XJ650 Starting issues
Discussion in 'XJ Technical Chat' started by RideAlong420, Oct 10, 2025.
  1. RideAlong420
    RideAlong420 Active Member
    USA
    Alright, looking at more stuff, it seems the "spark plug CAPS" were out of spec, but I couldn't seem to remove the inner caps. If I am understanding this, the caps are supposed to come off, right? If the inner ones are hard to remove, they could just be corroded or stuck, but a flathead and some wd40, and elbow grease should get them off?
    Is there no way to check the resistance of the coils without pulling the tank off too?
    Ideally for the XJ650 1982, 5k resist boots, no resist sparks?
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Fork upgrade.
    Between models there are differences in stanchion diameter. So if unsure get the triple tree also, along with brakes, wheel and discs. Big job!
    Spark plug caps.
    If you mean "come off the spark plug" then yes definitely.
    If you mean the cap off the wire, if they are standard coils and caps, definitely yes also. If non standard then they could just be a crimp on the wire which isn't removable.
    Indicator replacement with LED gear definitely drops a lot of current usage. I'm all for it.
    Good luck!
  3. RideAlong420
    USA
    I'll have to see when I'm over there probably next week, I'm not sure. I am sure however that they "appeared" non-removable for 2/3. The caps look like the wire went "over" the cap ends, and could be slipped out, whereas it looked the other way around for 2/3.
    Not my image, but they look very similar to this:
    Left is 2/3 and right is 1/4, so you have an idea what I'm talking about. The left caps don't look removable and they were pretty on there.
  4. cds1984
    All of those are removable. You must unscrew them from the wire. The cap might be stuck a little by the waterproofing boot but they will come off.
  5. cds1984
  6. RideAlong420
    USA
    Cool, thank you for the context!
    I've been trying to google as much as I can, to figure out as much as I can on my own, but stuff like this helps.
    Wish I had a bike mechanic in the area I could be like, buy them a beer and we just futz around on the bike for an afternoon lol
  7. cds1984
    There are a million pictures and write-ups here.
    The 'diy how to' forum is super interesting.
    I know I read most of them when I started this xj voyage.
  8. RideAlong420
    USA
    I've certainly read those and have gone through the xj4ever catalog repeatedly learning as I go. Not the same as having someone knowledgeable next to you to soundboard things off of, unfortunately. Also, some of the how-to's here have dead image links from posters who may not be around to fix, which makes things a little trickier.
  9. cds1984
    Yes I noticed a thread I did has dead images. Although they are there. There are policies to allow information from other sites to display which are the norm nowadays, anti spam etc. Try opening the image separately and it may be available. Right click action stuff on a computer.
    Olewildbill likes this.
  10. RideAlong420
    USA
    Is it possible to convert a master cylinder that comes on the XJ to something more modern, with a detached reservoir? I have to disassemble the master cylinder anyways since something is leaking and I just assume upgrade it.
    I'm trying to find a kit or...something but I am not really seeing what's good here. I don't really like the reservoir integrated with the front brake handle designs (hard to see levels with a crummy little bubble as your only visual reference, and I don't like how much space it takes up on the handle bar if I wanted to mount other stuff), but I also realize the size of the reservoir matters in order to keep things the same, for example.
    Or should I just suck it up?
  11. Timbox
    Your bike, do what makes you feel good. It is all part of making it your bike your project. I think the only thing you have to keep in mind would be the size of the MC. The plunger size of the system needs to be kept the same or very close. After that I think you can do what ever you want to do.
  12. Simmy
    Simmy Well-Known Member
    Waterloo Ontario Canada
    The yamaha master has a mount for the mirror if that is a concern
    Also wiring for brake light just plugs in
    If you can't find a good Yamaha Mc there are cheap Chinese ones plug and play
    I can't vouch for them may be worth a try
  13. RideAlong420
    USA
    I don't have a better photo right now, but I have this one from before I cleaned the bike of the Master Cylinder. Is this the "type A" sight window? or do I have to disassemble it in order to find out? The PDF on the parts catalogue wasn't super clear.
