  1. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    Looks like Dan has been doing all the heavy lifting. All I did today was check & fill my battery then zip-tie the broken side panels back into place.
  2. Dan Gardner
    Minneapolis, MN
    @Brhatweed I’m a glutton for punishment I guess. And there’s that nice 550 by you and a 900 just popped up in St. Cloud. Crap!!!
  3. Dan Gardner
    Minneapolis, MN
    That XJ650RJ I picked up today is definitely a bit of a basket case - but there’s some good stuff that needed to be saved. Tank is a little crusty inside but solid. Carbs are serviceable. TCI was there, needs to be tested. At least those bits need to be saved from the scrapper.
    Brhatweed likes this.
  4. Brhatweed
    Mora MN
    Don't know what happened to the 550 that was down by the storage place, sold maybe? Spare change is a little hard to come by right now and my better half is keeping a close eye on them, I could really get into a 900 tho.
  5. ScottFree
    ScottFree Active Member
    Northern Ill-Annoy
    What did I do to my Yamaha the last couple weeks? Just rode it, maybe a total of 500 miles or so. No place in particular, just rambling around the corn fields, tying together what few curves there are in this part of IL.
    Stopped to photograph this one because it had just been chip-sealed and the loose pea gravel made the corner No Fun At All.
    I did a lot of thinking on these rides. It's been three years and 6000 miles since the XJ showed up in my garage, and I thought a lot about whether the bike is a keeper or whether it's time to join the ranks of CL (or FB Marketplace) optimists. On the one hand, the bike works mostly pretty well at this point--it starts easily, runs up to redline without any noticeable issues (though I can't say I have a lot of basis for comparison--a perfectly-set-up one might be a lot better for all I know), tracks straight, corners pretty well and even stops acceptably (especially by the standards of its day). Now that the pesky carb-overflow problem seems to have been fixed, I would trust it for a trip. On the other hand, it still doesn't want to idle (and I increasingly doubt I am enough of a Carb Whisperer to get it to), it shifts like a tractor despite multiple clutch adjustments, the FD leaks a bit, the seat is too low and generally terrible (though the "booster cushion" and Bead Rider make it tolerable), and the chassis still feels twitchy (though I think a bit of attention to the steering head and swingarm bearings are likely to help that).
    As usual, I returned with no clear decision, which means I will not do anything irreversible. Besides, a quick check of FB Marketplace shows that I could not sell the bike for what I have already put into it.
    July marks 50 years since I got my motorcycle license. How time flies! My first bike was an ill-tempered Kawasaki two-stroke triple (the 350cc one, or I might not be here today); my second, bought 49 years ago, was a KZ900. I bought that bike immediately after being sacked from my first post-college job, and spent pretty much the entire summer of 1977 riding it to both coasts. I have thought about celebrating the 50th anniversary of those trips by finding a KZ, but given that one in even remotely decent condition is close to ten grand, that idea died quickly. I suspect that if I want to re-create the feeling of being in my twenties, I'll have to do it on the Maxim. Which is not a bad bike--same inline-four, dual-cam, four-carb Universal Japanese Motorcycle as the KZ, but also equipped with tubeless wheels, shaft drive, and a frame that doesn't feel like it's made of rubber. Maybe I should paint it dark green, like my KZ was...
  6. Rooster53
    North, FL
    So yesterday I had new rubber mounted Bridgestone Battlax.
    This is what the front looked like going in:
    This is what the front looked like coming out - 12 total weights so 3 oz.
    The rear is not as bad with eight weights (2 oz), but the white dot is 180 from the valve stem - and the weights closely follow. The story at cycle gear for the rear was the tire would not bead with the white dot at the valve stem where it should be, so procedure tells him to move the dot 180.
    Should I accept these - all done at Cycle Gear?
  7. Dan Gardner
    Minneapolis, MN
    @Rooster53 - seems quite excessive to me. If they couldn't rotate the tire to get it close without needing a ton of weight, then the tire is bad. Either way, I don't like it.
    Fuller56, Brhatweed and chacal like this.
