exhaust paint
Discussion in 'XJ Technical Chat' started by bensalf, Mar 21, 2026.
  1. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    hi all,
    i'm about to spray up my exhaust after having it repair welded, the exhaust is an aftermarket Motad -Neta
    which has Gloss black paint, but i cant find any high temperature Gloss spray paint, i'm in uk, so if anyone knows a place where it is available, that is easily obtained in uk, i would very much appreciate it ,nearest i can find is satin black, i'm spraying the whole exhaust including the headers. :(
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
  3. Dave in Ireland
    Ireland
    Never found any exhaust paint worth a damn.
    Even the best of them only survives so long.
    Factory black chroming lasts well, but never found a method of doing that at home.
    cds1984 likes this.
  4. Rayzerman
    Rayzerman Member
    Ontario Canada
    Some sanding and wire brushing will prep the surface. Two very light coats and leave it.. heavy coats will eventually flake off.
  5. bensalf
    yorkshire ,england
    hi guys, sorry for not replying sooner , ive not been at home,
    Rust-o-leum is not so easilly obtainable in uk, but i found this at Halfords of all places.
    tried it out today with first coat
    seems to be good results for first coat, but its only rated to 300 degrees C, so will have to see how it bares up heat
    thanks for your replies and sudgestions
  6. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    It does look good. Keep us updated once you ride it a bit, I'm curious.
    The OEM pipes are double wall so it might stand up.
  7. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    I went with the VHT 1200F but it didn't hold up well, issue here is it needs to be "set" at high temp for a period of time.
  8. bensalf
    yorkshire ,england
    they are not OEM though, its a Motad- Neta aftermarket one, just single walled