  14. RideAlong420
    USA
    Messed around with the bike this weekend, quite a few updates here:
    Finally got the bike started in my GF's garage. It would not start, even with a brand spanking new, fully charged AGM (YT12C) battery (to replace the leadacid YB12A-A one that was there before. I had replaced the old one with a new one but that still seemed to have issues so, I just did an upgrade instead to agm), so I shoved a bit of Seafoam in the tank, blasted some starter fluid in the airbox, and cranked it. Still nothing, so I touched what I believe is the idle screw (for some reason I assumed this was an actual screw but it's a knob instead you can just stick your hand in there and turn clockwise to increase) for the first time since getting the bike, and slightly turned it clockwise (towards the right side of the bike).
    Blasted some more starter fluid in the airbox, tried again:
    I had pulled back on the throttle when starting, so when she started with the choke on she kinda screamed immediately into 5000 rpms, and I kinda in shock let go of the throttle. Kinda like someone had startled you awake, certainly made us both jump. Monitored it as you can see here for a bit, before she was idling around 600/700rpms but I increased it to just a hair over 1000 on the tach, to better fit the 1050 suggested rpms for the xj650. I tried screwing the bottom screws, thinking they were the fuel mixture and quickly realized those were the fuel drain screws, and closed those right back up, after losing a few drops. I don't really see an easy way to reach any screws on this, but not important for right now.
    Installed brand new caps (5k Ω) onto BP7ES (non-resistive) spark plugs! Apparently, they were running (I think) DR8ESL spark plugs in here, but I didn't take a photo so I don't really know (I can find out two sundays from now if anyone wants to know). I really hated these rubber dust cover boot things on the plugs, and I went 3->4->2->1 so by the time I got to 1 here in the photo, I just left the original dust cover on the cap because it was such a massive pain in the butt, and the dust cover was fine anyways.
    I then moved onto working on the rear left blinker, which you may have noticed a slight problem before...
    oopsie...that happened because I was an idiot and didn't tie down the bike properly bringing the bike to the garage.
    But that's okay! because we have solutions. Solutions like someone was selling their XJ parts after a restoration and didn't need their blinker assembly, so I asked them to kindly send me rear left one. I technically got sent the rear right one. But that's okay, because we can just do some magic tricks and it all ends up the same in the end.
    wait, what?
    Left is what came with my bike, the right is what came with the replacement. What in the world?
    well....I guess that's a solution that was decided by...someone.
    When the PO of the other xj owner's rear blinker, had decided to have that blinker replaced by a non-oem part (the exterior, rather squishy aluminum? chrome? housing) they did two things. They had the original shaft I'm holding here, along with a new outer shell for the light bulb, that's aftermarket. They did not, apparently, have a hollow screw and a nut, like the original does, so you can feed it through a hole in the rear fender to pass through the cables for the wire. They did have a hex bolt, that they cut the length off of, so they could use that to hold it in place. However, where do the wires go? Ah yes, lets cut a V into the original shaft, and feed the wires up through the gap in the outer blinker housing, a tight fit that resulted in some of those wires having a bit of the plastic housing cut because they were jammed in there.
    I suppose the person doing the modification thought they were clever, but they literally were just making more work for themselves when they could have gone to the hardware store to pick up a hollow threaded screw, instead of a hack job. I guess this is a situation of "not my problem, it's the next owners problem now, lol".
    I was going to just reuse this new shaft, because the chrome is in better condition, and the V cut can be ignored, but the threading on the shaft is different and doesn't fit my hollow thread, and I wasn't going to implement the PO's crappy hackjob, so I took the outside casing (which itself wasn't oem) and blasted some Kroil and some elbow grease and mushed the two ends together. At this point I realized why the V cut shaft was also sanded down....because it does not want to go inside the replacement endpoint very well, it is very tight.
    For some reason, last summer the blinker was working, even though the part was smushed:
    It wasn't working, so I assumed something must have happened to my original lightbulb connector, and decided to take a chance that the replacement's was working (since it seemed like the FB guy replaced the lights to upgrade them, rather than there was something wrong with them).
    With the replacement blinker assembled, I tested the blinkers. I turned the bike on, and the right blinkers worked as expected. I hit the left blinkers, and got a steady light instead of a blink. Apparently, if the relay doesn't detect the resistance/voltage drop from both the front and rear blinkers on that side, it doesn't blink, as opposed to just, blinking the light that is available, and ignoring the one that isn't present. I assume this is normal behavior if one of the lightbulbs dies, but this doesn't really seem very smart to me. Blinkers should...well, blink.