  8. Brhatweed
    Mora MN
    No that's a bad deal all around. Say all that weight comes off on the highway at 70 MPH? Things are going to get really rough. If it was me I'd take it back and say no lets first pull the tire and mark where the weights are then check the balance of the rim then remount the tire and see where the heavy spot is. When I had the rims of my 750 seca checked bare they were off exactly where the valve stems are and they were able to zero them out leaving me with a "clean slate". The new front required only an ounce at the 3 o'clock and we used a heavy sheet rubber that's used to seal coax connectors on the inside leaving nothing on the rim, the rear took two ounces at the stem and this was balanced using another nut & washer. At 100+ the bike is smooth with no worries about things flying off at speed, there are times when one *has* to crack the throttle to get away from a knucklehead and that gang of weights is a disaster waiting to happen. If they can't get it right push for a warranty because it's your butt that's on the line so don't back down.
    chacal likes this.
  9. Dan Gardner
    Minneapolis, MN
    Tank soup!
    Brhatweed and Fuller56 like this.
  10. chacal
    I smell electrolysis..........
    ksigurdsen likes this.
  11. Dan Gardner
    Minneapolis, MN
    And lots of it
  12. Brhatweed
    Mora MN
    It smells like.... teen spirit.
  13. Dan Gardner
    Minneapolis, MN
    I picked up a Craigslist deal today - 650 Maxim tank and right side cover
    RideAlong420 and ksigurdsen like this.
  14. Fuller56
    Fuller56 Well-Known Member
    I continued the 750 engined 650RJ with Shoei GF2 fairing rehab. Last evening was finding the kill switch was no longer working. Now to figure out why.
  15. ScottFree
    Northern Ill-Annoy
    Early last week I took my XJ for a ride. Stopped for ice cream, stopped at the local dealer to look at the new Chinese-made Ural sidecar outfit. Didn't have time to take it for a demo ride. I'm not in the market anymore (not with two patched up shoulders), but I'd kinda like to take the thing for a ride just for old time's sake (I put about 100,000 miles on a Harley with sidecar back in the '90s; it was my daughter's fourth birthday present and she went everywhere in it). And, of course, I continued trying to figure out whether to keep this bike or not--I question whether I really have the temperament for a "vintage" bike, and I spend a lot of time cussing at those fussy little carbs, but feeling like I'm still in my mid-twenties (rather than my early seventies) is priceless...
    Anyway, Friday morning I was beating myself up by going through the ads on FB Marketplace and seeing how little people were asking for XJ650s, when I stumbled upon this:
    A gen-u-wine Rifle "Sport" fairing, from the people who designed the Yamaha streamliner that Charlie Perithian rode to a whopping 400 miles per... gallon in 1982. I had one of these things on my Sportster back in the day, and was amazed at what a good job it did. Plus... it's more or less period-authentic to the XJ! I think it looks pretty good from the side as well:
    Haven't had a chance to try it on the road yet (heat index has been up around 105º the last couple days; the only reason I was able to do the fairing installation is that I have air conditioning in the garage), but I think it should be a good improvement over the little Puig flyscreen I had on the bike before. And when I go up to Wisconsin for the Crud Run in October, I bet I'll be happy I have it.
    Think I'm going to have to rotate my phone/GPS holder just a bit to clear the windshield. I also about half-expect to have to trim the shield by an inch or so, bu town't know till I take it for a ride. I still have to wire up the lights. Turns out the fairing has dual filament sockets, so I get both turn signals and running lights. Sweet!
  16. Fuller56
    Oh, that is a nice find! I think you are really going to like it. All that time and effort and thought you have put into getting that bike set up as you like it, if you get rid of it you will be sorry. Then you will just have to start over. Remember about having what you want vs wanting what you have......
  17. ScottFree
    Northern Ill-Annoy
    Yeah, I read that book (How to Want What You Have) about twenty-five years ago, and when I am in my right mind I pay attention to what it has to say.
    The more I think about it, the more I come to believe the real question is not whether to keep the XJ, but what to do about the other two bikes in the garage, because the reasons I had for owning them seem to have evaporated. The Harley was the two-up long-trip touring bike, which the wife and I have ridden to New Mexico, Canada, Maine, the Gulf Coast, and Seattle... but now she says she's done with the two-up epic rides, and this year we took our vacation (around Lake Michigan) in the car. The Himalayan was the off-road adventure bike, and I rode its predecessor (the earlier air-cooled 411 Himalayan) on a once-in-a-lifetime trip to Moab five years ago (revisiting a once-in-a-lifetime trip taken forty years earlier), but at the age of 72, with no particular interest in riding dirt for the sake of riding dirt, I have little justification for a tall, bulky, and awkward (I have to climb onto the thing as if getting on a horse) "adventure" bike. What I probably need is a "standard" bike with some touring accessories, something that could haul two people on day trips (and possibly be trailered behind the car when we travel further from home), and could support me for a long solo trip.
