3 Wheeler XJ700
Discussion in 'XJ Modifications' started by Robert Strumbell, Apr 7, 2025.
  1. Robert Strumbell
    Robert Strumbell Member
    United States duluth mn
    1985 xj700 air with 2002 Honda foreman 450 swing arm. Originally made it for 1000 ft speed runs on Ice, 1st year 80mph so far. It is fun on street, my town allows ATV on street. Pinions are on opposite sides, had to flip diff up side down. Bike had no title and been layed down. Looking for info on possible Tach options, shift light, Rev limiter.
  2. Robert Strumbell
    upload_2025-4-9_23-52-25.jpeg This is by far my favorite toy. 125 mph in 1000ft on ice. Ive pretty much scared everybody away with it tho. Thats why I built the XJ.
    chacal and Simmy like this.
  3. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    you have balls that clank!
    How does the acceleration compare to the latest sleds?
    Robert Strumbell likes this.
  4. Robert Strumbell
    lol I have not riden a new sled but im sure they are not far behind. The fastest STOCK snowmobile as of 2022 NSSR is a 1000cc 1998 thundercat at 120 1000ft. Its a 1984 Honda 200es frame. It started with a 440 liquid Rotax , then 583 then 670 then current 950 PSI. PSI says it is capable of 197 hp. The compression can be changed by turning a nut on top of the engine and it is mild right now. There is more speed in it. But someone will have to go 120 before I go for it.
  5. Robert Strumbell
    Found a pretty cool tach for the xj700 wheeler. Dyno Racing 80mm, 11000 rpm, 1 to 8 cylinders, Shift light, has high RPM memory. 40 bucks Amazon.
  6. Robert Strumbell
    The Tach works good, shift light comes on at 7500. Has anybody ever installed a "Quick shifter" or Air Shifter on xj700?
  7. k-moe
    If it's registered as a XJ700 then it's still a motorcycle, and not an ATV. You can run it on public streets anywhere in the U.S. (but not with the spikes).
    It's only when a vehicle has 4 wheels that is stops being a motorcycle in the U.S.
    That it has a 2T motor doesn't change that, because of the year of manufacture of the frame.
  8. Robert Strumbell
    lol. I race them both on ice. Ok now back to the Quick shift or air shifter.
  9. Robert Strumbell
    Not finding much on Air or Quick shift. Quick shifters seems like they need a controller capable electrical system. Plan B is to reverse shift lever, to upshift while pushing down on shifter. I did get 1 good idea tho, the guy said he put on a rev limiter and shifted when it hit that.