    Anyways, I couldn't be arsed to look at the manual, that was 30miles away, to see whether the brown was positive or the black was positive, but what I could do, is turn the blinker on and touch the wires together and see if the light came on at all. Once the connection was correct, the blinker in my hand and up front worked as expected. I connected the two correct wires (as seen above) with a butt connector and installed the light back on the bike. Huzzah! I now have working blinkers again!
    At this point both of us were tired, as I was working on this all afternoon and she was working on a nice homemade motorcycle lift for us.
    Motorcycle lifts are expensive, but making one out of wood? When she hates carpentry? Priceless.
    The following day, we're finishing up stuff in the garage, I'm trying to figure out what is going on with my bike, that I have to blast her with starter fluid in order to get her to start, and I put the battery back on the 1A charger while I look, for what feels like the 40th time over every inch of the bike, trying to find something "wrong". I don't see a single frayed cable, I don't see anything burnt, I've been over the entire wiring harness, having cleaned the major contact cables, scrubbing the heck out of any electrical surface I can find, I've replaced the fuse box with ATC fuses (though I used the template to screw it into the airbox, it does not fit under the seat in that position, it needs to be further back, and the risers do not help. It doesn't raise it up far enough, so there is an extra drill hole in the airbox I need to fill, and the fusebox just kinda....floats under the seat for now.) and nothing really is solving the issue.
    The issue being: hard to start, and if I try too many times, this discharges the battery enough that the bike won't start up, until I put the battery back on the charger for a while, and then she starts up. Once she starts up, she's fine and will stay running....until she gets to like an intersection, I go to lower the RPMs and pull in the clutch, and then she just dies. Choke on or not, doesn't matter. She'll even do this when we're just doing figure 8s or whatever in the parking lot. When I got her started with Seafoam, I just let her idle for like 15 minutes, figuring that might help clean out whatever might have been stuck over the winter.
    You can see me playing around with the choke here after having started it:
    https://www.youtube.com/shorts/1GU5EtFdb0Q
    I'm a bit hesitant to let her run too high in neutral with full choke, having increased the idle screw a bit, it does now idle much better, but I haven't been able to test it on a ride, because, well, the front forks have a problem and are leaking. I did test the brakes a bit, and it seems that the front brakes work well, and I don't see a leak anywhere, though, there might be the smallest smallest one in the brake cable towards the MC. I also found that there is technically two brake hoses for one caliper. The upper one that goes to the midpoint of the fork stem, and the lower one that goes to the caliper. Why is it set up this way instead of one long brake tube?
    In any case, that potentially saves me some money, but I'll want to come back to it and replace with a steel braided cable, but that's less important than the forks. They seem to be leaking from the top, so that's gonna take a rebuild, and unfortunately that's several hundred dollars. The forks are very soft right now, feels awful, and it's leaking all over the rim and tire.
    But hey, at least it starts!
    And look what we did!
    Now we can work on the bike while sitting on rolling seats instead of on the dang ground! She was a heavy girl to get up on this thing, absolutely not a one person job. We tested with her Honda Rebel and that was way easier than this bike. Unfortunately, I can't think of a good way we can lift the bike up to do the fork replacement on this, and this design won't accommodate the center stand being put down, which would have solved things a bit.
    While the bike was on the lift, it had been a few hours since I started it last. She went to start the bike and it started right up without any starter fluid. All this to say, it does really seem like carburetor issues. I really didn't want to have to pull the carbs and clean them, that's another several hundred dollars, plus the almost $200 for checking the valve clearances, and then carbtuning them. :(
    I also noticed something peculiar...the right side oil pump cover (where the YICS logo would be) should be the same as on the left, right? well, the right side is missing the YICS logo, and there's some suspicious screws there that don't look stock (slightly stripped screws). I'm wondering now if the bike had gotten dropped at one point on its right, and they had to replace the cover on the right, and that would explain this very weird "frame guard" piece of metal that's kind of just bracketed to the frame (the metal that is attached on the left to the orange straps in the photo above), perhaps after that fall, the PO put a guard up. It does at least come out a few inches on each side of the engine, acting as a pseudo frame slider.
    I'd like to get a matching pair, for the symmetry, but it's not very high priority.