    Y'know, something like the XJ.
    Fuller56 likes this.
  18. Fuller56
    @ScottFree, see there, you talked yourself right into needing to keep it! Well done.
    And it is easier to move around than the Harley and prettier than the Himmy. Anything else I can help you justify?
  19. ScottFree
    Northern Ill-Annoy
    It is actually easier to move around than the Himalayan, which, despite being 70 pounds lighter, is awkward and top-heavy and has the world's worst center stand (and of course the limited space in the garage means the bike has to be parked on the center stand). The Yamaha is much, much easier to move around the driveway or garage.
    I finished wiring up the fairing lights yesterday. I binned the pair of 3-pin Molex pigtails that came with the fairing (and which can only be hooked up if you have tiny hands on universal joints) and instead installed a standard 4-pin flat trailer connector behind the tachometer. This morning, before the Midwestern steam heat turned on, I took the bike for a 20-or-so-mile ride. The fairing works quite nicely. I can ride with the visor up on my open-face helmet and see over the windshield. You can tell this is '80s tech as the shield lacks the "flip" that's common on new windshields. I might buy one of the little clip-on or stick-on things to provide a bit of a flip and move the air up a tiny bit higher.
    I am still feeling a bit of wiggliness when leaned over in a corner. I should say I take corners faster on this bike than I do on either the Himalayan or the Harley, but when it's leaned over it feels like it's hunting for its line. I checked tire pressures and they are OK. Haven't gotten around to snugging the steering head bearings a tiny bit and/or checking the swingarm pivot bearings. I probably should. I also suspect my choice of front tire: I am running a Dunlop Trailmax Mission "50/50 street/dirt" tire up there, and after a few thousand miles it's worn kinda chunky. Next time around I will go with something more street oriented.
    Huntchuks and Fuller56 like this.
  20. Jarich
    Jarich Member
    Ontario Canada
    PXL_20260904_004119887.PORTRAIT.jpg PXL_20260904_004119887.PORTRAIT.jpg Fit longer rear shocks and dropped the front 6 mm. There's a better stance
    Dave in Ireland and Brhatweed like this.
  21. ScottFree
    Northern Ill-Annoy
    Yesterday morning, before Mother Nature turned on the steam heat, I took the Maxim for a 75-or-so-mile ride.
    Riding with a Purpose!
    I was happy with the fairing's performance. Had the bike up over 75 mph without any issues, and the air pocket is definitely bigger and more comfortable at that speed than with the little flyscreen I had previously run.
    I had to stop for a few minutes at a construction zone, and the flag guy (who looked to be at most 21 years old) asked if I was blipping the throttle to keep the engine from overheating. I explained how it's an old bike, it doesn't want to idle, so I'm just keeping it from stalling out. He then said he thought it's a really nice-looking bike, which I could not disagree with. Then the zone cleared and I was on my way.
    I am looking for words to describe the handling and stability issue. The best I can come up with is "twitchy." I can take my hands off the bars at 65 mph and the bike will track straight and true without the slightest hint of weave or wobble for several seconds (I don't have a throttle lock, so it slows down to about 50 while I'm doing that). But, if I am going a steady 60 or so with my hands on the bars, and shift my butt a little, the bike gives a definite "wiggle" that settles down in a fraction of a second but is a little scary until it does. And when I am leaned over in a corner, it seems to hunt for its line. Just a little, like that vague feeling we used to get on grooved pavement in the days of "rib" front tires. For the time being, I am assuming it's happening because the head bearings and/or swingarm bearings need to be tightened. I hope to get those tasks done later this month, before I set off for the Crud Run and the Driftless at the beginning of October. If I still have the "hunting" behavior in corners, I may try replacing that Dunlop Mission front with a more street oriented tire.
    Another thing that I suspect is a "you just have to live with it" item: this bike really cooks my left calf. The engine doesn't seem any hotter on the left side, but I think the alternator sitting behind cylinders 1 and 2 pushes hot air out further and into my leg. It can get pretty unpleasant at times, though it's much reduced if I just make sure to splay my knee out a couple inches further. I really wish the bike had a wider gas tank--not just for longer range between fills, but also to keep my leg further from the engine!
    RideAlong420, Rooster53 and Fuller56 like this.
  22. Brhatweed
    Mora MN
    How's the swingarm bearings? My SECA got a little twitchy when the preload came out and it didn't want to track curves very well. That front might also be a bit much for a street bike.
