Honing cylinders
Discussion in 'XJ Technical Chat' started by MrSeca, Mar 5, 2026.
  1. MrSeca
    MrSeca Active Member
    Oakland, CA
    Seca 650
    Bought new piston rings and after doing some research I learned I have to hone out the cylinders first before putting it back together. What size cylinder hone do I buy? What kind do I buy? I’m noticing there are different grit sizes as well. What grit size do I buy? If there are any tutorials you could point me to that’d be great. Thanks.
  2. JBurch
    JBurch Active Member
    Owego, NY
    McMaster_Carr for the hone; I would suggest the following, stock # 4424A904, 600 grit. It is called a flexible ball hone; This one has an overall length of 8 inches, 3 inch band of abrasive. I have used WD-40, kerosene, diesel fuel,, what was handy for cutting fluid.. You do not want to remove a lot of materiel from the cylinder, stroke the hone in and out of the cylinder for about 30 seconds, move on to the next cylinder. Try not to run the hone all the way out the bottom of the cylinder.
    If you don't want to shop McMaster-Carr for the hone, try your favorite auto parts store.
    Good luck
    MrSeca, k-moe, cds1984 and 1 other person like this.
  3. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Then clean the bores with white cloth soaked in kerosene or similar until the cloth comes out spotlessly clean.
  4. JBurch
    Owego, NY
    Thanks for pointing that out, my mistake for not pointing that out, good call!
    MrSeca and k-moe like this.
  5. MrSeca
    Oakland, CA
    That's what I needed. Thanks. When actually honing the cylinder does it matter which direction you go in? Meaning, should you hone from the bottom of the cylinder or the top?
  6. JBurch
    Owego, NY
    Hone top to bottom
  7. Dan Gardner
    Minneapolis, MN
    With the dingleball (Flex-Hone) hones, it is important that the drill is turning before you insert it into the cylinder - then stroke it up and down a specific number of times. You will want to be consistent and do the same (or about the same) number of strokes on each cylinder.
    I suggest finding "Jim's Automotive Machine Shop" on YouTube and find some episodes where they do some honing. That up and down movement of the honing machine is the movement you will want to mimic. "Vice Grip Garage" does some engine rebuild videos with the dingleball hones too that would be a good demonstration of how to do it. Here's a good one:
    k-moe, chacal and MrSeca like this.
  8. k-moe
    It's so good to see great advice still being shared here.
    MrSeca likes this.
  9. MrSeca
    Oakland, CA
    Why does the gentleman in the video spray the dingle ball honer with PB blaster before using it?
  10. Dan Gardner
    Minneapolis, MN
    You need some sort of lubricant. Blaster, WD40, expensive honing oil, something like that.
  11. Robert Strumbell
    Robert Strumbell Member
    United States duluth mn
    Stones clog up if you dont use liquid to wash.
  12. MrSeca
    Oakland, CA
    Ah I see. So he's actually cleaning his honer from previous uses before using it to hone his cylinder.
  13. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Not really, liquid helps carry particles away, keeps things cooler. Like using cutting oil in a drill press, or fluid in a milling machine or lathe. A real honing machine uses a constant flow onto the honed surfaces and stones.
  14. MrSeca
    Oakland, CA
    So I completed the job. Rode the bike for about a month/500miles. I still have low compression. WTH!!!!!
  15. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    My first question is this a ring sealing issue or is there something else like a valve leaking? What are your compression numbers with and without oil down the spark plug hole?
    My last compression test yielded around 140 PSI/jug except for #3 which was 90 pounds dry on a XJ750R SECA. When I gave each jug a measured 5CC of 2-stroke Lawn Boy oil (organic) all the numbers were up by a good 30 plus pounds including the low #3 jug. I used a syringe to meter the oil so I didn't raise the compression ratio to oblivion.
    My advice would be to go back and check the numbers again but after checking/setting the valves and making sure the cams are correctly timed so you know everything around the cylinders are in order.
    MrSeca likes this.
  16. MrSeca
    Oakland, CA
    With the compression gauge I have it read 90 across all 4 cylinders. I think the gauge itself is wrong. Regardless, it is consistent across all 4 cylinders. The bike starts up nicely and idles equally as nice. I don’t even need the choke to start it which I think is indicative of something because my last Seca 650 took forever to warm up. Nevertheless, having owned one of these bikes before I’m almost positive the timing is correct, however, it lacks power on the top end and it’s guzzling gas like crazy.
  17. Dan Gardner
    Minneapolis, MN
    Did you lap the valves while you were in there honing?
    Brhatweed likes this.
  18. Brhatweed
    Mora MN
    An even 90 psi across all four is cause for concern, didn't state if you added any oil to the jugs during the testing so we can't rule out a ring issue just yet. If you're doubting the gauge I'd go after another one, any chance that little schrader check valve on the cylinder side adapter was changed to one for a tire? I got my 1977 vintage gauge for almost nothing because it was reading low from the wrong valve, they're a special design with a very light spring so rule out any instrumentation issues first then see what's up.
    Running rich alright. I'd start on the float settings and work my way back to the cleaning & reassembly making sure the emulsion tube pinholes are zestfully clean and the pilot jets are in the correct places if they were removed, the service manuals have them reversed in the details and Chacal outlines that in the tech section. A quarter pull of the enrichment lever is about the correct place for cold starting if things are set up right.
    Stock air box or pods? If stock what filter is in there?
    Did you change the primary jets? With my 750 the stock jet is a #120 main however I've gone as far as a #126 and those are about the highest it will tolerate. #122s seem to be the best for the modern fuels and the throttle response is crisp on the street, 124s give a better top end at the expense of fuel economy and life below 6000 RPM.
    For a settings baseline using the fine thread idle pilot screw I start out at 2.5 turns and work from there, this after the butterflies are all sync'd and I use vacuum gauges for all my tuning going for a balance instead of raw numbers with the goal of about 5 to 7 inches total idle vacuum at 1000 RPM .
    So check out and eliminate the variables that could have been introduced during the service work and move up from there, I find retracing my footprints leads me back to my mistakes
    MrSeca and Fuller56 like this.
  19. MrSeca
    Oakland, CA
    I did not but I have another Set ca 650 where had the head professionally gone over. Wonder if it’s worth switching heads.
  20. MrSeca
    Oakland, CA
    All the variables as far as the carbs are concerned have been eliminated and what ultimately lead me to check the compression.