    I was looking over my rear brake pedal, trying to fix the rust on the chrome...only to find there's no saving this without paying someone to re-chrome it, or replacing it. I have a better idea:
    Once it dries, I need to add another coat, and then some clear coat, and it should be good. Speaking of which, the sissy bar in the back has absolutely seen better days (along with the caliper, which you can just finger peel the paint off of). I need to figure out how to get this bar off (the rear shocks are attached to it) so I can paint this too (and to buy new gold stripe stickers from xj4ever to replace the ones on here (and the tank, eventually)
    Anyways, next on the docket is fork repair! See ya in a few weeks!
    Timbox likes this.
  15. RideAlong420
    USA
    Some future upgrades/tasks I'd love to do to this bike:
    take everything off the frame, sand it down, repaint frame. It's both gross and there's rust cropping up here and there I want to deal with.
    paint down everything but the aluminum surfaces black. Polish aluminum to a nice shine.
    Upgrade to XJ750 forks for dual caliper brakes. Upgrade to slightly better rotors
    Upgrade to XJ750 tank for larger tank size (will the rotation of the forks touch the tank?) Fuel sender maybe? I'd love a fuel indicator light.
    switch over to LEDs so I can hook up a USB device, and grip warmers. I'll lose out on the auto-off relay which sucks, but oh well.
    Upgrade rear shocks to heavy duty shocks
    convert built-in MC reservoir to detached so the handlebars aren't in the way
    replace right hand control module with something that just has an off-on switch instead of 3-pole
    upgrade to a digital tach and speedo, perhaps all in one, would be preferable.
    dream wishlist would be figuring out how to make this EFI, there's a walkthrough for an XJ1100 by a guy who used to work at NASA but that's so far down the pipeline for me.
  16. cds1984
    That's a lot!
    Starting and running wise.
    2 things
    Fuel and spark.
    The fuel side is ALWAYS a problem on a bike that's sat for a bit or has been running about for 40years.
    Once the carbs are fully tuned and cleaned and refurbed, if you have spark, then if you're still having dying issues you can move to the spark side.
    Carbs are the heart of it.
    When the bike is running it's great but I always feel like I need to do some more carb tuning after a couple of 100ks. Never ending tuning!
  17. RideAlong420
    USA
    I have an order coming from xj4ever today (though I'm at work rn, so hopefully it doesn't arrive before I can get home to sign for it, it showed up a LOT faster than I expected) with the following items:
    - Fork rebuild (performance kit is discontinued, sounds like the progressive springs are out of stock) kit
    - tools for fork rebuild
    along with some "might as well" parts since the fork is coming off
    - front and rear high performance wheel bearings
    - upgraded stem taper bearings
    - tools to do the above
    - steel braided brake lines
    The brake lines weren't necessary technically, but still a good idea since I have no idea when they were last changed and I'd rather be safe than sorry. I don't quite have enough $$$ right now for a full MC/Caliper rebuild, and the guy I paid for the initial service of the bike last fall claims to have done a rebuild. The caliper is coming off anyways, so why not replace the brake lines to be sure that part is okay? While I'm at it, the caliper paint is literally peeling off, so guess what's getting hit with some masking tape and some black rattlecan paint + clear coat?
    The wheel bearings weren't necessary technically, I have no idea how long they've been in there, and may as well install some high performance ones. I did forget to order two wheel bearings for the rear and only ordered one, oops. Well, the back wheel is a little less important, though I do need to get that one off eventually, because the rear rim corrosion is insane. I wash it and the black looks good and once it dries, it looks like there are grey spots all over it, so once the wheel comes off, I'm just gonna wirewheel all the black parts, get some plastic bags to cover the tires (which I do eventually also have to replace because they're over a decade old, but NOT rotted or cracked, that I can tell, which is surprising. No flat marks??) and masking tape the flat metal, and spraycan those black again and clear coat again.
    Once that's all done, then I can finally take the bike out for a ride, but there's still a few things left to buy: fork oil I'll just pick up locally, laser thermometer (I can't find mine) so I can test the temperature of the headers to double check there is no issue with any cylinders. I also need to get a spraybottle of water so I can spray around the intake boots to see if there's any vacuum seal issues (spray water around edges, if rev goes down = vacuum leak and I will need to probably just replace all four manifold intake boots and the boots on the airbox) though I haven't personally pulled the carbs, I didn't notice any cracking of them, still good to check. Also brake fluid. I also ordered a cheapo digital torque wrench (I have one from my grandfather I inherited, but it's 20+ min torque and lots of things on this bike are like 8-20 range, so got a small one), and a digital compression gauge, because I think the technician did check compression but I don't know the individual values just that he "checked"
    I also realized that what I turned was the idle speed screw not the idle mixture screw, which seems like it "helped" but I'm worried it obfuscated the issue (especially since the idle will warm up and increase under load, and I increased it on the bench with no load.) so I'll turn it down again after later testing.