  23. Fuller56
    That Rifle fairing does look slick on your bike. Just the right size. Well done Sir.
  24. Brhatweed
    Mora MN
    I'd love to get on that one! Very nice indeed.
    Jarich likes this.
  25. Jarich
    Jarich Member
    Ontario Canada
    Thanks. It even has rear brakes and rear drive now so that ride has a fair better chance of happening.
  26. Brhatweed
    Mora MN
    I'm always a sucker for classic Yamaha be it bikes, audio or a concert grand piano.
  27. co.dirtbiker
    co.dirtbiker Active Member
    Colorado, USA
    Today I did one of my least favorite jobs in prep for doing a full brake rebuild on my 750 Seca. I removed the front fairing. It's not that it's that tough of a job, but it always exposes all the things that I need to address that I keep putting off.
    Several of the bolts are awkward to get to and require removing my GPS mount for access to the nuts inside the fairing. That turned out to be less of a chore than I expected. Just had to loosen up the screws enough and jiggle it around to get the clamps to pop out.
    The big 'ole connector that plugs in to the bike has all the tabs broken off so it doesn't stay in place, making it really hard to get plugged and unplugged. I think I might be able to 3D print a solution for that, but I need to check it out closer. It also has a toasted pin, although I think I already fixed that by moving to a different unused one.
    The lower sections of the fairing are both broken where they mount to the bike, and one has now completely detached. Not even sure how I'm going to get that fixed. The PO had tried to reinforce it with some pieces of scrap plastic, but that didn't last long. I added some fender washers but obviously that didn't help much either. I'm open to suggestions. Fiberglass or JB weld maybe?
    The good news is I think I stumbled upon the reason the aux headlight has never worked. I hadn't ever looked into it before first because I don't even know how to turn it on (or does it stay on like the headlight?) and two because I just assumed it was a burned-out bulb and was too lazy to replace it. Turns out there is a broken wire. I think it's ground and I think it's supposed to go into the Y connector coming from the blue wire. It's the only thing I see that looks like it's got the stub of a bullet connector with no wire going to it. The other side of the Y goes to the turn signal, which is why I assume ground since it wouldn't make sense to split the blinker positive.
    It's all off now. The parts for the rebuild are either already on the shelf or on order from Len. The brakes had gotten really bad, with one pad wearing much faster than the rest, pulsing, and generally weak operation. Hopefully by the time I'm done it'll be at least as good as the brakes on the 900.
  28. Rayzerman
    Rayzerman Member
    Ontario Canada
    I use Permatex Plastic Epoxy for broken plastic...... a fair amount of working time 15 minutes, it's not runny and you can kind of form it to what you need it to be. Use it as a glue and filler if need be.... however, OTOH, JB Weld Plastic Epoxy is runny and takes forever to cure, use it as a glue and filler also...., but it's not as strong or as tough as Permatex. With either, may need more layers, and can sand, file, drill, paint.... a primer is recommended for best results.
    Jarich likes this.
  29. Jarich
    Jarich Member
    Ontario Canada
    Have you tried baking soda and super glue(CCA?)
  30. Jarich
    Jarich Member
    Ontario Canada
    PXL_20260906_201519831.PORTRAIT.jpg PXL_20260906_201519831.PORTRAIT.jpg PXL_20260906_201519831.PORTRAIT.jpg The very best thing. The first test ride. Very happy with this
  31. co.dirtbiker
    Colorado, USA
    I'll look for it. The problem is it right on a bend in a high stress place, so maybe if I build up some fillets it may have more strength.
    I've seen it used. Does that have enough strength? Seems like it would be brittle.
    I crimped a new connector on the aux light, but still no joy on making it work. I did jumper it to the battery and it lights up, so I know the bulb and wiring in the light is good. The wiring on these things with the fairing is a rat's nest. The whole mess looks cobbled together with splices and splitters all over the place, and the jumper wire colors don't match the source colors so it's hard to tell what's going on. I have always assumed that if this light is switched in some way, this is probably the switch. Can anybody confirm? I've never figured out any other purpose for it.
    Jarich likes this.
  32. Fuller56
    @co.dirtbiker, I would say yes, that should be the switch for the aux light. The ones I have had have had what looks like an added on at the factory switch under that pod. I will check the wire colors and connections on the RJ750R in the morning.
