  1. StorminNorman
    StorminNorman Member
    Virginia
    Thank you for the heads up. I haven't had much issue with it yet. Hopefully, I complete the swap in the next week and can see how it rides.
  2. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Annual "wake up from hibernation" day yesterday. Oil change on the 750, wrestling the octopus on the 1100, looking forward to the extra evening daylight now. Some of you guys have been riding all winter, but just have thicker skin than me! Warmer weather is coming...
    Uxbridge Brule likes this.
  3. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Yesterday I went to my son's place to work on our bass boat. He has three bikes stored under a large tarp for the winter. His Kaw, on the right side, tipped over towards the right and pulled my XJ700 on its left and his Honda to the left of the XJ, over. Broke my clutch lever off (at the base!). Took a while but got it running. Today, I think, I'll start up the Maxim X, hopefully, and take a spin. Should try to hit 70 F later today.
  4. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    That was my Ex and the tentacles in my wallet befire I was traded in for a newer model.
    Put some KM's on the SECA today, we hit a max of 49F and I really didn't feel like dealing with anything or anyone. Gotta say it stores well in that all I've had to do so far really is open the fuel, add a quarter pull to the rich lever and it fires right off. Now the cold front is blowing thru and it's going to spiral downward for the next week or so.
    Roast644 and chacal like this.
  5. Tristan Kernick
    Tristan Kernick Active Member
    Pittsburgh, PA
    Even with a bit of wear and tear, she’s still a handsome devil, isn’t she?
    Have had an eventful offseason. Replaced handlebars, replaced MC (just to get one that sits flat), added heated grips, replaced wheel bearings, rebuilt forks, replaced a valve shim, and did the performance shifter pawl upgrade.
    Rides great, though apparently I’m slipping out of gear sometimes when I’m in second. I’ve heard this is a problem with worn shift dogs, but since I replaced the pawl and springs beneath the side cover, I’m somewhat suspicious that I mucked something up. Not a big deal anyways, just gotta short shift into 3rd and I’m fine.
  6. Brhatweed
    Mora MN
    I'm liking it. Nice Maxim.
    Tristan Kernick likes this.
  7. ScottFree
    ScottFree Active Member
    Northern Ill-Annoy
    That Maxim looks so much prettier than mine!
    Where'd you get the MC? I'm still running the stock one on a set of Daytona (Japanese "standard" style) bars, and while it works OK (hasn't leaked or sucked air yet, anyway) I know I'm in for an adventure when it's time to flush the brake fluid next fall.
    So the electrical system's up to handling heated grips? That's good to know.
  8. Tristan Kernick
    Pittsburgh, PA
    I got the MC from chacal, he sells one that’s pretty close to the style of the original and sits flat on the Daytona bars. Those are exactly what I have, and I’ve been very happy with that MC.
    I have had no problems at all with the grips, but I changed out the gauge cluster backlights, the tail light, and the license plate light for LEDs. These Oxford Heaterz draw 4 amps, which equates to something like 50 watts. I’m pretty sure changing the incandescents saves a good bit of power draw, so I can’t verify that these would work on a stock setup.
  9. Brhatweed
    Mora MN
    Well I do know form experience the XJ regulator won't go much higher than about 240 watts so 4 amps at 12 volts is 48 watts and going with the LED's gives you a good margin.
  10. Brhatweed
    Mora MN
    Ran the snowblower and cut a path in the 6.5" of snow, weather geek is threatening 60+ later this week so I want to be ready. Lets see if it happens.
  11. ScottFree
    Northern Ill-Annoy
    Yeah, we had heavy rain all day Sunday, about an inch of snow Sunday night, then a couple days in the 20s, another inch or so of snow tonight, then 40s on Wednesday, 50s on Thursday-Friday, 60 and sunshine on Saturday. We don't really have "spring" in the midwest; it's more winter days mixed with summer days, slowly turning from mostly winter to mostly summer by the end of April... or sometimes May.
    I really need a string of days when it's wet and drizzly out but warm enough to work in the garage, as I have a ton of bike projects to get done. I have a pile of parts for the Himalayan, which will get valve check and a bunch of electrical accessories that require removing the gas tank as soon as I ride it another 450 miles. The Yamaha's carbs are still sitting in the garage, waiting to be reassembled with a slight adjustment to the float limiter tab (the one that is supposed to keep the floats from dropping far enough to stick open when the carbs are empty), level-set, put back on the bike and synched, plus I have to finish the Seat Rationalization Project (raising the rider portion by about two inches so my fake knee and hip stop screaming at me).
    Luckily, there should be plenty of these days in April... which is good because I'm hearing the clock ticking. The Slimey Crud Run weekend is less than seven weeks away, and I really hope to have the Yamaha ready for that ~600 mile trip; and I'm leaving for New Orleans on the Himalayan all of three days later. My "riding season" is all year round, but things do get a lot more intense between May and October.
  12. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Today i re-fitted some standard forks to my XJR which i had powder coated and removed the fashion victim USD's.
    Tristan Kernick, Simmy and Brhatweed like this.
  13. Brhatweed
    Mora MN
    I'm really diggin' that XJR1200. That big boy would look great next to my SECA 750.
    I'm somewhat familiar with northern Illinois weather having worked for Motorola at Schaumberg for various training and other duties. Some days were hot and other days not but the wind was a constant. Was a good gig until Google screwed it up and cut the company in half.