    Once the bike is on the road, the next steps will be to see if it sputters and dies when I pull into an "intersection" from having given the bike load and then to "unload it" by downshifting down to first or neutral as I come to a stop, and pull away from a stop in first, which is what it was doing. I went out riding on my GF's Rebel and I was not being a complete noob and dumping the clutch, and my gf who is more of an experienced rider than me was also dealing with the same issues when she tried the bike out, so I'm not convinced the problem is occurring between the seat and the handlebars. When this happens, or even as I start to "slow down" the bike acts like it was being starved and it subsequently dies, and then it's hard to turn back on, each subsequent attempt becoming harder and harder.
    It's really damaged my relationship with the bike, I get it's old, but I want a bike that behaves more consistently, I don't want to be left stranded on the side of the road. I want it to be reliable, and I think that's only going to happen if I put enough work into it to make it more reliable.
  18. RideAlong420
    USA
    Did a bunch of work, replacing the front wheel bearings, and rebuilt the front forks. I will do the new brake lines next week.
    I got a digital thermometer and tested the temps of the headers, and from left to right they were roughly these ballpark temps: 250, 450, 350, 450 which to me sounds like there are issues with Cylinder 1 & 3 not firing properly. Headers 2&3 should be hotter typically, but off by 200F and 100F?? Something is wrong. (The bike has a 4-1 exhaust, not stock)
    I know you can swap the ignition coil wires 1 & 4 and see if the problem follows, ie: if I do this and cylinder 4 starts running poorly, then I know it's the wire, and I can trim back 1/4" and try again. If it doesn't follow, then the ignition coils are probably fine, and the problem is carb related. Am I completely off base with this assessment of the next steps? The previous technician said there was a firing issue on 1 & 4, so I'm leaning towards the carbs are fine as he did those, but the induction coil might be junk. $60 is a lot more bearable than $600+ to do the valves and carbs myself
    I doubt the spark caps and plugs are bad, as I just replaced those with the correct spec ones.
  19. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    You should check the wires and coils with a multimeter.
  20. RideAlong420
    USA
    Do I have to take the tank off to do that?
  21. RideAlong420
    USA
    Excited to work on the brakes tomorrow, will try going to tractor supply, and get some syringes and some clear plastic tubing and try some reverse bleeding. I considered getting the mintyvac but it's so expensive.
    I also need to check the coil resistances, and I don't think I can do that without taking the tank off, unless there's a different way to test them. I gotta empty the tank of old fuel anyways I guess. I'm sure that something has gotten clogged in the carbs.
    edit: the other thing I noticed is that at some point, the carb hats are chrome on the outside and zinc on the inside, as if they are the non-north american versions. I don't know when this happened, as all four should be chrome tops. Someone has been here before to pull the carbs, and lost the original carb hats, or did the carb rack entirely get replaced? I have no idea.
  22. Simmy
    The carb hats are correct
    Yamaha saved money only chrome plating the outside carbs
  23. RideAlong420
    USA
    I wasn't aware, the catalog seemed to indicate otherwise
  24. RideAlong420
    USA
    I'm back in the garage and the front left fork is leaking from the top. Damnit.
    I don't think I blew out the seals or anything so I'm not sure what I did wrong.
    I'll still do the brakes today and test it,but maybe next week I gotta take the left fork off and do it over again. Sigh.
  25. RideAlong420
    USA
    I got the new stainless brake lines on, the top one took a little bit of difficulty and I'm going to start reverse bleeding the system, though I might have to come back to this tomorrow.
    However, what the hell is this??
  26. co.dirtbiker
    co.dirtbiker Active Member
    Colorado, USA
    Old crusty brake fluid. If the master cylinder reservoir looks that bad, you're probably going to need more than just new hoses. Check the MC piston. Probably looks the same kinda crusty and likely doesn't pass fluid like it should and/or sticks. The return port may also be clogged. Caliper likely needs a rebuild too. You don't want to skimp on brakes.