    Yes, also, for the baking soda and super glue plastic fix. That stuff is not brittle in any way, shape or form! I have used it on a bunch of motorcycle plastic repairs without any failures. I have read that using finely ground charcoal is even stronger but have not tried that yet. The stuff sets instantly. I dust the parts in question with the baking soda and then a drop of super glue and repeat until you are happy. Lots of times there will be a tiny puff of reaction smoke.
    Jarich likes this.
  33. Brhatweed
    Mora MN
    Yes that is the aux light switch and do be careful as these are very delicate and will not handle anything larger than a 55 watt bulb. Yamaha just tack-soldered the wires to the leads and they corrode away. I ended up wiring in a Bosch cube relay to run my aux light which happens to be a 130 watt Hella and use the switch to fire the relay coil.
    Jarich likes this.
  34. chacal
    Whoa Nellie!
    Jarich likes this.
  35. Jarich
    Jarich Member
    Ontario Canada
    It's very much not brittle. From what I can understand it was developed through the floor repair guys and the RC body repair guys. It's amazingly effective across a lot of plastics types. And there's nothing on that list that I haven't tried it sometime and they all are just a surface repair. They fail to bond. This stuff becomes plastic and bonds directly with the base material. I use fiber tape for drywall as backup on the inside of a big repair. But you can easily fill in a turn signal hole in the middle of a fairing with this stuff. I could fill this thread with many examples of repairs if you are truly interested.
    Gorilla glue makes a bigger bottle so you're not squeezing out a thousand crazy glue tubes. Vinyl floor repair suppliers have bigger bottles yet and colors available. Definitely to be done in well-vented places and never grind it till it it smokes. It prefers low speed die grinding work more
  36. co.dirtbiker
    Colorado, USA
    @Jarich I'll have to try the baking soda/CA trick. If you can show a couple examples of ones that have worked well, I'd love to see them to get an idea of how much you built up. The drywall tape sounds like a good idea to help reinforce the area since it takes so much stress.
  37. RideAlong420
    RideAlong420 Active Member
    USA
    I noticed this too from riding! It's not the end of the world as long as you wear jeans but I noticed my left knee tends to get HAWT because this bike runs like an oven. I was riding a bit and was like "what is happening to my knee, oh"
    The carbs themselves get warm but not "hot" but absolutely warm.
    I never knew what this was called, or even that the behavior could be due to suspension/steering head bearings, thanks for this
  38. Jarich
    Jarich Member
    Ontario Canada
    @co.dirtbiker
    These are of couple recent ones.
    A keyhole delete that was done just by putting tape on the outside and building up the glue and soda behind it.
    The other is a tab I repaired a couple of years ago that's now broken one of its fingers. I'm going to try a wire rebar embedded in it before I glue it some more. It'll be a good test for it.
    It's standard chemical body work other than that. Roughing it up for some good tooth keeping it chemically clean with alcohol. It sets quick but it doesn't get its true strength for 24 hours when you're laying in multiple layers. It trowels well but you have to have a clean knife every time you work it
  39. Jarich
    Jarich Member
    Ontario Canada
    co.dirtbiker likes this.
  40. co.dirtbiker
    Colorado, USA
    @Jarich Those are impressive. I also have a little chunk missing on the front fender mount of the 900. I bet I could get that filled in too.
  41. Jarich
    Jarich Member
    Ontario Canada
    @co.dirtbiker For sure. My order of attack is to tape the outside to hold it all together.
    Grind, clean and reinforce the inside with fiba tape. Let it dry for a couple of days.
    V groove the outside cracks and use glue and soda to fill them. Once dry a 1 inch olfa blade makes a great scraper to shape it. Just standard polyester filler after that.
    Uxbridge Brule likes this.
  42. ScottFree
    Northern Ill-Annoy
    On Tuesday I checked my swingarm and steering head bearings. The most "difficult" part of the process was getting the wheel back on; for some reason getting it aligned and into the splines is a form of magic--I will get it into what feels like the correct place, but it won't actually slip on the splines; I put the bike in first gear so the FD splines won't move, but no matter how much I rotate and push the splines don't engage; I pull the wheel back off and lift it into position again, and suddenly it slips right on and I have no idea what I did right. Just like slipping the drive shaft splines into the FD on my BMW... if anybody knows a trick for this...
    Anyway, I found zero left-right play and smooth motion, so the swingarm bearings appear to be OK. I didn't check the torque on the adjuster stub, figuring the absence of play meant it should be right and I stood a better chance of mucking things up by loosening the locknut and attempting to set the preload. If it ain't broke, don't fix it...
