the linked thread.
  7. biggs500
    Sherwood WI
    Yeah.... doesn't look standard issue at all.
  8. Dan Gardner
    Minneapolis, MN
    Looks like a water cooled version => MaximX => different tensioner.
    biggs500 likes this.
  9. chacal
    well, maybe..........but a Max-X tensioner has a rounded (almost a pure circlulr) mounting flange where it attaches to the jugs......hard to tell from the image posted, but it doesn't look like one of those, either:
    https://www.ebay.com/itm/117056174411
  10. chacal
    l don't recognize that vertical bracket (pictured in front of the horizontal case of the tensioner) that appears to have some tube running thru it? It appears to have coolant hoses on the engine, meaning it's a Genesis engine; a 1986 XJ750 could possibly be an XJ750-X (only available in Canada), and if it made it all the way to Macedonia, it's done some travelling........
    Borce007, if you could provide the VIN number of the bike, it would help us to properly identify it.
  11. borche007
    Macedonia
    Sure, this is the VIN: YJA 1MY 008 GA 000626
  12. chacal
    Okay, that is an XJ750-X water-cooled model. It's a long way from home.
  13. borche007
    Macedonia
    here is link to a video of my bike running, Lets see if someone can find the noise familiar :D
    My video was uploaded as youtube-shorts and I can not embed it (facepalm).
    please manually construct the link because the forum does not accepts it: youtube(dot)com/shorts/RvLL465i844
  14. Brhatweed
    Mora MN
    Sound doesn't really detail the problem very well but I did hear what I thought might be slop in the clutch basket. I could be wrong here but on my XJ there's a circle of springs on the back side of the clutch basket that work to dampen and control the "shock" energy however over time they do develop some slop clearance and this gets noticed during idle as the engine has essentially no flywheel to smooth things out. Just my guess here but based on experience with my XJ750R... which I will address at some point this year.
  15. borche007
    Macedonia
    Thank you Brhatweed for your observation.
    However, one AI claims if that if the noise is coming from these springs, it should disappear or change when the clutch is engaged, which is not case for my bike.
  16. Brhatweed
    Mora MN
    I tend to shy away from the AI, most of this is based on pure speculation and strings of data put together by lazy teenagers who think life is a game. The only real way to find out where the noise is coming from is to get inside the motor and investigate, not the most elegant but we're dealing with a 40+ year-old bike that like many of us have a number of stiff joints and sore spots. I will give AI a little credit here; yes the forward loaded springs will go quiet when the clutch is applied however the backlash springs will remain unloaded and gain clearance as the forward springs are compressed by load. Again it's all going to come down to opening both the factory service manual and the engine covers and doing some real investigation.
    G_PA, borche007 and biggs500 like this.
  17. Rayzerman
    Rayzerman Member
    Ontario Canada
    While I'm not familiar with that tensioner, if it's a manual, can you not try to adjust?
  18. borche007
    Macedonia
    I agree with you Brathweed but I am reluctant to just tear of the engine because I have not done such job yet and can't say that my mechanical skills are good. And if I mess up, where I live, no mechanic will be willing to clear the mess and fix the engine :D
    Razerman I can try to adjust it if I find some manual or at least you tube vide that does something similar. For now I only found automatic tensioner fixes
  19. Rayzerman
    Rayzerman Member
    Ontario Canada
    Can you post a pic of your existing tensioner, to see if it is auto or manual? A manual should have a bolt and a jam nut exposed I would think.
    The autos (as described previously) have a ratchet mechanism to keep them from backing off, so in essence ideal..... the only way you should get noise from there is badly worn cam chain or guides, and tensioner then effectively is not long enough to take up all the slack..... but we don't know that yet... so, pic of your tensioner please.
  20. chacal
    You win the internet today!
    Another observation:
    "One of AI’s weaknesses is if you feed a scribble to it, and ask what letter it is, it will give an answer with 99% confidence it is correct, because “not a letter” is beyond its capability. It looks for patterns where there are none. AI's will make predictions of patterns it sees in the randomness, unable to understand what randomness truly is."
    biggs500, borche007 and Brhatweed like this.
  21. Brhatweed
    Mora MN
    I'm 56 years old and I call it like I see it, not most friendly but I do know what respect is and how to earn it.
    biggs500 and borche007 like this.
  22. Robert Strumbell
    Robert Strumbell Member
    United States duluth mn
    I assume you can only hear it at idle. Its not idling very smooth. Its sounds like little misfires which can cause the back lash in the gears to be noisy.
  23. Brhatweed
    Mora MN
    I really don't think it's the timing chain.
  24. Dave in Ireland
    Ireland
    That's idling like a bag of spanners. Sort out your valve clearances and carbs and you might find the rattle disappears.