  27. RideAlong420
    USA
    The previous technician claims that he rebuilt the caliper. I'm not sure how he didn't see this, unless he did a reverse bleed of the system? Or maybe he didn't do the caliper like he said? I have no idea. The actual reservoir looked real clean, it was just the gunk above the rubber gasket thing. It didn't really seem like it was inside the actual reservoir.
    I flushed the entire system, after installing the new brake lines, and eventually was able to engage the piston in the caliper, and it seemed like it was working but it wasn't working very strongly, and pulling the brake lever, seems to go all the way in. I guess there's still air in the line maybe?? We tried wiggling the handlebar around so much, and removed any gunky fluid that we could find, and passed like half a bottle of brake fluid, through the entire system back and forth, till we were getting a nice lamellar flow, up towards the master cylinder, but I guess it still wasn't enough.
    This is so frustrating. Honestly, I'm really debating, just giving up on doing these repairs myself, and then just paying somebody else to do it. It's a good skill that I'm learning, and I suppose it's probably cheaper, but I'm honestly getting a little bit tired of doing a repair that takes hours, to find out there's something else that I need to work on, to then, need to do the repair again because it's still not working, either because this is the first time that I've done something like this, or maybe I missed a step, or maybe something needs to be replaced that I'm not aware of. However, my priority, is to ride not to do piles of repairs
  28. cds1984
    A lot of people look at these bikes as a project.
    The reason for that is they are old and bikes need a lot of maintenance from day one.
    That's where the abuse of the previous owner(PO) pops up now and then.
    So, walk away when frustrated and come back another day.
    It's a long term project, if you plan on keeping it you will end up doing these repairs again, most likely.
  29. RideAlong420
    USA
    I wanted to ride this summer and I'm just really tired.
  30. Tristan Kernick
    Tristan Kernick Active Member
    Pittsburgh, PA
    For what it’s worth, when you’re done with the brake overhaul, you’re probably going to be impressed with your braking performance. I did a full MC + caliper rebuild and replaced my brake lines with stainless ones after my first riding season. I also swapped my 1980s brake pads with modern sintered pads. Couldn’t believe what a difference it made.
    With one front disc and a rear drum, an XJ650 will never stop as well as a modern bike. But it can achieve adequate performance that won’t make you question your life choices whenever you see a light turn yellow up ahead.
    Edit: just noticed the above post, and yeah I feel that. These bikes are definitely a project, and you’ll spend less time riding than someone with a modern bike. I think a vintage bike is worth it if you actually enjoy the maintenance. Otherwise, it can be extremely frustrating.
  31. Dave in Ireland
    Ireland
    The Previous Owner is always a liar.
  32. RideAlong420
    USA
    In this case the PO is my dad, and he doesn't really speak to me.
    The previous technician is someone I paid last year to do work on the bike for me. It certainly was running again,it just wasn't running right. And once I started getting it going, these issues started coming up. I guess being awoken from a 20+ year slumber with only one wake up 10-14 years ago was enough for these issues to crop up.
    This is also why I'm documenting everything, so there's a record
    Dave in Ireland likes this.
  33. RideAlong420
    USA
    I'm gonna elect to replacing the MC with HCP1808WO, instead of rebuilding what's there, since that will go with the steel braided ones I bought, and I want a new brake lever anyways. It has a bigger bore, which sounds like it will take more hand force, which is whatever, I don't mind that.
    My gf's 2008 Honda rebel, you can hear the nice little "click" of the brakes starting to engage after about a millimeter, and you can not bottom out the brake lever, which is what I hope to achieve. Currently, I bottom out the front brake lever and the front brakes engage and stop the wheel from spinning, but I can rotate the front wheel by hand while the front brake is engaged. Is it an unreasonable expectation to say I shouldn't be able to do that on properly setup brakes? I've read some posts saying that the front brakes on the XJ650 is "adequate" but what exactly does "adequate" look like in practice?
    I also hear the front brake is not adjustable?
  34. cds1984
    When the brake line, callipers and MC are all completely primed and tight, it is exactly like that.
    With SS lines even more so as they won't expand under pressure.
    With a bit of disc wobble the calliper piston will move back into the calliper so that can add a tiny bit of lever action also. Nothing like you have though.
    Pretty sure the adequate comment is not what you think, may have been someone with no grip strength.
    I have, definitely locked up my front wheel on a dry road when a small animal fluttered out in front of me.
    Adjustable at the screw to the MC. On or off. Not a drum brake.