    Moving on to the front of the bike, I increased the preload on the steering head bearings by about 1/8 turn. This isn't much given how fine-thread the adjuster nut is. I set it to a point where it took just a bit of force to make the fork swing (as opposed to its just flopping under gravity). Neither of my manuals (Yamaha or Haynes) give a quantitative setting for this adjustment, only "so it's not loose or too tight." Thanks a lot... In any case, since I retrofitted tapered roller bearings here, a procedure for setting the stock ball bearings might not be particularly useful anyway. My Buell had a specific setting for preload: something like two pounds of force (measured with a fishing scale) applied to the fork to move it from the straight-ahead position. I aimed for something in that general vicinity, measured by the calibrated finger.
    I didn't have a lot of time for a test-ride, but I did get out to ride some curvy roads near my house. It seems more stable, less "hunting" in the corners, less twitchy about shifting my weight on the seat. I still think that chunky off-road tire up front is contributing a bit, and I suspect having 1/2" longer than stock shocks at the back might also be a factor.
    In any case, it seems to work better. I hope to give it a more thorough test tomorrow, when I have a ~150 mile lunch ride to the brewery planned.
    Also, in preparation for the 4-day, ~1000-mile Oktoberfest/Slimey Cruds trip coming up in a few weeks, I installed a USB power supply on the inside of the Rifle fairing (to operate my navigation system) and replaced the 25/50 watt LED in the headlight (a Bosch H4 I installed a couple years ago to replace the stock sealed beam) with a proper 55/55 watt halogen. The LED produced a nice white light, but it's not possible to make an LED that fits into an H4 lens/reflector and delivers the same light pattern as a halogen bulb. I was pleased to see that doing these things had no effect on the charging system voltage, which still sits at 14.4 +/- 0.1 most of the time.
    Progress, one step at a time...
    Uxbridge Brule and Fuller56 like this.
  43. Jarich
    Jarich Member
    Ontario Canada
    Gave the 900 it's first good highway run to visit friends at the vintage club race at Shannonville.
    The 900s were really rare around here so I truly have little experience riding them. What a great engine. Pulls like a train, jetting still seems spot on, chassis is working well but I need taller bars for comfort. I have the guy working on a top clamp right now.
    Simmy, co.dirtbiker and Fuller56 like this.
  44. co.dirtbiker
    Colorado, USA
    Some long overdue brake maintenance on the Seca 750. Got the first caliper done. Working on the anti-dive unit now. What sadistic SOB designed that spring clip halfway down the cylinder??! OMG what a pain! After probably an hour of fiddling and cursing I finally got the clip out, but now the piston is getting hung up on burrs in the threads and won't come out. I got tired of cursing at it for today. Tomorrow I'll try some sandpaper or something to see if I can smooth it out.
    Still have to do the other caliper, the other anti-dive, the master cylinder, new rotors and I think I am going to go ahead and do fork seals while I have it apart. They aren't terrible, but they do seep a little.
    Brhatweed, Dan Gardner and Jarich like this.
  45. Brhatweed
    Mora MN
    So the only thing I've done to my Yamaha is watch the odometer pass 52,000 miles this afternoon.
  46. ScottFree
    Northern Ill-Annoy
    Last Friday I rode the XJ out to lunch at the brewery with a friend (last time I did this, last fall, I had to turn around at the meeting place because carb #1 was overflowing). This time the bike ran just fine (other than the idle issue), and I think I’ve licked the twitchy feel and hunting in corners.
    And it appears the Rifle fairing added about 3-5 mpg to the gas mileage. I ran through a whole tank on this 150-mile ride, and it delivered an even 50 mpg, up from about 46 before I installed the fairing.
    Rooster53, Fuller56 and Dan Gardner like this.
  47. Jarich
    Jarich Member
    Ontario Canada
    I love this bike
    430am departure 700km down 250km to go
  48. Fuller56
    @co.dirtbiker, please excuse my tardiness about getting you light switch wire colors, I beg forgiveness. The wires coming out of the auxiliary light switch on my XJ750R are red with a blue tracer and blue with a black tracer. The wires at the light are black and red with a black tracer.
  49. co.dirtbiker
    Colorado, USA
    @Fuller56 No worries. I moved on from that for now to work on the brakes. Once I get those done, I'll turn my attention back to the wiring mess. Thanks for the info.
  50. Brhatweed
    Mora MN
    If you want I can do a scan of the wiring and post a PDF
    Jarich likes this.