  35. RideAlong420
    USA
    Okay, so I shouldn't be able to rotate the front wheel by hand at all, that's good to know. That's what I expected but I wasn't sure if that was a fair assumption or not.
    I'll replace the MC and if it is still an issue, I'll do my own rebuild of the front calipers, even though the guy I paid said he did that (though I can't really trust if he actually did it, since the reservoir gasket had tons of gunk on it, the MC was clean, but flushing the brake system, pushed some brown sugar colored brake fluid into the reservoir when I did a reverse bleed)
    the gf bought a harbor freight vaccum bleeder so I'll try that next time. Maybe an air bubble got caught in the distribution joint, or the MC has an issue.
  36. cds1984
    That's the thing. When did he do them? 5 winters ago.. moisture is sucked into the brake fluid and makes a mess.
    That is one of the reasons a lot of the xjrs will do a Brake flush every year or 2.
    Seized pistons suck but everything is fully repairable and with maintenance stays working well.
    Keep at it!
  37. RideAlong420
    USA
    Literally last october. It was outside for maybe a month before going into my gf's garage over the winter.
  38. cds1984
    Here is a tip.
    Air rises.
    It also gets stuck in all the little bends and angles.
    So.. stand around fill the MC and just open the bleeder and let brake fluid flow down.
    When it's mostly emptied the MC, close the bleeder, top it up and just lightly move the lever in and out and you'll see a few bubbles in the MC.
    Tap the lines and you may see a few more...
    Keep doing that everywhere till no more bubbles in the MC and then attempt a normal bleed.
    Vibration from riding can dislodge them also up to the MC.
  39. RideAlong420
    USA
    I did a reverse bleed with large syringes, and 1/4 inch vinyl tubing, which I read here works, pushing upwards from the caliper. Besides not quite having a great seal around the brand new bleeder valve, which I've seen a few videos where that just kinda happens, even with a vacuum bleeder kit, it more or less worked until I saw no bubbles at all.
    I'm more inclined to think the pressure issues are from the MC seals being bad, rather than there being air in the lines.
  40. cds1984
    Whatever works to get that air out. If the the plunger and cylinder in the MC aren't in good nick then, your right, nothing is going to work.
    One thing I learnt after toiling on my barely running bike 15 years ago that is my daily rider now, every single rubber component is bad and needs looking at and/or replacing.
    I definitely practice the bleeding technique mentioned and I also have anti dive to wrangle with.
    Although in saying that it definitely doesn't work with 900 rear brakes... Now that is another world of pain.
    Project for life possibly.
  41. RideAlong420
    USA
    Yeah, thankfully I have the simplicity of the 650 american bike without the anti-dive system of the seca. But I'll replace the MC and crush washers and try bleeding/flushing the system and trying again. If it still gives me a hard time, I'll rebuild the caliper again, if I still can't get it, I'll just give up and take it to a tech at that point lol
  42. Huntchuks
    East Rochester, NY
    MC rebuild kits are not too expensive.
  43. RideAlong420
    USA
    It's true, but for like an extra 20 or $30, I can just replace the entire assembly. I need to replace my clutch lever anyways, so it seems worth it to me. The convenience of taking the old thing out and just screwing the new one on, is extremely up my alley.
  44. RideAlong420
    USA
    So I did a little bit of work on the bike today, and these are what all four of the new plugs look like.
    You can see also how much and how the pitting looks like on one of the inner tubes. It doesn't really seem like much and my fingernails don't really catch on them that well after having sanded them. That being said, I did start to put some epoxy on it, and I'll get to it next week to sand them down. I also inspected the seal for damage, and I don't see any nicks or any cuts on it at all. Also, the inner tube doesn't seem to defense or anything, and it seems like it's the appropriate thickness.
  45. chacal
    Those plugs don't look too good.......if the black residue is OILY, then you have an internal engine mechanical issue (valve stem seals or worn piston rings are the likely culprits). If the residue is DRY (not oily, just sooty) then that's due to incomplete combustion, which can come from a variety of causes (typically carb and/or tuning related) and although frustrating and perhaps time-consuming to diagnose and resolve, will be much less expensive to remedy than a mechanical ailment.
  46. RideAlong420
    USA
    I don't recall the plugs being oily, what it looked like was dry soot, I could more or less rub it off with my finger or a microfiber cloth, for the most part. The ceramic part was a bit harder to touch, since it's a small area and I didn't want to get particulates on it.
    I didn't finish a compression test I was running (since the forks epoxy was drying), since I didn't have a car battery, so I needed to make sure the AGM battery was topped off before each attempt, and the first time I did the test I had the extender on the compression test, and I think I didn't fully pin the throttle for cylinder 1 on the second attempt, but the first two I tested were cylinder 1&2 and it was 131.3psi and 146.2psi respectively.
    I'll be able to check cylinder 3&4 next Saturday. I'll likely retest 1&2 then too.
  47. RideAlong420
    USA
    Cold compression tests:
    C1: 131.3
    C2: 146.2
    C3: 146.6
    C4: 128
    Didn't get much further than that, but I did work on the forks again, using the level tool and topped up both forks, adding some air to both with a small ball inflator, and sanded down the epoxy on the leaking fork. The oil seal looks unharmed.
    I also replaced the brake assembly, and upgraded with performance pads, and the brakes are now really good and mint. Very strong.
    Tomorrow I will be installing the crash guards, putting fresh gas in it, cause the gas is likely old, and taking it for a short ride. It runs poorly, in my opinion, but my ex says it is running okay and it's probably a combination of it's an old bike that doesn't run perfectly and inexperience
    I have a tech going to take a look at it next month who will do the valves and carbs and do a leak down test.
  48. RideAlong420
    USA
    I took the bike for a roughly hour and a half ride today, after installing the crash guards, removing as much October gas and buying expensive ethenol free gas.
    The fork I repaired again with epoxy was leaking, very very slightly still. Not a lot, and from the top. It's better than it was, but I'll keep an eye on it. I may have to just suck it up and replace the inner fork. I don't think there's anything wrong with the oil seal, nothing was installed incorrectly, and I've had these forks on/off so many times I'm pretty confident of the process.
    I think I might have seen a spot on the front tire that has some rubber cracking I hadn't noticed before, but the rear tire looks great.
    Brakes seem fine. The new performance pads need a little more break in time, but they're very nice I think.
    Here's the rub:
    Riding the bike in 3/4 gear, feels great. Wonderful. Everything is very smooth, shifting feels great, sound seems great, hover around 5k rpm and the bike feels like it should. She doesn't complain, she is very responsive.
    Riding in second is, fine... It just feels a little "dry" and revs up easily compared to the curve in 3 or 4.
    Riding in first? Incredibly inconsistent and jumpy behavior. One of two things will happen, it will rev up very quickly, and when I let go of the throttle, it will "release" power very quickly, to the point of going so low it feels like it will stall because it's acting like it is starving, for something. So I have to re-adjust back and forth, or just get out of first asap to avoid the issue.
    This of course makes it incredibly clunky and nerve-wracking for me to interact with any intersection in a city if I'm having to constantly fight the bike to stay alive during stop and go traffic. I've had hit or miss success with giving it the choke when I am going back into first to try and mitigate this.
    The other thing I noticed happens at times in first, is I go from a stop in first, and start to pull away, and it's like the bike hasn't realized I've hit the throttle, so I instinctively turn the throttle a little more, and then the bike finally realizes that I've done this, and the bike jerks forward, and then I get anxious and let off the throttle entirely and it calms down relatively quickly, so I try to accelerate again, and it again starts to complain, while I'm having to deal with this jerky behavior, until I leave first gear and get into second.
    I thought this was me, and the ex rode it a bit, and agreed the bike is behaving weirdly while in low rpms, she was saying the power delivery was odd, and inconsistent. While she was able to keep it from stalling, she thought the behavior was very weird.
    Googling the issue, sounds like something called "bogging".
    I pulled the 1&4 plugs and the tips are still sooty.
  49. Rayzerman
    Rayzerman Member
    Ontario Canada
    I'd replace that leaky fork seal one more time. I've done many fork rebuilds for leaky seals, and visually I can't find anything wrong with them...... worth a shot.
    RideAlong420 likes this.
  50. cds1984
    If the bike idles well, is synced, std air box, clean air filter, good fuel, float level correct, correct air fuel mix... Then you can blame the slide, diaphragm and needles.
    Before all the above the cv carbs are a magical pain in the backside.
    Colourtune plug helps a great deal. I mean, the guys who tune the air/fuel without a colourtune are magicians in my mind. I tried.
